    Struggling to export to .dwg
    15 Posts 3 Posters 1.3k Views 3 Watching
      GBaird
      Ah thank you - how do you purge ?
      I was actually looking to get a 2D dwg file and after downloading your clean version I still dont seem to be able to export it, It's still crashing ?
        GBaird
        I've worked out how to purge !
        But I still can't export a 2D .dwg ?
        By the way, I'm loving the sticky out tongue tiger 😄
          I actually used my own 'Purge All' tool - it gives you a log report if you want...
          http://sketchucation.com/pluginstore?pln=PurgeAll
          Although it's not yet been [re]signed, it will work OK in >=v2016 in unrestricted loading-policies...[mod=:1f935uzs]It's now signed !
          http://sketchucation.com/forums/viewtopic.php?p=616482#p616482[/mod:1f935uzs]
          The SKP works fine for me making the DWG.
          I assume that DWG is sufficient for your needs at the moment.
          However, your issue suggests some other problems...
          Try the following.
          Close SketchUp.
          Find the v2017 installer exe file [probably in your Downloads folder - if not re-dowmload a new copy].
          Select its icon and right-click > context-menu > "Run as administrator"
          When prompted choose 'Repair'.
          Retry exporting...
          Any improvement ?
          If not repeat the above steps [...as admin'] but choose to uninstall, then immediately re-install it.
          Retry...
          I am suspecting that the issue is due to an incorrect installation.
          Simply double-clicking on the installer icon - even if you have admin powers - is no longer sufficient to properly install most modern applications in the newer Windows OSs...
          Please report back...
            GBaird
            Thank you for the tool link 😄
            So I've followed your directions and it's still crashing .....
            I'm thinking it may be an even bigger issue so I'm going to give the whole PC a re-format first thing tomorrow.
            Is there any chance you would be able to possibly export me a 2D version of the file in .dwg - I would be eternally grateful !
              A 2d dwg version will loose all layering etc.
              Is that what you really want ?
              It might be what's taking the time...
              It's taking ages for me !!
              Why do you need a 2d dwg ?
                GBaird
                It's so that I can change the line weights etc ..... or is there a way to create a 2D in CAD so you can't see through the walls ?
                I don't really know how to use 3D CAD to be honest, I've only ever used 2D.
                  My 2d export is still running, so I suspect that's your issue !
                  As you have Pro why not bring the SKP's view [saved as a Scene-tab!] into a Layout page [set up your Layout document to the desired paper-size etc...
                  Then you can perhaps over-draw edges to make them heavier etc.
                  Since we don't know your exact final desired result, then we are guessing here !
                    I scrapped the 2d dwg !
                    Here's a 3d dwg but with just edges [no faces] as set in the exporter's options...
                    170319 House Options Exploded[lines_only].dwg
                      @gbaird said:
                      Thank you very much - but what I'm trying to do is this.
                      What ?
                      Please consider Layout for this...
                        GBaird
                        3D court XL Small.pdf
                          GBaird
                          I've popped a PDF up.
                          Can layout do line weights ?
                            Yes.
                            You can draw over edges, or copy edges and paste into layout and change their thickness/color etc...
                            It seems you are at the start of your journey... e.g.
                            https://www.youtube.com/watch?v=JnHrdUCenzs
                            There are dozens of examples...
                            • JQLJ Offline
                              JQL
                              What I do is that I use Tig´s Section Cut Face on my model then export 2 scenes from Layout:
                              1 - Sectioned model view;
                              2 - Section cut face scene with same camera as 1 but model is hidden.
                              In layout I overlapp the two scenes where 2 is on top of 1.
                              Then I can have lineweights for 1, different than 2 and still update the 2D drawing on the fly as I work on the model.
                              I also add details to the section cut face, for construction detailing.
                              When finished, if needed, I export to dwg from Layout.
                              www.casca.pt
                              Visit us on facebook!
