    Material ID and Transparency
    renderpluginsextensions
    14 Posts 4 Posters 10.5k Views 4 Watching
      Can you render out a pass with transparency disabled...?
      • andybotA Offline
        andybot
        @valerostudio: I figured it out! - you don't have a refraction layer do you? It works fine with a refraction layer...
        Not to mention - it gets weirder if you have an ID color for the glass - it overlaps the ID color of the other IDs. see second matID map example.
        Here are my material settings:
          This smells like bugs all over the place!
            @andybot said:
            Note that the amount of transparency is very different with a single layer of glass.
            Isn't that the fog?
            • andybotA Offline
              andybot
              no, my fog color is pure white. There's two layers of reflection instead of one.
              Edit:
              Oh, and the dark blue glass is not completely transparent. This is a material I use for exterior renders when I don't want to see in the building.
              • andybotA Offline
                andybot
                Buggy, yes, just one of many 😞
                c'mon new beta!! πŸŽ‰
                One trick - if you are using a single layer of glass, is to change the refraction IOR to 1.0 to avoid distorting objects behind the glass.
                having the refraction layer works with both single and double thickness glass for MatID.
                Note that the amount of transparency is very different with a single layer of glass. (Edit: I am using a semi-transparent material for the dark blue glass instead of fully transparent.)
                • V Offline
                  valerostudio
                  Flipping A! Nice work to finding a trick for this pain in the butt bug. Seriously need this new beta.
                  • V Offline
                    valerostudio
                    The AA on the glass id channel does screwy things. Anyone know why this is?
                    • V Offline
                      valerostudio
                      I assume its a product of refraction. You can see the AA on the green edge compared to the red edge of the glass. Choppy and weird. At least this is a decent workaround. Thanks guys.
                        gparadis
                        Reverse question - is there a way to exclude 100% transparent material from the material ID render ? Say I have a texture of a tree where the foliage is opaque and an alpha channel masks what's not needed. Material ID still considers the transparent surface as a different material.
                        When a lot of objects are in background, selection is not optimal.
                        render preview
                        material id preview
