    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      penumbra
      Fredo,
      latest release seems to have an issue that at the end of stretching operation and click outside of group, instead of accepting the scale change it springs back to original shape, when I repeat the operation a second time, then the change is accepted. is happening consistently on every drawing.
      I am on SU 2015, windows 7.
      Any thoughts?
      Thanks.
        I just tried and I'm not seeing it. Could you upload an SKP file in which this happens?
          penumbra
          File attached. If you don't see the behavior when trying to stretch any of the building elements you see here then I must have interference from another plugin.
          Stretching.skp
            Which direction are you trying to stretch them in?
              Actually, I do see it in your model when I try stretching the large building.
                penumbra
                I use the scale to target tool and also I invoke the input dialog box via the TAB key. Either way the issue exists in any stretching direction.
                  penumbra
                  Thanks for looking at it. And now for the great search of the other offending plugin... How I wish there was a quicker way to detect and find plugin clashes.
                  Edit: On second thought. If Dave is seeing it also then there is a little issue with the plugin? Unless Dave and I have a similar plugin clashing with it?
                    I think we need Fredo's input.
                    • fredo6F Offline
                      Thanks for signaling. This is a side effect of the fix for bugsplat in SU2017.
                      I fixed it and will re-publish.
                      By the way, the fact that it work the second time is due to the fact that the first time, FredoScale chains two operations
                      • Make Unique
                      • Stretching
                      The bug was due to an unvolontary Undo, but the make Unique remained, so that it works fine the second time.
                        penumbra
                        Thanks fredo.
                        • fredo6F Offline
                          NEW RELEASE: FredoScale v3.0a - 14 Jan 17
                          FredoScale 3.0a is a maintenance release providing corrections to previous versions, and should be installed for all SU Versions.
                          • gudio83G Offline
                            gudio83
                            Any idea how to resolve this bug?
                            SU2017 x64, Win10
                              What bug? Your screen shot doesn't clearly indicate a problem.
                              • gudio83G Offline
                                gudio83
                                the menu bar is small and i can't resize it. I must scroll every time to see all options / results.
                                This bug appear only on "Labels with areas". The same problem on my PC and my laptop.
                                  So this has nothing to do with FredoScale.
                                  • fredo6F Offline
                                    SU2017 x64, Win10
                                    SU2017 has changed a few things in the dimensioning of web dialogs.
                                    Normally, you should be able to resize and adjust the size, which would be kept for the next use.
                                    I just have one doubt: not sure I released the fix in FredoTools 3.0a (i.e. the capability to resize the dialog box).
                                    • E Offline
                                      elfis
                                      First of all that you for the best plugin in sketchup. Enginsh is not my native language so I record this short clip to explain my problem.
                                      When I copy group of objects and start to stretching one of them I'm getting this conflict.
                                      I know there is problem with components when they all not unique but why with groups ?
                                      It was fine before format of windows with different versions of plugin.
                                      For now i'm using Sketchup 2016 and latest plugin with libs.
                                      Kind Regards
                                      Patrick
                                      ps. Sorry if this is noob question.
                                      • fredo6F Offline
                                        In Sketchup, a group just copied behaves like Components...
                                        ...unless you just edit (i.e. double click) the group you copied.
                                        This is probably for optimization.
                                        • E Offline
                                          elfis
                                          Hi, thanks for the answer . Before I have never have this problem, I found small fix on this "model" by removing group of objects inside this group.
                                          Group Tree
                                          • array81A Offline
                                            array81
                                            I installed the last version but I have only the "box" tools, no "target" tools. Any ideas?
                                            • 56
                                            • 57
                                            • 7 / 57
