    [Plugin] Add Icons [for all SU files on mac]
    47 Posts 8 Posters 15.5k Views 8 Watching
      sketchuh
      like to donate thru paypal. your add icons plugin works. what is your paypal address. u can pm me. Thanks.
        sketchuh
        i have to resize the sketchup window size to a square , if i want the thumb nail to be square. otherwise, my thumnails are always with red bands. the square button doesn't work.
        also, can you change the red color to white or grey? thanks
          driven
          Hi sketchuh,
          are you still on SU v15 , which version of osx do you run and do you have a retina display?
          I've been doing some more work on this, but it's not quite ready...
          can I PM you some test files?
            sketchuh
            yes john!
            I am using sketchup 2015 on macbook pro retina 2013. and using the latest os system.
              sketchuh
              actually, when chose the batch mode, almost all other sktechup files would have square thumb nails, only one that is opened has red bands if the viewport is not square.
                driven
                if you want to change the red to Finder off white, copy/paste this code into 'Ruby Console' and hit Return...
                it should work without needing a restart of SU...
                filename = Sketchup.find_support_file("jcb_Add_Icon/Add_icon_logic.rb", 'Plugins')
                text = File.read(filename)
                content = text.gsub(/ FF0000 /, " e8e9e8 ")
                File.open(filename, "w") { |file| file << content }
                  sketchuh
                  thanks, the red is changed.
                  just want to confirm do i have to resize the window to square in order to have the thumb nail square?
                    driven
                    Currently, yes, and I don't know why the 'make square' button only works for some people...
                    It may be because of Retina or system/SU language used...
                    I have another way of doing it automatically, which 'batch mode' uses, but need some time to add it in and test...
                      driven
                      Finally SketchUp has added it's own icons for mac with the release of v17...
                      not the same quality [imho] but it's native and I can finally stop updating this plugin....
                        greatoe
                        I've been using your plugin for years, thank you very much, John.
                        It's good that SketchUp can make native icon for mac (again) now but I still prefer yours, which has larger resolution. And I think that 'file' frame in the icons SketchUp produce is useless and screen-landscape-consuming.
                          greatoe
                          Hi driven,
                          This plug-in is not working on macOS 10.15 Catalina. Is there a chance that you would like to make a fix? 😄 😄
                            The latest MAC OS 'Catalina' does not support ANY current SketchUp version.
                            I know that SketchUp is working hard to release a new compatible update for version 2019 asap.
                            BUT no earlier versions will ever be made fully compatible.
                            Some might work, so will not - depending on how you use SketchUp etc.
                            So having an old Plugin updated seems to be the least of your worries !
                            Please complete your User-Profile so we know more details about your setup...
                            • 3 / 3
