    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 959.4k Views 172 Watching
      Sjamon
      Dear Anton,
      I just downloaded the plugin to make a simple cinematic / collision check on a folding workbench model, that is basically a deformable parallelogram.
      Although I got the basic principle and manage to make singles hinges move as expected, any component is stuck as soon as it's linked to two hinges.
      There's also a message reading "Requires MSPhysics 0.9.8+" in a corner of the screen, should I understand that it won't work unless I install something else ?
      Armand
        Anton_S
        Hi, Armand,
        A hinge with no parent groups will act stationary. In order for the hinge to move, it must have a parent group. What I think is going on in your model is that the hinges are top level groups. If you want a hinge to link two groups together, and still move, simply create a hinge joint within one of the groups andd then, using the joint connection tool, connect it to the other group. That way the hinge joint will have a parent body, which will allow it to move.
        Check out this mini clip:
        Movable Joints Example
        The message is there so that people using your model would know that they need MSPhysics in order to run it.
        Regards,
        Anton
        • gillesG Offline
          gilles
          I think I have some issue with hinge when I link it to a parent:
          Mac OSX 10.8.5, SU2015.
            Anton_S
            Hi, gilles,
            To fix that, you have to select the joint, open MSPhysics UI, and check the "connected collide" option.
            Regards,
            Anton
            • robintR Offline
              robint
              @anton_s said:
              Hi, Robin,
              I'm glad I could help.
              Best regards,
              Anton
              I made a simple mass/spring damper system as per model, but I get some odd results not like the damped sinusoid
              Am I on the right track or have I made some basic errors
              Also the block doesn't sit still on the plane but wanders off
              I am also having difficulty tying in the UI with real values of spring rate N/m and damping c*velocity Ns/m
              Any advice, most appreciated
              Cheers
              Robin
              BTW I looked at the Ruby docs but couldnt tie up real units to the constants
              classic spring damper
              As one door closes another one slams in your face
              • gillesG Offline
                gilles
                @anton_s said:
                Hi, gilles,
                Regards,
                Anton
                Works fine ๐Ÿ‘
                A lot to dig in, I go back to the mine.
                  Anton_S
                  Hi, Robin,
                  The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
                  I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
                  Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
                  Anton
                  • robintR Offline
                    robint
                    Hi Anton
                    I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
                    cheers Robin
                    • robintR Offline
                      robint
                      @anton_s said:
                      Hi, Robin,
                      Anton
                      Yes indeed, improved action, I missed the friction box
                      Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
                      spring stiff 1 (what does this do?)
                      Accel 1, damp 1.5 (gives critical damping approx)
                      changing sample rate from 1/60 to 1/240 changes the whole model performance
                      iterations 16 - improves stability
                      the plane has a mass of 0.01kg, lowest i could get without instability
                      So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
                      What do you think? Anything I can do to help (ruby dummy just now)
                      Cheers
                      Robin) ๐Ÿ˜›
                      V 2
                        Anton_S
                        Hi, Robin,
                        I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
                        Regards,
                        Anton
                        • robintR Offline
                          robint
                          @anton_s said:
                          Hi, Robin,
                          Regards,
                          Anton
                          Hi Anton
                          It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
                          BTW just seen some example in Sketchucation, blown away with the talent out there
                          Hope my little exercises aren' t too dull
                          Cheers
                          Robin
                          • gillesG Offline
                            gilles
                            What am I doing wrong?
                            THEO-JANSEN2.skp
                              Anton_S
                              Hi, gilles,
                              You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
                              Anton
                              • gillesG Offline
                                gilles
                                Thanks Anton,
                                Very nice tool you made there.
                                THEO.skp
                                  Anton_S
                                  Very clever, gilles!
                                  I'm sure there is a way to improve performance and stiffness of that thing.
                                  Anton
                                  • gillesG Offline
                                    gilles
                                    Thรฉo Jansen.
                                    http://www.strandbeest.com/index.php ๐Ÿ‘
                                      The peaceful robots! ๐Ÿ˜Ž
                                      • gillesG Offline
                                        gilles
                                        I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                                        Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                                        Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                                        Just for anybody else having the same troubles.
                                          Anton_S
                                          Yeah, I'm working on that. Thanks for the report, gilles!
                                          • robintR Offline
                                            robint
                                            [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                                            Hi gilles
                                            I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                                            kinda convoluted
                                            Robin
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 44 / 47
