    Scaling Materials
    17 Posts 6 Posters 12.4k Views 6 Watching
      Mike211248
      How do I create new materials in SketchUp from textures downloaded from the web and scale them correctly, so that I do not have to continually scale them once applied.
      I only draw in 1:1 scale in Sketchup and would like to create the materials so that they are at this scale.
      I know that I did it years ago for roof tiles in SketchUp 5 or 6 but cannot remember how I did it.
      I am currently using SketchUp 2015.
      Mike211248
        Adjust the size of the material in the Materials Browser...
        Click to play gif...
          Mike211248
          Thank you Rich. I knew I'd done it before, just couldn't remember how.
            I avoid needing to adjust the size of textures I create by making them the right size to begin with. I draw a rectangle with at least one dimension matching a known dimension in the texture. Then I import the image as a texture and apply it to the rectangle. Starting in the lower left corner of the rectangle, I drag the material out and click on the far edge at the known distance. For example, if I have a wood grain texture that is 12 feet long, I make a rectangle that is 12 feet long. The width can be whatever because the texture takes care of that automatically.
            Usually when I am making wood grain textures, I make 3 or more of the same species from the same log. I just make as many rectangles as I have texture images.
              Mike211248
              Hi Dave.
              That is what I have done with all my existing textures. The problem was that the last time I made textures was when I was using either SketchUp 5 or 6 when I first started using SketchUp. I have not had the necessity to make new textures until now and could not remember what the procedure was.
              I also do not like having to constantly adjust the textures to suit the drawing, beside having to adjust the register on the texture for starting points or the lining up of tiles on a roof surface.
              Regards
              Mike
                Regards
                Mike
                You shouldn't have to adjust the size of the texture after you've set it the first time. Are you saving the textures to a library before setting their dimensions?
                  Mike211248
                  Hi Dave
                  I was, that's why I asked for help in scaling. Now that I have been reminded how to do it,
                  I have gone into all the new textures that I had created (about 10) scaled them and saved them.
                  Regards
                  Mike
                    Excellent!
                      Mike211248
                      Hi Dave
                      Off Topic.
                      I first joined the SketchUcation forum on 17.04.2008. Since then my service provider changed and I forgot my login and password, hadn't needed to login for a long, long time.
                      How do I correct my details. I have just found the original email with my login and password. Originally registered as Mike Backler on planpro@iburst.co.za. Been using SketchUp since 2001/2, the earliest reference that I can find is the SketchUpDate newsletter of March 2003. My email records do not go back any further.
                      Regards
                      Mike
                        Mike, do you want to go back to using the "Mike Backler" username? If so, I think you should just be able to log in with that one instead. I don't think I can do anything to your current profile to make it look like your old one but maybe Rich can do so.
                          I sent you an email Mike with login details for your old account.
                            Mike Backler
                            Hi Rich
                            Thanks, I will login with the old Username from now on.
                            Regards
                            Mike
                            • jujuJ Offline
                              juju
                              yaaaiiieeee!!! Another compatriot! Wanneer gaan ons braai, Mike?! πŸ˜›
                                Mike Backler
                                Hi Juju
                                Ek het gebraai gister aandt. Ons kan braai die volgende keer ek kom na Kaap Stad Juju.
                                Mike
                                • SJS66S Offline
                                  SJS66
                                  Where are the image files used for SU materials stored? Actually, I've managed to delete one of my Water Materials (rocky stream bottom one). Where can download original SU material files?
                                    You should find the OEM materials in C:/Program Data/SketchUp/SketchUp2017/SketchUp/Materials. If you are still using SketchUp 2016I as your profile indicates the materials will be in C:/Program Files/SketchUp/SketchUp 2016/Materials.
                                    SU2016
                                    If you deleted one of them, though, you can replace it. You could do that by reinstalling SketchUp or by getting the SKM file from someone else. Which one is it that you are missing? I could upload it.
                                    You will probably need to change permissions for the appropriate location to be able to add to the folder.
                                    • SJS66S Offline
                                      SJS66
                                      pcmoor was kind enough to post up the water material files for me on SketchUp Community Forum. See link below.
                                      https://forums.sketchup.com/t/su-material-image-location/42204/2
