    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      @Juju
      I think you are probably correct on this, most architects/designers would like to have the plugin just auto size the plates.
      What I think I will do is add in one more option in the global settings which allows one to toggle the plate sizing to either auto or manual.
      If auto is selected I will create a basic algorithm that looks at the truss span, truss pitch and depth of the TC, BC and webs and then sizes the plates accordingly. I already have such an algorithm built into my Truss Designer here:
      404 - File or directory not found.
      (design.medeek.com)
      If manual is selected I will have an additional html input screen appear that shows the location and size of each plate as well as the outline of the truss. The input will look similar to this:
      http://design.medeek.com/resources/images/truss_su125_800.jpg
      As each plate is adjusted it will immediately change in size showing exactly the configuration of the truss with its connector plates. This involve quite a bit more coding however once I create one such html input, creating more will not be such a big deal. Each plate will be labeled P1, P2, P3 etc...
      The only question now is how to handle the gable end trusses. I think for now I will auto-size the plates on them using the same heel and peak plate sizes as the common trusses. For the the vertical studs I can use an algorithm that looks at stud length and then chooses either a 1.5x3 or 2x4 plate for connection to the top and bottom chords.
      Adding connector plates adds a whole new level of complexity, but there have been enough requests for it that I think it is a valid endeavor. After all this is the "Truss Plugin" and I might as well get the trusses right.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        As an interesting side note, one can turn off the truss layer and then measure the volume of the steel plates which yields 113.85 in[sup:1ft9va6p]3[/sup:1ft9va6p]. Multiply this by 0.284 for mild steel and you end up with a total weight of 32.3 lbs. That is actually quite a bit of steel plates in this rather small truss package. No wonder the truss plate manufacturers like Mitek make so much money on the sale of truss plates, the volume of steel is definitely there (194 plates).
        The weight of the wood can just as easily be computed, making an assumption on the wood species (G, specific gravity of the wood), and moisture content (typically 19% at dry service conditions).
        The appropriate equation to use for the density of wood can be found in the AWC NDS:
        (design.medeek.com)
        For DF No. 2 the density would be 34.2 lbs/ft[sup:1ft9va6p]3[/sup:1ft9va6p]
        The volume of the wood is 22.06 ft[sup:1ft9va6p]3[/sup:1ft9va6p], multipled by 34.2 lbs/ft[sup:1ft9va6p]3[/sup:1ft9va6p] yields a total weight of the wood at 754.5 lbs. Steel plus Wood = 786.8 lbs.
        It may be useful to provide weight information at both the truss component level and the entire truss assembly, wood, steel and total weight.
        design.medeek.com
        • medeekM
          medeek
          Enabled connector plates for the common gable truss:
          http://design.medeek.com/resources/images/truss_su163_800.jpg
          There gets to be quite a bit of geometry when you start modeling all of the plates (194), especially the gable trusses with all of their vertical studs.
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          design.medeek.com
          • medeekM
            medeek
            Enabled metal plate connectors for the 4/4 and 6/4 scissor trusses:
            http://design.medeek.com/resources/images/truss_su164_800.jpg
            Each truss type and configuration needs its own special function to locate and auto-size each plate. The code required is not difficult since most of it can be recycled but it is still time consuming to generate for each and every truss type with all of the many possible configurations. I have not even considered raised heel trusses yet. At some locations (ie. heel plates on a scissor truss) the truss configuration may cause the plate to fall outside of the perimeter of the truss in this case some additional logic is required to check for these instances.
            View model here:
            3D Warehouse
            I should probably attack the attic truss next, that one will be fun. πŸ˜„
            design.medeek.com
            • sfto1S
              sfto1
              πŸ‘ There is always interest for your work
                MtnArch
                I work with a contractor who normally builds spec homes, and he LOVES exposed heavy beams and trusses - I vote yes!!
                Highest Regards,
                Alan T. Hendry, RA
                Architect
                • facerF
                  facer
                  Medeek,
                  Good to see you are getting into the "nuts and bolts" of trusses. πŸ˜„
                  Suggestions:
                  Most structural items will require "computations and sign off" by a registered
                  Engineer here in Australia and NZ.
                  I would suggest having a "simple truss or hide detail" option that will just show the
                  design intent.
                  Hence:
                  1. The architectural designer can show just the "simple layout" for design development.
                  2. The architectural designer can then show "detail where required" as in design development and final sign off with the client and relevant consultants.
                  More Graphics Please
                  Where possible add symbols and graphics to aid the user in data input.
                  Also, suggest breaking up data input into logical "sets" or "common areas for easier input"
                  At present your "data input menus" are a long list of items that does not suggest
                  on first viewing the "logic for data entry".
                  Keep up the good work and have a great Xmas-New Year.
                  • medeekM
                    medeek
                    @facer
                    I agree, the major limitation with the simple UI menu offered with SketchUp API is the inability to add additional text or other user aids. Ultimately I need to switch all of these menus to html so that I can further customize them and add in visuals, graphics, help text and help popups.
