    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 958.2k Views 172 Watching
      Anton_S
      Unfortunately I didn't fix the encoding issue. I thought I did but I didn't. I will work on it soon.
      Thanks for the report, SynSuka3d.
      TIG, thank you for remarking on the issue.
        cristyan
        Hello Anton ! It give me an error on Sketchup 2013 when presing PLAY.On Sketchup 2016 is runing ok.Thank you !
        • OxerO Offline
          Oxer
          With the last version MSPhysics 0.9.5 & AMS Library 3.4.0 it appears an error message in Ruby Console:
          Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
          Error; #<Exception; An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons;
          - LoadError; dlopen(/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
            Referenced from; /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
            Reason; image not found - /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
          - LoadError; MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
          /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
          /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
          /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `register_extension'
          /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `<module;MSPhysics>'
          /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
          OSX 10.11.6
          SU 2016
            Anton_S
            SynSuka3d, I fixed the encoding error with non-ascii user names.
            Download version 0.9.6 to get it working.
            Cristian, Oscar you might be getting these errors because you overwritten original versions rather than deleting them.
            It is important that you delete original AMS Library and MSPhysics versions from the plugins folder prior to installing the new ones; otherwise, you'll get nonsense errors. The extension signature tool is not working right. I could not sign my extensions. That's why overwriting original versions will result with errors when using MSPhysics and AMS Library.
              cristyan
              Hello to everyone out there ! and Hello Anton ! It give me an error after program is launched... 2013 and 2016... And on version ...
              I manually install all the new plugins and I always delete the old ones ...
              Thank you !
              2013_MSPhysics_0.9.6_error
              2016_MSPhysics_0.9.6_error
              • OxerO Offline
                Oxer
                I obtain similar message:
                Error al cargar archivo /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                - LoadError; dlopen(/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                  Referenced from; /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                  Reason; image not found - /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
                - LoadError; MSPhysics library file, "/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
                OSX 10.11.6 SU2016
                  Anton_S
                  Alright, I'll look into this.
                  • V Offline
                    vico44
                    The 0.9.4 still working well on OS 10.11.6 SU2016
                      JEER
                      Hello Anton!
                      I have installed this plug-in and when started a SU , came a window:
                      Error Loading File C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                      Error: #<Exception: An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons:
                      • Encoding::CompatibilityError: incompatible character encodings: Windows-1250 and UTF-8
                      C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
                      C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
                      C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
                      My SU is 2016 64 bit (16.1.2104)
                      My wsystem WIN10
                      • TIGT Online
                        C:/Users/Jen**ő**/...
                        Contains an accented character.
                        The extension's coding was updated to fix the user-path encoding to UTF-8, so do you have the latest version installed ?
                        If so then perhaps Anton needs to make his re-encoding more robust ?
                          khturnings
                          Just installed Sketchup Make 2017 and tried to install MSPhysics 0.9.6 and AMS 3.4.0 and got this error ---
                          Error Loading File C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
                          • LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib.so
                          • LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib_no_sdl.so
                          C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in load'
                          C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
                          C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
                            Anton_S
                            That's unfortunate. Looks like I will need to create another account to ensure that the encoding error is actually not fixed.
                              M3one
                              I'm want to do a path following object, but I don't really know how. I found on this thread that it's done with curvy joints, but I'm lost. Please, can you explain how or do you have kind of example?
                                Anton_S
                                Okay, those loading and encoding issues should be fixed now. Upgrade to 0.9.7.
                                  Anton_S
                                  Hi M3one,
                                  At the moment, you can refer to this tutorial on curvy joints.
                                  https://www.youtube.com/watch?v=dU-KgxKc0ds
                                  You can also check out this example model at 3Dwarehouse.
                                  https://3dwarehouse.sketchup.com/model.html?id=d21984a9-477b-44d7-9eca-c191ae85afe4
                                  Anton
                                    M3one
                                    @anton_s said:
                                    Hi M3one,
                                    Anton
                                    Thanks Anton, I'll check it later
                                      khturnings
                                      Thanks Anton that has sorted the loading issue with Sketchup 2017.
                                      Regards
                                        Taner Batu
                                        Hello, I can't download MSPhysics 0.9.7 plugin from your link!
                                        • E Offline
                                          Emersonvip
                                          First of all thanks for sharing this great plugin
                                          Please I need help. with chains.
                                          • OxerO Offline
                                            Oxer
                                            I installed the last version 0.9.7 and it appears this message:
                                            Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
                                            Error; #<Exception; An exception occurred while loading MSPhysics 0.9.7! The exception occurred due to one or more of the following reasons;
                                            - LoadError; dlopen(/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                                              Referenced from; /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                                              Reason; image not found - /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle
                                            - LoadError; MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib_no_sdl.bundle", is missing!
                                            /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                                            /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                                            /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;90;in `register_extension'
                                            /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;90;in `<module;MSPhysics>'
                                            /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
                                            SU2017 & OSX 10.11.6
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 46
                                            • 47
                                            • 24 / 47
