[Plugin] ChrisP_ColorEdge
@stefx said:
I use Mac and it looks like it doesn't work.....
any tips?stef.
Oops!
Sorry but I do not test on Mac.
cmeed uses the plugin successfully on Mac
can you send me a copy of the errors returnedChristophe
Hi Christophe,
I have solved the problem just restarting my Mac.
Sorry for the trouble,Thank you for the amazing plugin!
stef.
no problem
it suits me -
Hi Everyone,
a new version ChrisP_ColorEdge 0.2.2
Adding the management layer
Draw an edge by layer, with a color of your choice or the color of the active layer.
Recolor the edges by filtering by layer, with a color of your choice or the color of the active layer.
Dotted lines by filtering by layer
Thank you to TIG for his plugin ListeLayerColors[flash=425,350:29yeejxt]http://www.youtube.com/v/GQ-DpoUOiTM[/flash:29yeejxt]
Enjoy
Christophe
****14/07/2010 Version 0.2.3 Fixed problem layer's observer
http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
Regards
Christophe
good plugin to counter autoCAD colored edges....
Very cool,
thank you for your share
A gotta have script and just super for tracing over scan'd drawings and such.
Thank you so very much.Note that if one selects a color visually from materials it will be the default for the line tool color.
Works well especially as on can sample on screen colors too this way for repeats.
Cheers
dtr
Is there anything special about the installation. I can't see the plugin in SU . I unpacked to plugins and it created a folder and a rb file ChrisP_ColorEdge_EN. Anything else? I would be very happy when I could draw dotted lines.
It is under ...VIEW __TOOLBARS ^`...Color Edge
Thanks Juan
Shade by 3 colors dosn't work for me Instead, it gives me the dialog, and when I click ok, NOTHING HAPPENS!
Yes,
I donยดt understand the tool neither. Use it for lines, enough for me. Sorry.
I have to investigate though I have the feeling that it is not tunned yet or updated. -
This tool allows to colorize the edges on a same plane by a mixture of two basic colors depending on the angle and possibly a second plane and a third color -
hello i would like tranlate this plugin to german but how ?
And it is Possible to have a different line width.
Thanks for the great work
best-off@gmx.net -
Good evening,
for the width lines it's not possible.
I will soon publish a new version, including a Spanish version translated by Diego Rodriguez. The new version adds faces to the lines drawn.
Can work on inner edges are groups and components.
It is possible to include a German version. Here are the lines to translate$aa_01 = "Length " $aa_02 = "TAB to modify parameters " $aa_03 = "Select the end of the edge == TAB to modify colors " $aa_04 = "Color on axis X " $aa_05 = "Color on axis Y " $aa_06 = "Color on axis Z " $aa_07 = "Color 45 degree " $aa_08 = "Color other axix " $aa_09 = "Color single " $aa_10 = "Color " $aa_11 = "Select the start of the edge == TAB to modify colors " $aa_12 = "No color " $aa_13 = "No RGB" $aa_14 = "RGB " $aa_15 = "TAB to modify colors " $aa_16 = "By Layer " $aa_17 = "No selection, do you want apply\nthe operation to all entities? " $aa_18 = "Stippling " $aa_19 = "% or cm " $aa_20 = "Adapt length " $aa_21 = "Color 1 " $aa_22 = "Color 2 " $aa_23 = "There are several instances\nDo make unique instance?\nOtherwise the definition will be modified... " $aa_24 = "Angle length " $aa_25 = "Angle color " $aa_26 = "Edge color " $aa_27 = "ColorEdge " $aa_28 = "Draw Color Edge " $aa_29 = "Draw edge by color by vector " $aa_30 = "Edge single color on select " $aa_31 = "Edge color by axis on select " $aa_32 = "Modify select in dotted line " $aa_33 = "Color Edge by click " $aa_34 = "Dotted line by click " $aa_35 = "Colored angle by click " $aa_36 = "Colors blend " $aa_37 = "Color select " $aa_38 = "Colored angle " $aa_39 = "Dotted line" $aa_40 = "By default" $aa_41 = "Active layer" $aa_42 = "All" $aa_43 = "Delete" $aa_44 = "Color layer" $aa_45 = "Keep" $aa_46 = "Whithout" $aa_47 = "Invisible" $aa_48 = "Yes" $aa_49 = "No" $aa_50 = "Selection of colors to use" $aa_51 = "Valid and save" $aa_52 = "Valid" $aa_53 = "Uncheck all" $aa_54 = "Chech all" $aa_55 = "Cancel" $aa_56 = "Color choice " $aa_57 = "Add face " $aa_58 = "Inputbox setup " $aa_59 = "Inputbox setup..........................................You must before colors selected " $aa_60 = "Language choice " $aa_61 = "List chosen colors " $aa_62 = "Parameters " $aa_63 = "Yes|No"
ChrisP
thanks i will check it out.