                    If you look at my snow load calculator at this link you will see how I use help popups to try and explain each term:
                    (design.medeek.com)
                    With the gambrel attic roof truss the html menu includes a 2D preview screen which helps the user visualize the changes to the overhang, pitches, member sizes etc... before they hit the "go" button. I think this is the best direction to go with all of the truss types.
                    Even if you know what all of the various menu items are the long list format without any sort of visual aid is a bit overwhelming.
                    I completely agree with your assessment on the user interface.
                    With regards to a simplified version version the more complex structural detail I'm not sure if you are referring to all of the plugin or just to the timber truss module I am proposing to add.
                    With timber trusses I will create an html menu from the get go so that the user can experiment with the various settings to develop the "look" they want before committing. This will be similar to the gambrel truss html menu with a preview screen showing the truss in 2D using html, javascript and SVG. Even though the layout and number of bolts may be structural elements they are also a big part of the architectural look and feel of the assembly so I would argue that these details are something any designer would probably like to show. Perhaps the ability to go back in and easily edit the truss without having to recreate it would be a big help in this regard.
                    design.medeek.com
                    • medeekM
                      medeek
                      Timber trusses would generally take one of two configurations: King Post or Queen Post.
                      User defined variables would be chord and web timber sizes, pitch, span, overhang. Other options would be:
                      • Number of rows of bolts.
                      • Number of bolts per row.
                      • Bolts spacing.
                      • Connector plate thickness
                      • Bolts size: 1/4", 3/8", 7/16", 1/2", 5/8", 3/4" or metric sizes. M12, M14, M16 etc...
                      • Washers
                      • plate inset/offset from edge of members measured in inches or millimeters.
                      The actual 2D profile of the plates is where the design may vary between one designer to the next. I will probably have one other option call "configuration" (ie. A, B, C etc...) which will allow the designer to quickly toggle between different design configurations and choose the layout they like best.
                      design.medeek.com
                      • facerF
                        facer
                        Re your "To Do List" NUMBER ONE PRIORITY ITEM:
                        TAKE A BREAK AND ENJOY XMAS-NEW YEAR PERIOD πŸ˜„
                        • medeekM
                          medeek
                          The current TODO list:
                          1. Hip Sets (Stepdown, California, Midwest, Northeast, Terminal) with and without drop-in purlin frames as applicable. Hip truss algorithm per June 15, 2016 post.
                          2. Flat Trusses with html input.
                          3. Barrel Vault, Clerestory, Studio Vault, and Double Inverted trusses.
                          4. Html menus for each truss type.
                          5. Update the manual and create more video tutorials.
                          6. Extend connector plates and layers to each truss and roof type.
                          7. Open Joist Floor Trusses.
                          8. Polygon entry for floor trusses/joists versus currently available rectangular assemblies, also add in a function to cut a hole in the floor for a stair way or other opening. See Jul. 2, 2016 post.
                          9. Dutch and Half Hip truss sets (See Jun. 14, 2016 post).
                          10. Gable roof with solid sawn beam.
                          11. Gable roof with "two" glulam or solid sawn beams. (cantilevered rafters).
                          12. Html menu for each truss type for manual connector plate sizing.
                          13. Add the roof to the gable dormer, see June 19, 2016 post.
                          14. Hip and Shed Dormer.
                          15. Gable, Hip and Dutch Gable Roof Minor.
                          16. Engineering for Rafters, Joists and Sheathing.
                          17. Bring the truss and beam engineering into the plugin versus an external link to my engineering site. This would require porting all of my Perl code into Ruby.
                          18. Add a dual pitch gable rafter roof.
                          19. Add raised heels to each truss type that currently does not have this feature.
                          20. Finish adding bird blocking option.
                          21. PDF or HTML output (printable) showing details of a truss assembly (ie. shop drawings and layout)
                          22. Update order system allowing $20 yearly license renewal.
                          23. Further investigate materials (colors) for specific layers.
                          24. Allow "editing" of a truss, floor or roof assembly.
                          25. Timber trusses (with bolted plates).
                          26. Complex hip roofs, this is related to roof minors (item 15). Need to devise a straight skeleton algorithm.
                          27. Integrate more tightly with other plugins as opportunity arises (ie. Estimator etc...)
                          28. Gable end trusses for gambrel attic and attic trusses.
                          29. Complete all configurations of each truss type and verify that each advanced option is correctly working (ie. polynesian truss needs more configurations).
                          30. Add gable and full returns to the roof return option, currently only the hip return is available.
                          31. Transition trusses.
                          32. The Trim function seems to be working now I need to work on the Extend function.
                          33. Steel and hybrid steel floor trusses.
                          34. Explore adding in a stairway module and deck module, however these may become part of the upcoming Wall Plugin.
                          35. In the advanced options for gambrel attic trusses create an option for a crow's beak, see June 20, 2016 post.
                          I know I'm missing a few items that I have on one of my paper lists but I can't find it right now.
