    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 957.7k Views 172 Watching
    • I Offline
      ITman496
      I have a bug to report, maybe. I've noticed that if you use programmed ratios for things, such as gear reduction, if you leave objects as default (where they can sleep when still) you can cause things to sort of slip, and lose sync with each other. (example: gear teeth phase into each other)
      The only way to stop this seems to be to make them never sleep. Is this behaving as intended?
      I also have a file that causes crashes when I try to make a door work, but it seems to have stopped doing it. I will attempt to re-create the bug and post the file here.
        Anton_S
        Announcing version 0.9.5!
        This version comes with more compatibility with Mac OS X. Now keyboard input and MIDI work on Mac OS X too. Also, a few new features were added, such as another play button, along with plenty of fixes, upgrades, and improvements. Check out the ChangeLog for more information.
          count_olaf
          Hi. Hope you can help as I'm unable to get past an install error on Windows (64 bit machine). I'm using Sketchup Pro 2015 and attempting to install on a device connected to a workplace network which I think is the cause of the problem. I can install it successfully on a separate standalone (at home) laptop. I am installing with network administrator rights.
          Having installed both the ams library v3.4.0 and ms physics v0.9.5 through the sketchucation plugin store button within sketchup, they both give confirmation messages that they have successfully installed. They both appear in the window>preferences>extensions list and are checked. At this point no toolbars are available, so I restart sketchup. I then receive this message...
          Error Loading File C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
          Error: #<Exception: An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons:
          • LoadError: 161: The specified path is invalid. - C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so
          • LoadError: 161: The specified path is invalid. - C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib_no_sdl.so
          F:/Sketchup/Sketchup 2015/Tools/extensions.rb:197:in require' F:/Sketchup/Sketchup 2015/Tools/extensions.rb:197:in load'
          C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
          C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
          All the files and paths listed in the error message are present and correct in those locations. Grateful for any suggestions.
            Anton_S
            Thank you for your insightful report, count_olaf. I will investigate it as soon as possible.
            • F Offline
              faust07
              Update from 9.3 to 9.5 did not work with installation in Extension Store. The old files ams_Lib.hash and MSPhysics.hash are not deleted and old models did not work. Installation per hand by deleting the old directories and copy the new to the plugin folder works...
              The new selection functions are great to test parts of large models - fantastic!!!
                Anton_S
                Oh that explains the issue. I didn't sign the extensions due to technical issues. Why did the plugin packaging had to become more complicated? Really! That's why y'all got errors. Anyway, so, count_olaf, as faust suggested, to fix that you have to delete original versions first and then install the new ones. This process might not be necessary after the extensions will be signed, which I will so shortly.
                  Anton_S
                  Well, I just tried signing my extensions and unfortunately the extension signature tool doesn't work. So, y'all have to do it the hard way for now, that is first delete original AMS Library and MSPhysics versions and then install the new ones in place (do not overwrite).
                    SynSuka3D
                    [LOUDLY CRYING FACE]
                    http://uploads.tapatalk-cdn.com/20161101/e0540bd275bbea6603a2e67caf553448.jpg
                      You have an accent in your Windows user-name 'Lémony'.
                      This has long been taboo !
                      It breaks older versions of SketchUp's Ruby completely !!
                      However, it should be possible to encode such a string when defining the file-path to avoid these issues - somewhat straightforward with newer Ruby versions - such as yours 'v2016'...
                      Perhaps the author needs to reconsider the paths' encoding...
                        Anton_S
                        What? I thought I fixed that bug... 😕
                          Anton_S
                          Unfortunately I didn't fix the encoding issue. I thought I did but I didn't. I will work on it soon.
                          Thanks for the report, SynSuka3d.
                          TIG, thank you for remarking on the issue.
                            cristyan
                            Hello Anton ! It give me an error on Sketchup 2013 when presing PLAY.On Sketchup 2016 is runing ok.Thank you !
                            • OxerO Offline
                              Oxer
                              With the last version MSPhysics 0.9.5 & AMS Library 3.4.0 it appears an error message in Ruby Console:
                              Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                              Error; #<Exception; An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons;
                              - LoadError; dlopen(/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                                Referenced from; /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                                Reason; image not found - /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
                              - LoadError; MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
                              /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                              /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                              /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `register_extension'
                              /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `<module;MSPhysics>'
                              /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
                              OSX 10.11.6
                              SU 2016
                                Anton_S
                                SynSuka3d, I fixed the encoding error with non-ascii user names.
                                Download version 0.9.6 to get it working.
                                Cristian, Oscar you might be getting these errors because you overwritten original versions rather than deleting them.
                                It is important that you delete original AMS Library and MSPhysics versions from the plugins folder prior to installing the new ones; otherwise, you'll get nonsense errors. The extension signature tool is not working right. I could not sign my extensions. That's why overwriting original versions will result with errors when using MSPhysics and AMS Library.
                                  cristyan
                                  Hello to everyone out there ! and Hello Anton ! It give me an error after program is launched... 2013 and 2016... And on version ...
                                  I manually install all the new plugins and I always delete the old ones ...
                                  Thank you !
                                  2013_MSPhysics_0.9.6_error
                                  2016_MSPhysics_0.9.6_error
                                  • OxerO Offline
                                    Oxer
                                    I obtain similar message:
                                    Error al cargar archivo /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                                    - LoadError; dlopen(/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                                      Referenced from; /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                                      Reason; image not found - /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
                                    - LoadError; MSPhysics library file, "/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
                                    OSX 10.11.6 SU2016
                                      Anton_S
                                      Alright, I'll look into this.
                                      • V Offline
                                        vico44
                                        The 0.9.4 still working well on OS 10.11.6 SU2016
                                          JEER
                                          Hello Anton!
                                          I have installed this plug-in and when started a SU , came a window:
                                          Error Loading File C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                                          • Encoding::CompatibilityError: incompatible character encodings: Windows-1250 and UTF-8
                                          C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
                                          C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
                                          C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
                                          My SU is 2016 64 bit (16.1.2104)
                                          My wsystem WIN10
                                            C:/Users/Jen**ő**/...
                                            Contains an accented character.
                                            The extension's coding was updated to fix the user-path encoding to UTF-8, so do you have the latest version installed ?
                                            If so then perhaps Anton needs to make his re-encoding more robust ?
                                            • 11
                                            • 12
                                            • 13
                                            • 46
                                            • 47
                                            • 11 / 47
