    Wrap-R for SketchUp
    extensions
    191 Posts 43 Posters 179.7k Views 43 Watching
      cuttingedge
      @oxer said:
      A second method, this give the best result, with SketchUV plugin.
      [attachment=1:2dx6nkvq]<!-- ia1 -->Secon method.jpg<!-- ia1 -->[/attachment:2dx6nkvq]
      [attachment=0:2dx6nkvq]<!-- ia0 -->calla-0UW.skp.zip<!-- ia0 -->[/attachment:2dx6nkvq]
      Thanks Oxer... it is how I would also normally do it using Sketch UV or by the native project texture . But there are limitations to this if you look closely.. Textures sometimes need to be stretched by UV mapping without distorting the map itself and this is what I want to achieve by unwrapping it.
      • dereiD Offline
        derei
        I put a quick tutorial together for the flower... it lacks some steps, but it could give some ideas of the workflow and the final result.
        It also points some flaws/bugs of the software, which should be investigated...
        It's a set of images in the archive along with the two .skp files (the one that i downloaded from the forum and the resulting one after uv-mapping).
        The biggest concern I have about the scaling-down bug. It scaled the model insanely down, when the uv-mapping was loaded with WrapR.
        below are the errors:
        Error in mesh after reloading
        Sized-down model and see the triangle with distorted UV
        Full archive (tutorial screenshots, skp files)
        QuickTutorial.7z
        Hope it helps...
        DESIGNER AND ARTIST DEREI.UK
          You didn't explain clearly your issue. I didn't know what you were referring to.
          We are aware of the scaling issue. And the next release will fix it.
          But if someone can reliable identify the workflow to reproduce it then please share it here.
            rv1974
            Derei, I complained earlier about scale bug and answer was to use [] keys to manage the tsx size. BUT when application blows up x50! scaling down 5% with bracket keys hardly helps. I'm curious whether this bug would migrate to final release.
            • dereiD Offline
              derei
              I am not sure if is 100% the cause, but i noticed it happening when I am scaling the uv-mesh in WrapR... seems that scaling the mesh will result in this model scaling-down. It should not alter the geometry, but only the way texture is projected on the mesh, but for some reason it does.
              Also, there are sometimes unwelded (red) edges that appear after the model was saved and automatically reloaded.
              Another issue is undoing the uv import from wrapr: if I imported the uv mapping on my model, but then i hit undo for any reason, i can't re import it or redo the operation.
              When I need that, I do a trick: i rename the existing wrapr sketchup file (found in WrapR folder), then I export again to wrapr. Now a new skp file will be exported. I delete the new file and I rename the old one back.. in this way i can import the uvs that were previously used... is a messy workaround, prone to many mistakes and it should be solved in a better way (eg. to allow importing uvs from custom selected file - this way i can save several uv options and test them separately).
                I like that idea.
                Added to list.
                • dereiD Offline
                  derei
                  @rich o brien said:
                  I like that idea.
                  Added to list.
                  About one week ago i sent you an email with a report with my first experience after a consistent use... I don't know if you received it, because I got no response back... even the shrinking bug was mentioned in there.
                    cuttingedge
                    Hope it helps...
                    Thanks Derei for taking time to do this tutorial. I got the idea! Im sure this will be useful!
                    • JQLJ Offline
                      JQL
                      Fine Tutorial Rich Derei. I was going to get there, I'm sure, but the "More manageable parts" is really the key for selection without the curve.
                      Great Tut!
                      www.casca.pt
                      Visit us on facebook!
                      • JQLJ Offline
                        JQL
                        Sorry Derei, I thought it was Rich that made the tut. It's excellent!
                        www.casca.pt
                          @derei
                          Email received.
                          We are working on a fix. We already know about it from the private beta.
                            rv1974
                            Rich, I'm trying to understand.. Do you confirm there's a bug with Wrap-R not obeying 'switch primary and secondary buttons' mouse mode? If yes, is it fixable?
                              jonorman
                              Quick question.. Will there be support for UDIM in WrapR ??
                                Gábor
                                It is a good idea. Thank you. It will not be in the first release but in future releases we might implement it.
                                  Gábor
                                  Thank you for spotting this glitch. Beta 1.0.5 has a fix for it. Please download and try it and let us know about the result.
                                  https://s3.amazonaws.com/wrapr-download/WrapR-installer_1_0_5.exe
                                    applemango85
                                    This really looks like a game changer for many
                                    I'm probably going to try and get the substance indie pack when it's next on sale so this would be a huge help.
                                    Only problem is I'm very much a mac user - hopefully once the pc version has been released work can start on the mac version?
                                      Synchronicity
                                      Great plugin... I am just wondering if you could possibly give me some advice as to a couple of things...
                                      What is the best workflow for using Photoshop for texturing
                                      (Convert .SVG to to .PNG, then export model as .obj and texture from there?)
                                      And also, after "triangulating" my mesh I assume this is what I should be doing, since the standard Sketchup models give the error of containing ngons if I try to send straight to wrap-r), my models get sort of distorted looking, and so do the UV's. Here is an image showing my problem.
                                      http://i64.tinypic.com/rclgsl.jpg
                                      Many thanks if you can point me in the right directional at all.
                                        If you use the latest PS then make a new document 1:1 ratio, say 2048 x 2048 px, and then save the UVs to SCG in WrapR.
                                        In PS use File > Place Embedded... to place the SVG into the document. Scale it to fit the boundaries. We export the SVG at 1024px x 1024px so you need to scale x2.
                                        Now you can paint however you wish.
                                        Try changing the mapping method in WrapR from the Mapping menu. If that still produces irregular results make more cuts to better resolve the UVs.
                                        Long triangles are hard to unwrap. Sometimes manual triangulation is needed in areas to control the mesh distribution.
                                        That help?
                                          Synchronicity
                                          Thanks very much for your tips Rich! I'll give them a shot later.
                                          Would there be any advantage (for more complex models) to putting the model through a program that can decimate/reduce polycount (and at the same time making it quad based) before running through Wrap-R, or would that sort of thing be best done after using Wrap-R while the sketchup model is close to it's native format?
                                          Thanks again for your help! Definitely a game changing plugin. I've been using Sketchup intemittently/not as much as I'd like since 2011 and this is the first time I've ever made a UV for a sketchup model haha.
                                            If you change the mesh you lose the UV information. So it is best to UV map the final mesh.
                                            I've been using Sketchup intermittently/not as much as I'd like since 2011 and this is the first time I've ever made a UV for a sketchup model haha.
                                            You're not alone. This is relatively new to SketchUp so I imagine the concept of UV mapping is new to a large portion of users.
                                            • 2 / 10
