    [Plugin] SectionCutFace
    569 Posts 171 Posters 505.5k Views 170 Watching
    • I Offline
      ifresia
      Hi TIG,
      Great plugin, but I have a question. I'm trying to couple sectioncutface with the keyframe animation plugin, essentially to animate a section cut in perspective through a building model, except by animating the building to move through the section plane, keeping the plane and camera in the same spot. Is it possible to have sectioncutface update real-time as the animation is played?
      Isaac
      • bmikeB Offline
        bmike
        TIG -
        When I create a scene with the SCF plugin the layer I have added the section to is now on in the current scene as well as the new scene... is this a bug or a feature? I would expect that the current scene would not be affected by anything happening when I choose 'New Scene'
        I'm also getting bug splats every couple of times I run the plugin. I have sent off the bug slats, not sure where I can access them to show you what is going on.
        Last bugs plat submitted was Crash Report #7925
        • bmikeB Offline
          bmike
          Video of layer activating on existing scene:
          • bmikeB Offline
            bmike
            Submitted multiple more bug splats, the latest was Crash Report #7933
            • bmikeB Offline
              bmike
              Crash Report #7935
              • bmikeB Offline
                bmike
                OK - I think I have isolated the issue, am testing now.
                If I run the plugin to create a new scene from a scene that uses a style where 'Section Planes' has not been updated or refreshed - SU crashes.
                Done this twice now in a row. Will test more.
                If I run the plugin in a scene with a style that I have not altered (like turned the section planes on so I can see them, to create the new cut) - then it works consistently.
                  A guaranteed way to Splat is to Remake Section when you section is hiding all content.
                  • bmikeB Offline
                    bmike
                    OK - This appears to be the case - if any change is made to the style of the current scene (like turn section planes on or off) - if you don't refresh the style when SectionCutFace tries to make a new scene it crashes.
                    I have tested this by altering edges, not refreshing and getting a crash, as well as only toggling the Section Plane on and off (for visibility) - and it crashes if I do not update the style before running the plugin.
                    • bmikeB Offline
                      bmike
                      I'm trying to make new...
                      See below - I think I have isolated what is happening - its related to styles...
                        Can we keep the posts on this in the one place - here...
                        Having other posts at SketchUp.com is confusing - although their team's comments on your BugSplats might be helpful...
                        Can you provide a simple model with Styles etc that shows this behavior...
                        ZIP it and PM if you don't want it 'public'...
                        If it's too big to attach use a file sharing site and PM me a link...
                        Also some step by step instructions on how to make the splats would be most helpful...
                        • bmikeB Offline
                          bmike
                          I can... later today.
                          2 issues that I have posted about -
                            • Is the layer behavior a bug or feature?
                          Video:
                          https://youtu.be/v9GZJrM7Jvo
                          I am getting the layer turned on in the scene I start from, when I believe it should only be on in the new scene that SCF creates.
                          1. the crashes - it crashes just with 2 boxes on the screen, and I believe this is connected to having a new scene created that is using a style that has been altered, but not refreshed.
                            Here's v6.1 http://sketchucation.com/pluginstore?pln=SectionCutFace
                            New FR strings file added [thanks to @mariocha].
                            Re-signed for full v2017 compatibility.
                            Haven't yet got to the bottom of the @bmike reported issues.
                            Watch this space...
                            • V Offline
                              victor hugo
                              TIG.
                              I upgraded SectionCutFace using extension store, the previous version was working fine and with this upgrade to 6.1 when I want to create a section I don't get the prameters window.
                              Any clues why this doe not appear.
                                I see this too - most perplexing...
                                COMPO seems to be mistranslated in the strings file...
                                Bear with me...
                                  Thanks for the error report...
                                  Here's v6.2 http://sketchucation.com/pluginstore?pln=SectionCutFace
                                  The glitch with the COMP constant - i.e the incrementing SCUT name in all strings has been fixed.
                                    mcmillancabinet
                                    I just installed SectionCutFace. I get the context menu "Add SectionCut Face" but right-clicking it does nothing, other than closing the context menu. There is no dialog box to specify the paramenters, and no section cut face is generated.
                                    After right-clicking, the following is added to the Ruby console:
                                    Error: #<NameError: uninitialized constant TIG::SectionCutFace::COMPO>
                                    c:/users/dave/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/sectioncutface/sectioncutface_code.rbs:1030:in dialog' c:/users/dave/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/sectioncutface/sectioncutface_code.rbs:96:in new'
                                    c:/users/dave/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/sectioncutface/sectioncutface_start.rbs:61:in block (2 levels) in <module:SectionCutFace>' SketchUp:1:in call'
                                    Other info: I am running Pro 17.1.174 64-bit on Windows 7. The plugin was installed using the Sketchucation ExtensionStore interface.
                                      You're not supposed to right click on Add SectionCut Face. You're supposed to left click on it.
                                        Irrespective of that... did you download/install the latest update v6.2 ?
                                        http://sketchucation.com/forums/viewtopic.php?p=613140#p613140
                                        It fixes this issue...
                                        It was posted in within the last hour or so...
                                        I expect your download and problem overlapped with this update...
                                          mcmillancabinet
                                          Sorry, Dave R, I worded that poorly. I don't right-click the context menu item. Rather, I right-click the section cut to bring up the context menu, from which I left-click the "Add SectionCut Face" item.
                                          Thank you, TIG. The version is 6.1. I must have just missed 6.2. However, the "Update" button for Add SectionCut Face in Extension Manager is inactive. I will try uninstalling and reinstalling.
                                            The Update button in SketchUp's Extension only applies to Extension Warehouse installs. You need to update using our ExtensionStore in SketchUcation Tools v3
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 25 / 29
