    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 102.0k Views 35 Watching
    • N
      nida12345m
      hello everyone,
      sorry am new to this , but I have added the ruby of this plugin to my sketchup plugins file, but i still dont get the menu .. what is the problem? and how can i show the menu?
        It's not on Menu Plugins!!!
        It is only under Menu ...VIEW __TOOLBARS ^`...Color Edge
        • guanjinG
          guanjin
          This feature does not work on sketchup8.0--2013 πŸ˜’
            dullgirlnef
            I know this is a very old post but I am wondering if anyone knows if this plugin will work in Sketchup Make 2015? I downloaded the plugin but it doesn't seem to add a toolbar in the toolbar list.
            Thank so much
            Stephanie
            • OxerO
              Oxer
              Thanks for the plugin!!
              The Tab key to change the color doesn't work on mac, is it possible fix this issue on Mac?
              In the Color List window don't appear the scrollbar.
                @Oxer
                I haven't looked at the code at all [it is pretty old].
                Get the latest version from the PluginStore...
                http://sketchucation.com/pluginstore?pln=ChrisP_ColorEdge_EN
                However, the know bug on using TAB on MACs [unlike PCs] is that a KeyDown event doesn't trigger, but a KeyUp does...
                So for cross-platform it's always required that you use KeyUp - at least when testing for TAB presses.
                In the RB file's code you could try to edit the FOUR occurrences of
                def onKey**Down**(key, repeat, flags, view)
                to be
                def onKey**Up**(key, repeat, flags, view)
                That should then work on PC and MAC...
                • OxerO
                  Oxer
                  I installed the last version 0.2.3 and I changed onKeyDown >> onKeyUp but the Tab key doesn't work 😞
                    You must change EVERY KeyDown to KeyUp...
                    • OxerO
                      Oxer
                      I did it.
                        So I am now at a loss πŸ˜•
                        Sorry, but I have several v2017 problems of my own to solve, let alone those of other authors who opt not to support older plugins...
                        • OxerO
                          Oxer
                          I understand you TIG, and thanks for your help!!
                          I'll try with older version of Sketchup.
                            Sorry i have no more contact with C Plassais for the moment! 😳
                            • OxerO
                              Oxer
                              I use Sketchup with my students in the technical drawing lessons and it's very useful draw the edges with different colors. Would be possible assign another different key to TAB to select the different colors on Mac?
                              For example in Ivy plugin the ALT and SHIFT keys work fine.
                              • sdmitchS
                                sdmitch
                                Yes. Any key that works for you will do. However, there is one other problem that I found. On two occasions, colr1 = results and color1 = results should be colr1 = results[0] and color1 = results[0]. These statements appear around line 233 and 754.
                                Another problem is the number of Sketchup Colors far exceeds the number the inputbox pull-down can handle. It needs to be a WebDialog if you really want all the color choices.
                                http://sdmitch.blogspot.com/
                                • OxerO
                                  Oxer
                                  Thanks for the info sdmitch but I changed the lines 233 and 754 but nothing, the TAB key doesn't work 😞
                                  • sdmitchS
                                    sdmitch
                                    Remember nothing happens until the Tab key is released. Please check messages. I have sent a copy of the plugin I modified and tested.
                                    • boofredlayB
                                      boofredlay
                                      I understand this is an old plugin. Maybe someone has a quick fix but if not no problem.
                                      I am experiencing the lines being drawn outside the group or component being edited. See attached.
                                      • FrederikF
                                        Frederik
                                        What happens if you mark them
                                        Cut them to the clipboard
                                        Open the model group and paste them back where you want them...?
                                        Cheers
                                        Kim Frederik
                                        • boofredlayB
                                          boofredlay
                                          That works just fine, which is what I did most of the day (large building with joint lines). But it is an extra step not needed if they were drawn inside the group/component.
                                          Edit: If I had started it the other way (draw default lines in a separate group and just painted the group) I might have saved some time today. However, once down a path...
                                            Skatepark
                                            Hey Chris, I am having trouble modifying colours on mac. I am clicking TAB but the color menu doesn't open so it's on default all the time... Any suggestions?
                                            Cheers
                                            • 3 / 4
