    Struggling to export to .dwg
    15 Posts 3 Posters 970 Views 3 Watching
      GBaird
      Hello
      I've sketchup a draft model of my proposal but I am really struggling to export it to .dwg so that I can add lineweights as a 2D.
      I left it running all night and when I cam back to it this morning sketchup had just crashed out.
      Any help would be much appreciated as this is due tomorrow morning - thank you
      https://www.dropbox.com/s/9749dwfyd5o3ojo/170319%20House%20Options%20Exploded.skp?dl=0
        I Purged your 14Mb monster SKP down to 2Mb !
        It exported as a DWG in a few seconds.
        Attached are the reduced SKP, DWG and Purge log...
        170319 House Options Exploded.skp
        170319 House Options Exploded.dwg
        170319 House Options Exploded-PurgeLog.txt
          GBaird
          Ah thank you - how do you purge ?
          I was actually looking to get a 2D dwg file and after downloading your clean version I still dont seem to be able to export it, It's still crashing ?
            GBaird
            I've worked out how to purge !
            But I still can't export a 2D .dwg ?
            By the way, I'm loving the sticky out tongue tiger 😄
              I actually used my own 'Purge All' tool - it gives you a log report if you want...
              http://sketchucation.com/pluginstore?pln=PurgeAll
              Although it's not yet been [re]signed, it will work OK in >=v2016 in unrestricted loading-policies...[mod=:1f935uzs]It's now signed !
              http://sketchucation.com/forums/viewtopic.php?p=616482#p616482[/mod:1f935uzs]
              The SKP works fine for me making the DWG.
              I assume that DWG is sufficient for your needs at the moment.
              However, your issue suggests some other problems...
              Try the following.
              Close SketchUp.
              Find the v2017 installer exe file [probably in your Downloads folder - if not re-dowmload a new copy].
              Select its icon and right-click > context-menu > "Run as administrator"
              When prompted choose 'Repair'.
              Retry exporting...
              Any improvement ?
              If not repeat the above steps [...as admin'] but choose to uninstall, then immediately re-install it.
              Retry...
              I am suspecting that the issue is due to an incorrect installation.
              Simply double-clicking on the installer icon - even if you have admin powers - is no longer sufficient to properly install most modern applications in the newer Windows OSs...
              Please report back...
                GBaird
                Thank you for the tool link 😄
                So I've followed your directions and it's still crashing .....
                I'm thinking it may be an even bigger issue so I'm going to give the whole PC a re-format first thing tomorrow.
                Is there any chance you would be able to possibly export me a 2D version of the file in .dwg - I would be eternally grateful !
                  A 2d dwg version will loose all layering etc.
                  Is that what you really want ?
                  It might be what's taking the time...
                  It's taking ages for me !!
                  Why do you need a 2d dwg ?
                    GBaird
                    It's so that I can change the line weights etc ..... or is there a way to create a 2D in CAD so you can't see through the walls ?
                    I don't really know how to use 3D CAD to be honest, I've only ever used 2D.
                      My 2d export is still running, so I suspect that's your issue !
                      As you have Pro why not bring the SKP's view [saved as a Scene-tab!] into a Layout page [set up your Layout document to the desired paper-size etc...
                      Then you can perhaps over-draw edges to make them heavier etc.
                      Since we don't know your exact final desired result, then we are guessing here !
                        I scrapped the 2d dwg !
                        Here's a 3d dwg but with just edges [no faces] as set in the exporter's options...
                        170319 House Options Exploded[lines_only].dwg
                          @gbaird said:
                          Thank you very much - but what I'm trying to do is this.
                          What ?
                          Please consider Layout for this...
                            GBaird
                            3D court XL Small.pdf
                              GBaird
                              I've popped a PDF up.
                              Can layout do line weights ?
                                Yes.
                                You can draw over edges, or copy edges and paste into layout and change their thickness/color etc...
                                It seems you are at the start of your journey... e.g.
                                https://www.youtube.com/watch?v=JnHrdUCenzs
                                There are dozens of examples...
                                • JQLJ Offline
                                  JQL
                                  What I do is that I use Tig´s Section Cut Face on my model then export 2 scenes from Layout:
                                  1 - Sectioned model view;
                                  2 - Section cut face scene with same camera as 1 but model is hidden.
                                  In layout I overlapp the two scenes where 2 is on top of 1.
                                  Then I can have lineweights for 1, different than 2 and still update the 2D drawing on the fly as I work on the model.
                                  I also add details to the section cut face, for construction detailing.
                                  When finished, if needed, I export to dwg from Layout.
                                  www.casca.pt
                                  Visit us on facebook!