                          The question is, other than item 1, what are the highest priority items on this list?
                          I've been basically sidelined since end of August so I am anxious to get this operation (neck) done with and over and really begin again in earnest to advance the development of the plugin.
                          My new job keeps me busy but not so busy that I can't spend a few hours each night plugging away at this list and weekends are certainly my friend in that regard.
                          Please feel free to let me know what other items should be added to the list.
                          design.medeek.com
                          • medeekM
                            medeek
                            When it comes to plates and connectors there is also the bolted plate connected trusses with larger timber members used for more architectural and ornamental work. I am wondering if there is any interest in having a separate module for those truss types?
                            Something along these lines:
                            http://deadlinesengineering.com/wp-content/uploads/2013/10/heavy timber trusses.jpg
                            http://cdn.shopify.com/s/files/1/0432/5985/t/2/assets/slideshow_2.jpg?3062143040596805956
                            http://www.forestryforum.com/gallery/albums/userpics/12957/Pict0309a.jpg
                            Look at this beautiful double howe truss:
                            http://www.americanpoleandtimber.com/wp-content/uploads/2015/07/70_ft_timber_truss_close-up-BIG.jpg
                            Half Bowstring Truss?
                            http://huskytimber.com/wp-content/uploads/2014/10/PICT0034.jpg
                            design.medeek.com
                            • jujuJ
                              juju
                              @medeek said:
                              1. Update order system allowing $20 yearly license renewal.
                              I would place that at number 1, it's a bit confusing and may be a deterrent for returning customers. Currently I now have 2no. licences (1no. which is now out of date) where I only need one, the second license should be the first that has been renewed + 6 months added to the current expiry date, which is still at a year after purchase of the "renewal". Not serious I suppose, just a pet peeve.
                              Apart from that, the continuous development is appreciated, but be sure to take an adequate break though...
                              • medeekM
                                medeek
                                @Juju
                                I concur, after work today I will dive back into my shopping cart code and see if I can't add the renewal code by tonight. The nice thing is that I already have a similar system in place for renewals on my API service. I just need to figure out what I did for that service about two years ago and replicate it for the two plugins.
                                Under the purchase new license will be the renewal button:
                                http://design.medeek.com/images/renew_plugin.png
                                I've updated your renewal expiration date in the database as I promised. I apologize for the delay on this.
                                If anyone else has purchased a new license in an attempt to renew their license in the last 2 or 3 months, please email me and I will extend your renewal expiration by another 6 months.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Pre-Op tomorrow and then operation on Thursday.
                                  Timber Truss icon for the Graphical Truss Menu:
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    @medeek said:
                                    Version 1.7.1 - 12.08.2016
                                    • Enabled metal plate connectors for the common fink truss.
                                    I enabled the connector plates in the settings, but it doesn't show up when the trusses are generated. I'm using version 1.7.1. I also noticed that the splash screen with all the various truss types icons seem to be different (window not resizing / icons running off of the page) to before I enabled the connector plates in the same version?
                                    ++++ EDIT ++++
                                    OK, it seems to be working now, I double checked the settings, assigned user defined layers and saved them again. It seems to be working now. The battens are not being assigned to a layer other than Layer0?
                                    • EarthMoverE
                                      EarthMover
                                      Those timber trusses are amazing. Perfect actually for a job I'm working on. Thank you for making such a phenomenal plugin!
                                      Content Creator at Skapeup
                                      • medeekM
                                        medeek
                                        @Juju
                                        Thanks for pointing out the non-layer assignment for battens, I will try to jump on that tomorrow, its a quick fix.
                                        The layer implementation is far from complete, I only just started on it and I have numerous files to go through and add the layer logic in so please bear with me.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          I'll see what I can do with the timber trusses, those should be a lot of fun to add in and with a decent html menu with preview screen should be fairly intuitive for the user.
                                          I've updated my database and shopping cart programming so now you should be able to renew your plugin (license) for the $20.00 renewal fee. You always have the option of purchasing multiple licenses at the full price, and the renewal form allows one to pick which serial number they would like to renew if they have multiple licenses.
                                          It took me about 4 hours to make this work, unfortunately the paypal integration complicated things, that was not anticipated. Now my arm is on fire, good thing I'm going into surgery Thursday, I really need it at this point.
                                          Item #22 on the todo list should now be complete. Now I just need to go back into my foundation plugin scripts and database and do the same thing.
                                          design.medeek.com
                                          • jujuJ
                                            juju
                                            @medeek said:
                                            @Juju
                                            No problem, thanks for the work you put into this, it is appreciated and doesn't go unnoticed.
                                            I suggested to the author of "Window+" (on EW) to implement something similar to what you have done with the custom layer assignments, he too thinks it a great idea and will probably implement it soon. Let's hope the idea spreads to more extension authors as it helps to save time when these can be pre-assigned as opposed to having to iterate through the entire model assigning groups / components to layers.
                                            All the best with the surgery tomorrow! Godspeed!
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 76
                                            • 77
                                            • 28 / 77
