    Straighten curved lines 360 panorama VRAY
    renderpluginsextensions
    4 Posts 4 Posters 1.2k Views 4 Watching
      Rocketinthecloud
      360 pano rendering VRAY SKetchup
      Hi all,
      I'm new to Vray in combination with Sketchup. How do I get straight vertical lines in a 360 pano render? They seem warped now (see attached image) Also the horizon seems to be off.
      What am I doing wrong? Hope you can help me out.
      Thank you in advance!
      Dirk
      • cottyC
        cotty
        I don't know V-Ray, but one possibility would be to use an external program to correct this (e.g. Hugin).
        my SketchUp gallery
        • filibisF
          filibis
          Your image is perfectly fine for a 360 panorama. You can test your image here if you wish: http://www.dermandar.com/share
          To straighten your horizon, you can use 'Hugin' as cotty mentioned. You can download it here: http://hugin.sourceforge.net/
          Here is how you do it:
          1- Load your spherical image.
          2- Go to 'Move/Drag' section. (Apply 180 Yaw if needed) Simply move and drag the image. Hold shift for straight dragging.
          3- When you're done and want to export, go to Interface>Advanced then 'Stitcher' section, adjust your canvas size or image format if necessary. Click stitch!
          Before and After stitching
          • P
            peerman
            Was the camera looking down? Next time try to have your camera look straight forward/horizontal. Maybe that helps?
            Best,
            iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
