    Version 2 is out!
    renderpluginsextensions
    69 Posts 16 Posters 47.4k Views 16 Watching
    • BoxB
      Yeah that's kinda what I meant by saying, perhaps it could be an option.
      Maybe a tic box for Ver 1 or ver 2, so a toggle for Outer shell or As modelled.
      I've noticed another small bug, sometimes it reverses all faces. I'll try and catch it doing it next time.
        I'll add this to my internal ticket.
        hmm... yes please. If you find a way to reproduce I'll look into it. (Could it be related to open instances? Toggling while editing instances?)
          designo_84
          why i can't use the 50% discount, today is still 11 of march?, the discount is appear only on the top but when i enter to paypal it gives me the full price.
            Are you the same user that reported this on Extension Warehouse? If not, PM me.
              rv1974
              BTW There is a bug on the 'view your cart' page: it is impossible to change the quantity of SubD's and Vert-tools via up\down spinners. I had to buy it from another PC.
              It happens if you visited (and clicked 'buy' button) previously.
                hm... what browser?
                  rv1974
                  FF, Chrome, maybe IE (not sure). Each new visit to buy page adds number of goods without option to tweak. Tried to purge history and erase cookies for this site..
                  But anyway managed to get some. Great tools, many thanks!
                    I just noticed that from the front page there is a clash between the front page graphic and the shopping cart.
                    But from any other page it's working fine, the spinners adjust the amount.
                    • T
                      TraxXx
                      Hi Thomthom !
                      First of all, many thanks for all your wonderful plugins, they save me such a precious time in my daily work on SketchUp. I've just bought vertex tools and SubD plugins few week ago and I'm slowly starting to get used to them.
                      One thing I'm working on is a curved wall with glass panels applied on it. This was achieved using Curviloft and Flowify and it's just an experimentation, not a work that has to be finished. I was wondering if there was a way (with SubD or another maybe) to subdivide only the iner faces of the glass panels.
                      The faces outside that link the glass panels to one another would stay straight whereas the inside faces would be smoothed to have a kind of Gaudi result in the end. Not sure if I'm being clear but that's one thing I couldn't achieve until now with Subd. When I smooth an object, I'd like to be able to decide when it's smoothing a geometry including its bounding edges or not.
                      I'm thinking here of an example with a water basin. I wanted to subdivide the stopper hole (where the water goes away)so that it's doing a smooth surved transition between the horizontal surface of the water basin but obviously Subd will also subdivide the edges of the horizontal surfaces, which I don't want. Of course, there's always a way to solve things so I just recreated the bounding edges to a rectangle and removed the undesired subdivided edges. Just wondered if you could implant a feature like that...
                      Thanks for your support.
                      Windows panel wall
                        Have you looked into the creasing tool? It let you control how much things a smoothed by.
                        • T
                          TraxXx
                          Yeah I did but looks like this shape is too complex and SubD can't handle it. I guess that's way too much polygons at once and the mesh is not properly made so it would crash everytime I try to crease, the whole mesh selected or simply a part of it. Never mind, I guess I should find another way to model this thing.
                          But still, I do believe that being able to decide directly from the beginning to keep bounding edges sharp or not would be a good feature to have. That would avoid having to edit the mesh after toggling on Subdivision. Even on simple geometries, the crease tool is very slow to show up and process on my side. I think my computer is good enough to run it (I have an overclocked i7 3770K)
                          I don't know if that would be hard to implement because it requires that the plugin is able to recognize the different bounding edges of each separate mesh composing the group. But maybe, that's not much of a big deal given the complex plugins you've made until now 😉
                            Can you share a sample model?
                            • T
                              TraxXx
                              There you go ! Just downloaded Fixit 101, it removed a lot of geometry and it's running smoother. Also, I had this geometry in a file with a lot of polygons so I isolated it in a new file and it's processing faster. Dumbly, I thought It would be the same processing speed but I guess SubD is actually processing the whole sketchUp file to display the crease tool stickers so it's asking a lot of ressources. Anyway, Maybe the file will help to understand my request : being able to crease the whole different meshes inside the group at once.
                              The problem is the geomtry is so badly done that some of them got subdivided with sharp corners and other got smoothed at corners resulting in a fail when trying to crease them sharp all at once. So the thing would be to crease manually each one desired.
                              That's why I'm asking if there would be a way to disable from the beginning the edges smoothing.
                              Thanks for helping !
                              curvy wall.skp
                              • O
                                optimaforever
                                Hello Thom,
                                Is there a quick way to select the rim edges of a quad mesh?
                                I have to keep the vertices at their place so I need to crease the corners , yet their selection can take some time and I was wondering if there's some script for this.
                                Usually I use Select Outer Edges by Chris Fullmer but it seems it's not supported anymore in SU2017.
                                  rv1974
                                  404 Not Found
                                  (sketchucation.com)
                                    @optimaforever said:
                                    Hello Thom,
                                    Selection Toys will to that for you.
                                    In SUbD v2 you can set corners to always be sharp - then you only need to crease the "inner corners".
                                    Creasing the edges will have little effect - you want to crease the vertices.
                                    • O
                                      optimaforever
                                      Thanks Thom for the reply,
                                      Actually the sharp border option didn't work at all.
                                      Perhaps had I to convert the sandbox mesh (+ artisan) to QFT quad first?
                                        That might be it... using QFT there is a toolbar button to convert Sandbox Tools meshes to QFT meshes.
                                        • O
                                          optimaforever
                                          That was it. Obviously something went wrong when subdividing... 😕
                                          not quads visibly
                                            Yes, from that screenshot it looks like SUbD treated each triangle as a separate face. Converting the mesh to QFT mesh will ensure the two sets of triangles from the Sandbox mesh will be treated as a single quad.
                                            • 3 / 4
