    Vray 3.4 Public Beta is Live
    renderpluginsextensions
    28 Posts 19 Posters 11.9k Views 19 Watching
    • V Offline
      vigge50
      @tedvitale_cg said:
      Great video! Please let me know if you have questions about workflows or want to give any feedback about the product. I'll be looking forward to seeing your future posts and videos!
      Also, just some info on Stereo 6:1, you don't have to have a special VR Headset, all you need is an iPhone or Android phone and a google cardboard. I typically use the Scope app (irisvr.com/scope) from iris VR (irisvr.com). You have to sign up for their website, but the rest is free! It's a very simple process. Upload your 6:1 to your user profile page then sign into the scope app and download the image to your mobile device. That's it! Your up and viewing!
      I'd also recommend you turn on Fog in SketchUp and see what happens 😉
      Turn on fog, as the 18432*1536 was heavy enough without it and displacement? 😄
      Really nice function, thanks for integrate it. Have you any plans or tips on programs to link several panoramas together so you can easy swish between panoramas?
      • TedVitale_CGT Offline
        TedVitale_CG
        We should not have any plugin conflicts, but I would be interested in finding out what errors you are running into @chavinskee. Please Post here or PM me with details. I don't like hearing users get that frustrated and I would like to try and track down the issue at hand so it doesn't effect others.
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
          TedVitale_CG
          No plan on creating anything like that but I would go check out IrisVR's Scope App, I think it will be a good start for what you are looking for!
          Ted Vitale
          • chavinskeeC Offline
            chavinskee
            thanks. will try again and see how it goes.
            http://chavinskee.blogspot.com/
              chavinskee
              got this error when opening sketchup 2016:
              Error Loading File C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/vfs.rb
              Error: #<LoadError: cannot load such file -- RubyToPython.so>
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
              C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/vfs.rb:86:in <top (required)>' C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools/core.rb:59:in require'
              C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools/core.rb:59:in block in <module:VRayTools>' C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools/core.rb:56:in each'
              C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools/core.rb:56:in <module:VRayTools>' C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools/core.rb:33:in <top (required)>'
              C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
              C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools.rb:40:in register_extension' C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools.rb:40:in module:VRayTools'
              C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools.rb:15:in <module:Plugins>' C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools.rb:14:in module:TT'
              C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_vray_tools.rb:13:in <top (required)>' Error Loading File vfs.rb Error: #<LoadError: cannot load such file -- RubyToPython.so> C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/vfs.rb:86:in <top (required)>'
              C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/vfs.rb:86:in `<top (required)>'
              • V Offline
                vigge50
                How do you activate fog, have tried to activate it but it don't make any different to the rendering, is there any settings that I have missed?
                • JonFarJ Offline
                  JonFar
                  the new version is great, but I unistalled it because it crashed skup a couple of times
                  I'll wait for the final version
                  Also, it doesnt work with VRay tools 😞
                  one thing I like about VRay tools is that I can open Skup with VRay disabled, and turn it on only when I want to render
                  • omiKronO Offline
                    omiKron
                    I want to add the CarPaint property to a material, and in the Quick Settings panel I get the message to use the Advanced Settings Panel, where is that?
                    For the most part, it's unbelievable how fast it loaded a complicated interior model after hitting render! I barely blinked one time and.. snap! Great job!
                      rogalxxx
                      I am getting errors with SU17 and Beta as well.
                      I just finished a fresh windows 10 x64 install.
                      Installed and registered Sketchup 2017 x64 and tried to install Vray beta x64.
                      When I run SU i get
                      Error: C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                      C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/vfs.rb:22:in <module:VRay>' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/vfs.rb:5:in <top (required)>'
                      I can't find Plugins folder in my SU installation folder. vfs.rb is also missing.
                      Downloaded both apps and reinstalled them. Nothing changed.
