    Struggling to export to .dwg
    15 Posts 3 Posters 1.3k Views 3 Watching
    • G
      GBaird
      I've worked out how to purge !
      But I still can't export a 2D .dwg ?
      By the way, I'm loving the sticky out tongue tiger 😄
        I actually used my own 'Purge All' tool - it gives you a log report if you want...
        http://sketchucation.com/pluginstore?pln=PurgeAll
        Although it's not yet been [re]signed, it will work OK in >=v2016 in unrestricted loading-policies...[mod=:1f935uzs]It's now signed !
        http://sketchucation.com/forums/viewtopic.php?p=616482#p616482[/mod:1f935uzs]
        The SKP works fine for me making the DWG.
        I assume that DWG is sufficient for your needs at the moment.
        However, your issue suggests some other problems...
        Try the following.
        Close SketchUp.
        Find the v2017 installer exe file [probably in your Downloads folder - if not re-dowmload a new copy].
        Select its icon and right-click > context-menu > "Run as administrator"
        When prompted choose 'Repair'.
        Retry exporting...
        Any improvement ?
        If not repeat the above steps [...as admin'] but choose to uninstall, then immediately re-install it.
        Retry...
        I am suspecting that the issue is due to an incorrect installation.
        Simply double-clicking on the installer icon - even if you have admin powers - is no longer sufficient to properly install most modern applications in the newer Windows OSs...
        Please report back...
        • G
          GBaird
          Thank you for the tool link 😄
          So I've followed your directions and it's still crashing .....
          I'm thinking it may be an even bigger issue so I'm going to give the whole PC a re-format first thing tomorrow.
          Is there any chance you would be able to possibly export me a 2D version of the file in .dwg - I would be eternally grateful !
            A 2d dwg version will loose all layering etc.
            Is that what you really want ?
            It might be what's taking the time...
            It's taking ages for me !!
            Why do you need a 2d dwg ?
            • G
              GBaird
              It's so that I can change the line weights etc ..... or is there a way to create a 2D in CAD so you can't see through the walls ?
              I don't really know how to use 3D CAD to be honest, I've only ever used 2D.
                My 2d export is still running, so I suspect that's your issue !
                As you have Pro why not bring the SKP's view [saved as a Scene-tab!] into a Layout page [set up your Layout document to the desired paper-size etc...
                Then you can perhaps over-draw edges to make them heavier etc.
                Since we don't know your exact final desired result, then we are guessing here !
                  I scrapped the 2d dwg !
                  Here's a 3d dwg but with just edges [no faces] as set in the exporter's options...
                  170319 House Options Exploded[lines_only].dwg
                    @gbaird said:
                    Thank you very much - but what I'm trying to do is this.
                    What ?
                    Please consider Layout for this...
                    • G
                      GBaird
                      3D court XL Small.pdf
                      • G
                        GBaird
                        I've popped a PDF up.
                        Can layout do line weights ?
                          Yes.
                          You can draw over edges, or copy edges and paste into layout and change their thickness/color etc...
                          It seems you are at the start of your journey... e.g.
                          https://www.youtube.com/watch?v=JnHrdUCenzs
                          There are dozens of examples...
                          • JQLJ
                            JQL
                            What I do is that I use Tig´s Section Cut Face on my model then export 2 scenes from Layout:
                            1 - Sectioned model view;
                            2 - Section cut face scene with same camera as 1 but model is hidden.
                            In layout I overlapp the two scenes where 2 is on top of 1.
                            Then I can have lineweights for 1, different than 2 and still update the 2D drawing on the fly as I work on the model.
                            I also add details to the section cut face, for construction detailing.
                            When finished, if needed, I export to dwg from Layout.
                            www.casca.pt
                            Visit us on facebook!
