    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 959.0k Views 172 Watching
    • robintR Offline
      robint
      Thank you so much Anton, thats given me some homework!
      BTW I didn't wish to imply you were overwriting the previous SP. MSP is of course entirely yours started from scratch - brilliant stuff
      I'll be glad to pass any useful models I can generate back to you to pass around to other interested parties and perhaps help generate other instructional models
      Cheers
      Robin
      As one door closes another one slams in your face
        Anton_S
        Hi, Robin,
        I'm glad I could help.
        Best regards,
        Anton
          Sjamon
          Dear Anton,
          I just downloaded the plugin to make a simple cinematic / collision check on a folding workbench model, that is basically a deformable parallelogram.
          Although I got the basic principle and manage to make singles hinges move as expected, any component is stuck as soon as it's linked to two hinges.
          There's also a message reading "Requires MSPhysics 0.9.8+" in a corner of the screen, should I understand that it won't work unless I install something else ?
          Armand
            Anton_S
            Hi, Armand,
            A hinge with no parent groups will act stationary. In order for the hinge to move, it must have a parent group. What I think is going on in your model is that the hinges are top level groups. If you want a hinge to link two groups together, and still move, simply create a hinge joint within one of the groups andd then, using the joint connection tool, connect it to the other group. That way the hinge joint will have a parent body, which will allow it to move.
            Check out this mini clip:
            Movable Joints Example
            The message is there so that people using your model would know that they need MSPhysics in order to run it.
            Regards,
            Anton
            • gillesG Offline
              gilles
              I think I have some issue with hinge when I link it to a parent:
              Mac OSX 10.8.5, SU2015.
                Anton_S
                Hi, gilles,
                To fix that, you have to select the joint, open MSPhysics UI, and check the "connected collide" option.
                Regards,
                Anton
                • robintR Offline
                  robint
                  @anton_s said:
                  Hi, Robin,
                  Best regards,
                  Anton
                  I made a simple mass/spring damper system as per model, but I get some odd results not like the damped sinusoid
                  Am I on the right track or have I made some basic errors
                  Also the block doesn't sit still on the plane but wanders off
                  I am also having difficulty tying in the UI with real values of spring rate N/m and damping c*velocity Ns/m
                  Any advice, most appreciated
                  Cheers
                  Robin
                  BTW I looked at the Ruby docs but couldnt tie up real units to the constants
                  classic spring damper
                  • gillesG Offline
                    gilles
                    @anton_s said:
                    Hi, gilles,
                    Regards,
                    Anton
                    Works fine ๐Ÿ‘
                    A lot to dig in, I go back to the mine.
                      Anton_S
                      Hi, Robin,
                      The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
                      I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
                      Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
                      Anton
                      • robintR Offline
                        robint
                        Hi Anton
                        I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
                        cheers Robin
                        • robintR Offline
                          robint
                          @anton_s said:
                          Hi, Robin,
                          Anton
                          Yes indeed, improved action, I missed the friction box
                          Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
                          spring stiff 1 (what does this do?)
                          Accel 1, damp 1.5 (gives critical damping approx)
                          changing sample rate from 1/60 to 1/240 changes the whole model performance
                          iterations 16 - improves stability
                          the plane has a mass of 0.01kg, lowest i could get without instability
                          So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
                          What do you think? Anything I can do to help (ruby dummy just now)
                          Cheers
                          Robin) ๐Ÿ˜›
                          V 2
                            Anton_S
                            Hi, Robin,
                            I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
                            Regards,
                            Anton
                            • robintR Offline
                              robint
                              @anton_s said:
                              Hi, Robin,
                              Regards,
                              Anton
                              Hi Anton
                              It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
                              BTW just seen some example in Sketchucation, blown away with the talent out there
                              Hope my little exercises aren' t too dull
                              Cheers
                              Robin
                              • gillesG Offline
                                gilles
                                What am I doing wrong?
                                THEO-JANSEN2.skp
                                  Anton_S
                                  Hi, gilles,
                                  You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
                                  Anton
                                  • gillesG Offline
                                    gilles
                                    Thanks Anton,
                                    Very nice tool you made there.
                                    THEO.skp
                                      Anton_S
                                      Very clever, gilles!
                                      I'm sure there is a way to improve performance and stiffness of that thing.
                                      Anton
                                      • gillesG Offline
                                        gilles
                                        Thรฉo Jansen.
                                        http://www.strandbeest.com/index.php ๐Ÿ‘
                                          The peaceful robots! ๐Ÿ˜Ž
                                          • gillesG Offline
                                            gilles
                                            I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                                            Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                                            Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                                            Just for anybody else having the same troubles.
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 46
                                            • 47
                                            • 41 / 47
