    Canyon
    11 Posts 6 Posters 1.7k Views 6 Watching
    • cheddaC Offline
      chedda
      Canyon
      Sketchup,Skatter,Erode plugin & Maxwell Render.
      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
      • Bryan KB Offline
        Are you reading my mind? I've been thinking about how to tackle a canyon scene for some time now.
        That looks excellent!
        I think I need to think about it some more. πŸ’š
          Does Maxwell allow you to overlay a noise texture on an existing texture similar to Thea?
          If it does I would try it on the walls to breakup to colour more.
          • cheddaC Offline
            chedda
            Thanks for the comments. Yes the texture needs some work i did consider displacement too for a moment but it's such a huge area. The erode plugin is an excellent tool for sketchup i highly recommend it.
              I didn't mean displacement noise. I meant colour noise.
              In Thea you can add perlin noise overlay on a texture to procedurally breakup the texture's tone.
              It's a tip Massimo shared for using it on leaves and it works great.
              • cheddaC Offline
                chedda
                Yes i understood. I can add a layer to allow patches of colour with a different mapping to add differentiation.I often do this with grass over a large area.
                • HornOxxH Offline
                  HornOxx
                  this is just awesome!!! I also thought about such a model task already but had no idea how to start πŸ˜„
                  And yes, the erode plugin is a great "must have" tool
                  thanks for sharing
                  never trust a skinny cook
                  • andybotA Offline
                    andybot
                    very cool! My 2 crits:
                    • floor is too level and gravel seems too even sized.
                    • the edge of the shadows should not be so smooth (I can understand not wanting to use displacement but it's the shadows where this falls apart...)
                    • cheddaC Offline
                      chedda
                      Yes thanks for the observations. If i kept the geometry sharp it would have given away the triangulation and looked a bit false. This scene literally took minutes to model it was just a test initially. It could be improved i'm sure.
                      • andybotA Offline
                        andybot
                        Yes, I get that you don't want it to look faceted, that's not what I meant though. You see how the texture is rough, with seams in the rock. A displacement map would break up the edges of the shadow line to match the texture underneath. Right now, the shadow just kind of floats over the texture. I understand it was a quick study - it's more a comment about the materials than the modeling.
                          Seriously good, needs a bolder strewn floor though.
