    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 489.1k Views 114 Watching
    • ccaponigroC Offline
      ccaponigro
      There are a lot of people more skilled than I on here but I think you want to isolate those objects in a scene in sketch up create another section that does cut them and import it and overlay it on top of your other section in layout.
      cfcaia.com
      • bmikeB Offline
        bmike
        @malo8x said:
        Hi All
        Sorry if this question has been asked
        I am using LO for construction drawings, I have some strip Windows which are at higher level than the doors. Hence the section plane can't cut through those windows and I can't see them on the plan. Does anyone have any tip or any way to solve Thi issue. Thanks
        You can isolate those objects, then cut a section, and place another view / window over your plan to show only those on the plan...
          Drifter928
          I have an example of a set of cd's on my website.
          http://www.craigsdraftingservice.com/home.html
          Craig
          • pbacotP Offline
            Excellent Craig! (I looked at your site--there was some problem with the other link).
              Drifter928
              Thanks for the compliment. I put up a pdf download on the link that didn't work.
              Craig
              • TommyKT Offline
                TommyK
                Those are great and detailed construction details Craig. Thanks for sharing.
                There's a lot of detail in there that would tax me if I were to make revisions. What plugins do you use to speed up your workflow?
                  Drifter928
                  Section Cut Face
                  Dashed Line
                  1001 Bit
                  These custom homes go thru a lot of changes so I have gotten very good at editing in Sketchup.
                  Craig
                  • fouronethirtyF Offline
                    fouronethirty
                    hellow sketchucation,
                    sir this is some of the work ive been on utilizing su/lo.
                    residential project out of su/lo
                      Lê Việt Trường
                      I have some tips you can make your Sketchup's 2D scenes better before send to Layout.
                      http://sketchucation.com/forums/viewtopic.php?f=12%26amp;t=65513
                      Hope you like it.
                        GigiCray
                        Screen Shot 2016-11-01 at 4.51.26 PM.pngHelp.... my layout files often become corrupted with a grey box with a big red x in the middle of the grey box.. these typically are where I had copied and pasted an image. Can anyone tell me why and how to get back to my original file?
                        • GMthompsonG Offline
                          GMthompson
                          @gigicray said:
                          [attachment=0:brb0u6bc]<!-- ia0 -->Screen Shot 2016-11-01 at 4.51.26 PM.png<!-- ia0 -->[/attachment:brb0u6bc]Help.... my layout files often become corrupted with a grey box with a big red x in the middle of the grey box.. these typically are where I had copied and pasted an image. Can anyone tell me why and how to get back to my original file?
                          file
                          document setup
                          references
                          then relink the jpg
                          is it a exploded skp?
                          you can learn something everyday by paying attention
                            ccaponigro
                            So I thought I would share a little of my quest to work without CADD. One big thing for me was having to give up automated Door and Window Schedules and Room Finish Schedules fed by objects in the model with attributes assigned.
                            So The Door and Window schedules are created by just isolating the objects and then numbering them sequentially with the help of the outliner. And then run the report generator save the cvs file and import to layout. In layout the label tool reads the instance number so the plan reads out the correct number and it is linked to the model. The reason the door labels are on the door knobs is because you don't have a problem selecting the door instead of the section cut.
                            The Room Finish Schedule is generated by Isolating a set of components. One for each room that is painted with a material called "AREA" I just copy the component with the attributes and make unique and then edit the face size. You can paint the hidden side so it does not interfere with your floor color because the formula only picks up the area of the "area" material.
                            Also all the dashed lines are directly in the model on the 2d layer and are created quickly using Profile Builder 2.
                            I know it's rudimentary but it's pure Sketchup and layout and it is all linked to the model. And I know most architect types will be looking for symbols around the Door and Window numbers. You could just scrapbook some in. I decided I like just the bold font. I'm very lazy.
                            Love to hear some feedback Thanks!
                            ROOM FINISH SCHEDULE REPORT
                            WINDOW SCHEDULE REPORT
                            FLOOR PLANS
                            cfcaia.com
                            • 2 Offline
                              2liv
                              Looking for scrapbook templates:
                              drafting symbols
                              electrical symbols
                              Could someone help me find them ?
                              thank you
                              • pbacotP Offline
                                @2liv said:
                                drafting symbols
                                electrical symbols
                                thank you
                                a search of Sketchucation gives this first result. You might find other things in the search too.
                                [UPDATED] My LayOut Scrapbook for Architectural Drawings.
                                403 Forbidden
                                (sketchucation.com)
                                • FlexanF Offline
                                  Flexan
                                  Thanks! It's really useful information.
                                  • RichardR Offline
                                    Richard
                                    Technical images for a manual.
                                    I rarely have ever been asked to prepare technical style drawings for clients (they know I avoid them). These are for a technical manual for the use of their panelised building system.
                                    Wall section exported from Layout:
                                    Another typical page of artwork exported from sketchup and rendered with maxwell:
                                    BUILTBRAND.COM.AU
                                    • fionmacoolF Offline
                                      fionmacool
                                      Following on from SketchUp's Section Tools improvements, I've released a follow on to my previous book on this subject. Construction Documentation Using SketchUp Pro 2020 is light years ahead of it's predecessor released in 2012.
                                      SketchUp for Construction Documentation UPDATED (2024) | SketchUcation
                                      Construction Documents using SketchUp Pro & LayOut by Paul Lee shows professionals & enthusiasts how to tie all the parts of SketchUp together to produce drawings that were traditionally the domain of CAD.
                                      (sketchucation.com)
                                      The book contains a course based around a building project that I designed and project managed years ago. I chose this project as it's the right balance of simple/ complex- You spend the least amount of time getting the maximum experience.
                                      I've been writing this book on and off for 2 years, preparing the concept and polishing the models to make them user friendly. Each of the 120 or so pages is carefully put together to make the steps easy to follow.
                                      https://viewsion.ie/wp-content/uploads/2020/01/CDSP_2020.5_001.jpg
                                      I'm going to be doing a few videos from it shortly. I'm still working on the website to place some cool resources on it. The idea for the website is to focus on construction documentation and BIM.
                                      In the meantime, here's a short extract from the book for you to download- My 5 killer shortcuts. Hopefully it will download OK.
                                      https://viewsion.ie/wp-content/uploads/2020/01/5_Killer_Shortcuts-for_SketchUp_Pro.pdf
                                      Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                      • jujuJ Offline
                                        juju
                                        (sketchucation.com)
                                        Has SketchUp Pro 2020 been released? Did you have early access to SUP2020?
                                        • pbacotP Offline
                                          Maybe 2020 refers to the version of the BOOK not the SW.
                                          • jujuJ Offline
                                            juju
                                            I also thought of that, but the lack of punctuation infers otherwise.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