                      Here's the command line window during install:
                      7-Zip (a) [64] 15.14 : Copyright (c) 1999-2015 Igor Pavlov : 2015-12-31
                      Scanning the drive for archives:
                      1 file, 51336790 bytes (49 MiB)
                      Extracting archive: C:\Program Files\Chaos Group\V-Ray\V-Ray 3.4 for SketchUp\extension\vrayappsdk\appsdk-win-1.8.3-vray3.40.4-20161026-beta.7z
                      Path = C:\Program Files\Chaos Group\V-Ray\V-Ray 3.4 for SketchUp\extension\vrayappsdk\appsdk-win-1.8.3-vray3.40.4-20161026-beta.7z
                      Type = 7z
                      Physical Size = 51336790
                      Headers Size = 2177
                      Method = LZMA:24
                      Solid = +
                      Blocks = 1
                      Everything is Ok
                      Folders: 1
                      Files: 108
                      Compressed: 51336790
                      Automatic installation was successful!
                      Error loading logtext.dll.
                      *** ServiceExe (startup) 1.0.5 - built 2010-10-01 13:09:35 ***
                      OpenService failed - 'Okreťlona us│uga nie istnieje jako us│uga zainstalowana. (0x424)'
                      Path of executable: C:\Program Files\Chaos Group\V-Ray Swarm
                      Service start type is 'Automatic'.
                      Installing service 'vrswrm-service' as 'V-Ray Swarm'...
                      Service 'V-Ray Swarm' installed.
                      Starting service 'V-Ray Swarm'...
                      Start pending for 'V-Ray Swarm'...
                      Waiting...
                      Waiting...
                      Result of starting service 'V-Ray Swarm': Success.
                      Older vray is not compatible with SU 2017 😞
                      regards
                      • andybotA Offline
                        andybot
                        It's changed now, that you honestly don't need vray tools any more. Vray doesn't mess with the model until you open the asset manager, render, or add vray objects.
                          TedVitale_CG
                          When I run SU i get
                          So sorry you've been running into this. We've made some changes to our installer to resolve this issue and will release an update to the beta. If you email support@chaosgroup.com they can also help fix this directly.
                          Ted Vitale
                            TedVitale_CG
                            On the right and left sides of the UI you have some flyout panels you can open. That's where both the material Library and the advanced parameters live. 2.0 materials are supported and render just the same, but if you have any layered material (reflection, on top of refraction and diffuse) it will default to the advanced panel. I would recommend making a new material in SketchUp and trying out the quick settings. You can change just about anything in the material quick settings. If you need additional help let me know!
                            Ted Vitale
                            • soloS Offline
                              What happens once the beta ends? does the current beta stop working and require a license to activate, or will it keep working but with a watermark?
                                sanjeevkmishra
                                @ TedVitale_CG
                                Just wondering how to increase or decrease material subdivide in vray 3.4 beta. I'm unable to see it in the UI. Pls advise if this has been deleted from the UX or its been integrated with something else. Thnx.
                                Rgds,
                                Sanjeev
                                  anguaa
                                  Same question here. Where can i set subdivs for materials in vray 3.4. Is is possible to do that only globally?
                                    rv1974
                                    V on 'Use local subdivs', but it's a bad practice- the beauty of v.3.4 is ability to control the quality in a globalmanner.
                                    • V Offline
                                      vigge50
                                      That app worked for a month but then the trail version ended they now want $40/month to upload your image wish I think is way to mush, any other tip of apps that you can use or do I just have to except that I need to pay a lot to see my panoramas as VR?
                                      • X Offline
                                        xone
                                        I'm checking out the latest release but I can't find the "Flat Normal" option for VrayFur anywhere... It's been mentioned in Vray documentation under LOD settings but I don't see that option there, why?
                                        • H Offline
                                          humptyhumps
                                          Anyone having problems with V-Ray 3.4 Beta for SketchUp Pro 2016 where the scene does not render or even pop open a frame buffer when render buttons are hit. I have been trying to render a 6:1 Stereoscopic render for use with Google Cardboard. I installed V-Ray 3.4 Beta and the new License Server. I tested it with the opening scene in SketchUp and I can render 6:1 stereo format. However, when I open my SketchUp model and hit the 6:1 render button, or any other render button, it does not work. It doesn't even open the frame buffer window. In the command window at the bottom left of the SketchUp window I can see it initializes the scene but it doesn't get past "V-Ray Bootstrap: Building scene". Any help is appreciated. Thanks.
                                          • I Offline
                                            Isarescu
                                            @humptyhumps: make sure "production render mode" is selected!
