    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 393.7k Views 109 Watching
    • enigmaticE Offline
      enigmatic
      @rogalxxx said:
      I'm having problems with the plugin in SU 2017. Su 2015 seems to be working fine.
      Using even stock settings I get a lot of random tiles missing.
      I have that same problem.Is there a solution?
      Murat
      • jujuJ Offline
        juju
        You could always do a work-around by saving the SKP in 2016 version, open SU2016, do what you want there with the plugin, save and open in 2017 again. I know, far from ideal.
        Who has any experience with Oob Layouts? It also reports only compatible up to 2015, but I have often had where extensions say that and work fine in the later (supposedly incompatible) SU version. Anybody willing to trial it?
        • sdmitchS Offline
          sdmitch
          I have tested FloorGenerator in SU2017 and had no problem with missing tiles.
          Could you post your model so I could test it myself?
          http://sdmitch.blogspot.com/
            rogalxxx
            here, Floor generator on stock settings, two identical planes-second one with tiles applied.
            looks like geometry has some random lines and faces, even though I have set no random parameter.
            tile test.skp
            • Mousa_SAM Offline
              Mousa_SA
              I confirm, this issue is happening with me too,although there are no other plugins are active with it.
              • sdmitchS Offline
                sdmitch
                I retested FloorGenerator in SU2017 using your model and, in 16 tests, 5 appeared to be normal, 1 had a single tile missing and the other 10 had several missing in random locations.
                My initial test seemed ok because I stupidly used the Random Colors option.
                I will do what I can to fix this problem.
                [highlight=#ff0000:153r5xxr]GOOD NEWS!!!! Once again it seems that the problem is the same old group explode redefining the ID of the selected face. Updated version now available in Plugin Store and my blog.[/highlight:153r5xxr]
                • sdmitchS Offline
                  sdmitch
                  [highlight=#ff0000:sj7zyo1x]GOOD NEWS!!!! Once again it seems that the problem is the same old group explode redefining the ID of the selected face. Updated version now available in Plugin Store and my blog.[/highlight:sj7zyo1x]
                    rogalxxx
                    sdmitch you are awesome! Thank you. Glad I could contribute! 😄
                      Infinite walk to the perfection! 😎
                        enigmatic
                        Sam, you rescue me from a big trouble. Very thanks.
                          rogalxxx
                          why is there no option for an origin point where you click? Why center or left lower corner only? I mean this would be useful 😄
                          • sdmitchS Offline
                            sdmitch
                            Because I assumed that the center or a corner were the most logical points of origin. FYI, the closest corner to the point you pick is used. Not just the lower left corner.
                              markpyvi
                              Can I please have a link for SU7. Latest one doesn't seem to work in SU7.
                              Cheers,
                              Mark
                              • sdmitchS Offline
                                sdmitch
                                Cheers,
                                Mark
                                Sorry I can't. There is only one version.
                                  seems working perfectly in 2017! ☀
                                  • sdmitchS Offline
                                    sdmitch
                                    [attachment=0:ocy8vhzy]<!-- ia0 -->sdm_floor.jpg<!-- ia0 -->[/attachment:ocy8vhzy]
                                    I think he has version 7 not 2017.
                                      markpyvi
                                      @sdmitch said:
                                      Cheers,
                                      Mark
                                      Ok, no worries, will use 2017 for this step. Cheers.
                                        marche3d
                                        Hello could you tell me how to install it please...!!!!
                                          Most Plugins and Extensions' RBZs can be downloaded from the SketchUcation PluginStore:
                                          https://sketchucation.com/pluginstore?pln=SDM_FloorGenerator
                                          Have a browse and be amazed...
                                          Use the native Extension Manager to install them.
                                          Alternatively download and install the SketchUcation ExtensionStore³, then you can browse and auto-install extensions directly from with SketchUp itself - sidestepping the download part altogether...
                                            c3dx
                                            Just can't make it work, the command window never show up
                                            I reayly like to make it run.....
                                            There is what i get when i try to run it
                                            SystemStackError: stack level too deep
                                            I do have Sketchup 2017 Version 17.21.2555 64 bit
                                            On windows 10 professionnel version 1703(15063.332)(French Version)
                                            I have Thearender for sketchup plugins install
                                            Graphic card: GTX 1060
                                            CPU: AMD FX-6300
                                            8 gig off ram
                                            i have this message in the console
                                            i also have this line appears many many time before the error
                                            read_default failed
                                            Error: #<SystemStackError: stack level too deep>
                                            C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in initialize' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in initialize'
                                            C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in method_missing' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in update_wd'
                                            C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:174:in rescue in update_wd' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:160:in update_wd'
                                            C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:170:in rescue in update_wd' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:160:in update_wd'
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
