    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      I suggest you re-install LibFredo6 after cleanup.
      This is strange that you cannot read the RBE
        What version of SU2016 are you using? Do you have the latest update? There was a bug in the original version that caused some loading errors for some users: https://help.sketchup.com/en/article/141303
          topbobster
          Hello Fredo, Can you please confirm if 'clean up' means more than deleting the files/folders from 'plugins' folder because I have done this and re-installed approx 7 times now. thanks. Rob
            topbobster
            Thanks Thom but I only purchased recently and have 16.1.1449 64bit
            Rob
            • fredo6F Offline
              Rob,
              Cleanup means remove both the top file Fredo6_!LibFredo6.rb and folder Fredo6_!LibFredo6.
              Can you verify that the file top_LibFredo6.rbe is 16.6 KB.
              The issue you have is very strange because many users have downloaded v7.2d and I guess installed it with no problem.
                topbobster
                @fredo6 said:
                Rob,
                Hello Fredo, Once again I deleted all LibFredo files and folders and re-installed, same error. The size of top_LibFredo6.rbe is 16.9 KB (17,398 bytes).
                Rob
                • fredo6F Offline
                  Rob,
                  Something strange.
                  You have AdditionalPluginFolders.rb, but not the subfolder.
                  Is it an old version.
                  Anyway, this is not a correct installation.
                  If you don't use the AdditionalPluginFolders features, then I suggest you delete the file.
                    Also the .RBX version of that particular file [which seems to be missing its subfolder] is an 'uninstalled' file [i.e. processed using the SketchUcation Toolset's Uninstaller], so something is adrift here, because that should have replaced the original .RB one when processed...
                    PS:
                    @Fredo
                    Should there be a LibTraductor.rb file in the Plugins folder ?
                    • fredo6F Offline
                      @tig said:
                      @Fredo
                      NO, LibTraductor.rb is no longer used and should be removed, though LibFredo6 arrange to ignore it if present.
                        topbobster
                        PS:
                        @Fredo
                        Hello Tig, all files/folders have been deleted each time I have re-installed. Does deleteing them have a different impact to uninstalling?
                        Regards, Rob
                          topbobster
                          @fredo6 said:
                          Rob,
                          Something strange.
                          Hello Fredo, I tried again. Here's my start point:
                          Then I installed '7.2d' and restarted and got the following message:
                          and checked the plugins folder:
                          I also tried un-installing as TIG mentioned and found the .rbx files. Deleted them and re-installed gain, same error.
                          Regards, Rob
                          • fredo6F Offline
                            Rob,
                            I don't know what you can do more. This looks clean, but for whatever reason, the rbe file cannot be read.
                            So, teh only next steps now are:
                            1. If you can, install Sketchup 2015. in SU2015, this will be the rbs file which will be read
                            2. re-install SU2016 from the original source on Sketchup.com.
                              Also remember that SketchUp must be installed properly.
                              That means selecting the installer's exe icon,
                              then using the right-click > context-menu > Run as administrator...
                              Running the installer by double-clicking the installer's exe will install it,
                              BUT that can often result in unexpected weirdness... that might be the case here.
                              It is NOT sufficient that you have admin-powers as a user, it must be 'Run as administrator'.
                              It's not so painful to correct this...
                              You do NOT need to uninstall SketchUp.
                              First close SketchUp,
                              then you find the installer exe [either the existing in Downloads or perhaps a re-download]
                              and then run its exe as explained above...
                              When prompted choose to 'Repair'.
                              Let it run...
                              This should correct any issues, since it will now be properly installed.
                              Restart SketchUp to see if that approach has helped...
                                topbobster
                                Let it run...
                                TIG, Fredo many thanks for your help. Before I read TIG's last response my intention was to uninstall Sketchup and re-install on my admin account. I un-installed, then saw TIG's message before re-installing so was able to follow his instructions exactly for the install. Then installed Libfredo tested, ok, then installed round corners and tested and it all worked on my admin account. I then logged into my user account and still got the errors.....I believe I read somewhere regarding permissions on user accounts but I installed files before so not sure if it is that, I will try to fiddle around with it on the user account. Anyway I can and am using it successfully on my admin account so am happy to do that.
                                Many thanks to everyone for your time and inclination to help. I look forward to using Fredo's good work and when I have seen the various tools working will surely make a well earned donation.
                                Hope I didn't waste anyone's time. Regards, Rob
                                • fredo6F Offline
                                  Rob,
                                  Glad you finally see the light.
                                  I think it's useful to understand the root cause (permissions on user account) so that we can understand for other users.
                                    topbobster
                                    @fredo6 said:
                                    Rob,
                                    Hello Fredo, Not sure if this throws any light on the subject but here goes....A while back I had trouble with an online storage account and they suggested it could be a corrupt profile. At the time I started to set up a new profile but had trouble copying over files so stopped there and did not use the account, but it was still there. I thought about trying Sketchup on that new profile (no admin rights), to see what happened......I have loaded all plugins succesfully, no issues whatsoever. I have made no changes to permissions on this account although they do seem to be in order:
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v7.2e - 15 Nov 16
                                      LibFredo6 7.2e fixes somemajor issues having a side effect on [b]Curvizard and Curviloft.
                                      See main post of this thread for Download of LibFredo6.
                                        And for 2016 & 2017...
                                        Recommanded also ?
                                        • fredo6F Offline
                                          Recommanded also ?
                                          Yes. LibFredo6 is signed for SU2017 (and SU2016).
                                          My other plugins are not signed yet for SU2017. I will release a signed version progressively. I guess not too many people works in SU2017 with Strict Security!
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v7.2g - 20 Nov 16
                                            LibFredo6 7.2g fixes two **major bug in Animator for:
                                            [list]
                                            []Orbiting (i.e. rotation around another object)
                                            ]Screw, where the movement was simply wrongly calculated
                                            See main post of this thread for [b]Download of LibFredo6**.
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 108
                                            • 109
                                            • 49 / 109
