    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      You have an accent in your Windows user-name 'Lémony'.
      This has long been taboo !
      It breaks older versions of SketchUp's Ruby completely !!
      However, it should be possible to encode such a string when defining the file-path to avoid these issues - somewhat straightforward with newer Ruby versions - such as yours 'v2016'...
      Perhaps the author needs to reconsider the paths' encoding...
        Anton_S
        What? I thought I fixed that bug... 😕
          Anton_S
          Unfortunately I didn't fix the encoding issue. I thought I did but I didn't. I will work on it soon.
          Thanks for the report, SynSuka3d.
          TIG, thank you for remarking on the issue.
          • C
            cristyan
            Hello Anton ! It give me an error on Sketchup 2013 when presing PLAY.On Sketchup 2016 is runing ok.Thank you !
            • OxerO
              Oxer
              With the last version MSPhysics 0.9.5 & AMS Library 3.4.0 it appears an error message in Ruby Console:
              Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
              Error; #<Exception; An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons;
              - LoadError; dlopen(/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                Referenced from; /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                Reason; image not found - /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
              - LoadError; MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
              /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
              /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
              /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `register_extension'
              /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `<module;MSPhysics>'
              /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
              OSX 10.11.6
              SU 2016
                Anton_S
                SynSuka3d, I fixed the encoding error with non-ascii user names.
                Download version 0.9.6 to get it working.
                Cristian, Oscar you might be getting these errors because you overwritten original versions rather than deleting them.
                It is important that you delete original AMS Library and MSPhysics versions from the plugins folder prior to installing the new ones; otherwise, you'll get nonsense errors. The extension signature tool is not working right. I could not sign my extensions. That's why overwriting original versions will result with errors when using MSPhysics and AMS Library.
                • C
                  cristyan
                  Hello to everyone out there ! and Hello Anton ! It give me an error after program is launched... 2013 and 2016... And on version ...
                  I manually install all the new plugins and I always delete the old ones ...
                  Thank you !
                  2013_MSPhysics_0.9.6_error
                  2016_MSPhysics_0.9.6_error
                  • OxerO
                    Oxer
                    I obtain similar message:
                    Error al cargar archivo /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                    - LoadError; dlopen(/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                      Referenced from; /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                      Reason; image not found - /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
                    - LoadError; MSPhysics library file, "/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
                    OSX 10.11.6 SU2016
                      Anton_S
                      Alright, I'll look into this.
                      • V
                        vico44
                        The 0.9.4 still working well on OS 10.11.6 SU2016
                          JEER
                          Hello Anton!
                          I have installed this plug-in and when started a SU , came a window:
                          Error Loading File C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                          Error: #<Exception: An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons:
                          • Encoding::CompatibilityError: incompatible character encodings: Windows-1250 and UTF-8
                          C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
                          C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
                          C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
                          My SU is 2016 64 bit (16.1.2104)
                          My wsystem WIN10
                            C:/Users/Jen**ő**/...
                            Contains an accented character.
                            The extension's coding was updated to fix the user-path encoding to UTF-8, so do you have the latest version installed ?
                            If so then perhaps Anton needs to make his re-encoding more robust ?
                            • K
                              khturnings
                              Just installed Sketchup Make 2017 and tried to install MSPhysics 0.9.6 and AMS 3.4.0 and got this error ---
                              Error Loading File C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
                              • LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib.so
                              • LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib_no_sdl.so
                              C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in load'
                              C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
                              C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
                                Anton_S
                                That's unfortunate. Looks like I will need to create another account to ensure that the encoding error is actually not fixed.
                                  M3one
                                  I'm want to do a path following object, but I don't really know how. I found on this thread that it's done with curvy joints, but I'm lost. Please, can you explain how or do you have kind of example?
                                    Anton_S
                                    Okay, those loading and encoding issues should be fixed now. Upgrade to 0.9.7.
                                      Anton_S
                                      Hi M3one,
                                      At the moment, you can refer to this tutorial on curvy joints.
                                      https://www.youtube.com/watch?v=dU-KgxKc0ds
                                      You can also check out this example model at 3Dwarehouse.
                                      https://3dwarehouse.sketchup.com/model.html?id=d21984a9-477b-44d7-9eca-c191ae85afe4
                                      Anton
                                        M3one
                                        @anton_s said:
                                        Hi M3one,
                                        Anton
                                        Thanks Anton, I'll check it later
                                        • K
                                          khturnings
                                          Thanks Anton that has sorted the loading issue with Sketchup 2017.
                                          Regards
                                          • T
                                            Taner Batu
                                            Hello, I can't download MSPhysics 0.9.7 plugin from your link!
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 46
                                            • 47
                                            • 23 / 47
