    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
    • T
      topbobster
      @fredo6 said:
      @topbobster said:
      Hello Dave, thanks for your help but the whole Sketchup8 part was a misunderstanding by me. Whilst trawling the forums for help I saw references to both Google Sketchup8 and '2016' got muself in a bit of a twist, thinking I had not had a version 8, so installed into both they were all new installs to both rather than old files so please ignore that part. Fredo did reply with a 7.2d download but still no luck so have replied to Fredo regarding that. Appreciate your interest. Rob
      From the trace you showed in a previous post, it seems you get a problem loading the top RBE file ("Failed to read RBE/RBS file."), which is something strange, because it is related to the un-scrambling (on which I have no control), not to the Ruby loading. In SU2016, this should not happen (v7.2d was for Sketchup versions < 2014).
      In the Ruby console, could you type the following one-line command:
      Sketchup.require "C:/Users/**User**/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe"
      Note: do not forget to replace < **User**> by your actual username.
      This will try to load the top RBE file. So We can see if you get the message "Failed to read RBE/RBS file.".
      Also, it would help if you could tell me which Windows version you run, and if in 32 or 64 bits.
      Hello Fredo, I did as you asked, in the Ruby console, and got the following message back:
      Sketchup.require "C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe"
      File load error (C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe): Failed to read RBE/RBS file.
      false
      My user name is 'user'. Windows 7, 64 bit.
      Thanks for your help. Rob
      • fredo6F
        I suggest you re-install LibFredo6 after cleanup.
        This is strange that you cannot read the RBE
          What version of SU2016 are you using? Do you have the latest update? There was a bug in the original version that caused some loading errors for some users: https://help.sketchup.com/en/article/141303
          • T
            topbobster
            Hello Fredo, Can you please confirm if 'clean up' means more than deleting the files/folders from 'plugins' folder because I have done this and re-installed approx 7 times now. thanks. Rob
            • T
              topbobster
              Thanks Thom but I only purchased recently and have 16.1.1449 64bit
              Rob
              • fredo6F
                Rob,
                Cleanup means remove both the top file Fredo6_!LibFredo6.rb and folder Fredo6_!LibFredo6.
                Can you verify that the file top_LibFredo6.rbe is 16.6 KB.
                The issue you have is very strange because many users have downloaded v7.2d and I guess installed it with no problem.
                • T
                  topbobster
                  @fredo6 said:
                  Rob,
                  Hello Fredo, Once again I deleted all LibFredo files and folders and re-installed, same error. The size of top_LibFredo6.rbe is 16.9 KB (17,398 bytes).
                  Rob
                  • fredo6F
                    Rob,
                    Something strange.
                    You have AdditionalPluginFolders.rb, but not the subfolder.
                    Is it an old version.
                    Anyway, this is not a correct installation.
                    If you don't use the AdditionalPluginFolders features, then I suggest you delete the file.
                      Also the .RBX version of that particular file [which seems to be missing its subfolder] is an 'uninstalled' file [i.e. processed using the SketchUcation Toolset's Uninstaller], so something is adrift here, because that should have replaced the original .RB one when processed...
                      PS:
                      @Fredo
                      Should there be a LibTraductor.rb file in the Plugins folder ?
                      • fredo6F
                        @tig said:
                        @Fredo
                        NO, LibTraductor.rb is no longer used and should be removed, though LibFredo6 arrange to ignore it if present.
                        • T
                          topbobster
                          PS:
                          @Fredo
                          Hello Tig, all files/folders have been deleted each time I have re-installed. Does deleteing them have a different impact to uninstalling?
                          Regards, Rob
                          • T
                            topbobster
                            @fredo6 said:
                            Rob,
                            Something strange.
                            Hello Fredo, I tried again. Here's my start point:
                            Then I installed '7.2d' and restarted and got the following message:
                            and checked the plugins folder:
                            I also tried un-installing as TIG mentioned and found the .rbx files. Deleted them and re-installed gain, same error.
                            Regards, Rob
                            • fredo6F
                              Rob,
                              I don't know what you can do more. This looks clean, but for whatever reason, the rbe file cannot be read.
                              So, teh only next steps now are:
                              1. If you can, install Sketchup 2015. in SU2015, this will be the rbs file which will be read
                              2. re-install SU2016 from the original source on Sketchup.com.
                                Also remember that SketchUp must be installed properly.
                                That means selecting the installer's exe icon,
                                then using the right-click > context-menu > Run as administrator...
                                Running the installer by double-clicking the installer's exe will install it,
                                BUT that can often result in unexpected weirdness... that might be the case here.
                                It is NOT sufficient that you have admin-powers as a user, it must be 'Run as administrator'.
                                It's not so painful to correct this...
                                You do NOT need to uninstall SketchUp.
                                First close SketchUp,
                                then you find the installer exe [either the existing in Downloads or perhaps a re-download]
                                and then run its exe as explained above...
                                When prompted choose to 'Repair'.
                                Let it run...
                                This should correct any issues, since it will now be properly installed.
                                Restart SketchUp to see if that approach has helped...
                                • T
                                  topbobster
                                  Let it run...
                                  TIG, Fredo many thanks for your help. Before I read TIG's last response my intention was to uninstall Sketchup and re-install on my admin account. I un-installed, then saw TIG's message before re-installing so was able to follow his instructions exactly for the install. Then installed Libfredo tested, ok, then installed round corners and tested and it all worked on my admin account. I then logged into my user account and still got the errors.....I believe I read somewhere regarding permissions on user accounts but I installed files before so not sure if it is that, I will try to fiddle around with it on the user account. Anyway I can and am using it successfully on my admin account so am happy to do that.
                                  Many thanks to everyone for your time and inclination to help. I look forward to using Fredo's good work and when I have seen the various tools working will surely make a well earned donation.
                                  Hope I didn't waste anyone's time. Regards, Rob
                                  • fredo6F
                                    Rob,
                                    Glad you finally see the light.
                                    I think it's useful to understand the root cause (permissions on user account) so that we can understand for other users.
                                    • T
                                      topbobster
                                      @fredo6 said:
                                      Rob,
                                      Hello Fredo, Not sure if this throws any light on the subject but here goes....A while back I had trouble with an online storage account and they suggested it could be a corrupt profile. At the time I started to set up a new profile but had trouble copying over files so stopped there and did not use the account, but it was still there. I thought about trying Sketchup on that new profile (no admin rights), to see what happened......I have loaded all plugins succesfully, no issues whatsoever. I have made no changes to permissions on this account although they do seem to be in order:
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v7.2e - 15 Nov 16
                                        LibFredo6 7.2e fixes somemajor issues having a side effect on [b]Curvizard and Curviloft.
                                        See main post of this thread for Download of LibFredo6.
                                          And for 2016 & 2017...
                                          Recommanded also ?
                                          • fredo6F
                                            Recommanded also ?
                                            Yes. LibFredo6 is signed for SU2017 (and SU2016).
                                            My other plugins are not signed yet for SU2017. I will release a signed version progressively. I guess not too many people works in SU2017 with Strict Security!
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 113
                                            • 114
                                            • 57 / 114
