    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 535.8k Views 114 Watching
      AirWindSolar
      @jasonwd said:
      I think this came about because there were so many LayOut critical scenes in the SU file that if I created a new layer I would have to Update all the scenes with that new layer off. That's my excuse anyway!
      This. Not sure why they won't give an option to have new layers default to off in all scenes, since 99 times out of 100, I'm creating the layer specifically so I can have something show in only one scene. Would be a lot easier to turn it on in that scene than go through all the others turning it off.
      And while we're on dumb behaviors, who had the drug addled idea that "save draft" should be the leftmost and most visible button?
      • JasonWDJ
        JasonWD
        When I'm working away in solitude I assume I'm being an idiot and there is a good reason for things being the way they are so just go with the flow and bodge it.
        It's nice to know others have the same problems 😄
        SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
          malo8x
          Hi All
          Sorry if this question has been asked
          I am using LO for construction drawings, I have some strip Windows which are at higher level than the doors. Hence the section plane can't cut through those windows and I can't see them on the plan. Does anyone have any tip or any way to solve Thi issue. Thanks
          • ccaponigroC
            ccaponigro
            There are a lot of people more skilled than I on here but I think you want to isolate those objects in a scene in sketch up create another section that does cut them and import it and overlay it on top of your other section in layout.
            cfcaia.com
            • bmikeB
              bmike
              @malo8x said:
              Hi All
              You can isolate those objects, then cut a section, and place another view / window over your plan to show only those on the plan...
                Drifter928
                I have an example of a set of cd's on my website.
                http://www.craigsdraftingservice.com/home.html
                Craig
                • pbacotP
                  Excellent Craig! (I looked at your site--there was some problem with the other link).
                    Drifter928
                    Thanks for the compliment. I put up a pdf download on the link that didn't work.
                    Craig
                    • TommyKT
                      TommyK
                      Those are great and detailed construction details Craig. Thanks for sharing.
                      There's a lot of detail in there that would tax me if I were to make revisions. What plugins do you use to speed up your workflow?
                        Drifter928
                        Section Cut Face
                        Dashed Line
                        1001 Bit
                        These custom homes go thru a lot of changes so I have gotten very good at editing in Sketchup.
                        Craig
                        • fouronethirtyF
                          fouronethirty
                          hellow sketchucation,
                          sir this is some of the work ive been on utilizing su/lo.
                          residential project out of su/lo
                          • L
                            Lê Việt Trường
                            I have some tips you can make your Sketchup's 2D scenes better before send to Layout.
                            http://sketchucation.com/forums/viewtopic.php?f=12%26amp;t=65513
                            Hope you like it.
                            • G
                              GigiCray
                              Screen Shot 2016-11-01 at 4.51.26 PM.pngHelp.... my layout files often become corrupted with a grey box with a big red x in the middle of the grey box.. these typically are where I had copied and pasted an image. Can anyone tell me why and how to get back to my original file?
                              • GMthompsonG
                                GMthompson
                                @gigicray said:
                                [attachment=0:brb0u6bc]<!-- ia0 -->Screen Shot 2016-11-01 at 4.51.26 PM.png<!-- ia0 -->[/attachment:brb0u6bc]Help.... my layout files often become corrupted with a grey box with a big red x in the middle of the grey box.. these typically are where I had copied and pasted an image. Can anyone tell me why and how to get back to my original file?
                                file
                                document setup
                                references
                                then relink the jpg
                                is it a exploded skp?
                                you can learn something everyday by paying attention
                                • ccaponigroC
                                  ccaponigro
                                  So I thought I would share a little of my quest to work without CADD. One big thing for me was having to give up automated Door and Window Schedules and Room Finish Schedules fed by objects in the model with attributes assigned.
                                  So The Door and Window schedules are created by just isolating the objects and then numbering them sequentially with the help of the outliner. And then run the report generator save the cvs file and import to layout. In layout the label tool reads the instance number so the plan reads out the correct number and it is linked to the model. The reason the door labels are on the door knobs is because you don't have a problem selecting the door instead of the section cut.
                                  The Room Finish Schedule is generated by Isolating a set of components. One for each room that is painted with a material called "AREA" I just copy the component with the attributes and make unique and then edit the face size. You can paint the hidden side so it does not interfere with your floor color because the formula only picks up the area of the "area" material.
                                  Also all the dashed lines are directly in the model on the 2d layer and are created quickly using Profile Builder 2.
                                  I know it's rudimentary but it's pure Sketchup and layout and it is all linked to the model. And I know most architect types will be looking for symbols around the Door and Window numbers. You could just scrapbook some in. I decided I like just the bold font. I'm very lazy.
                                  Love to hear some feedback Thanks!
                                  ROOM FINISH SCHEDULE REPORT
                                  WINDOW SCHEDULE REPORT
                                  FLOOR PLANS
                                  cfcaia.com
                                    2liv
                                    Looking for scrapbook templates:
                                    drafting symbols
                                    electrical symbols
                                    Could someone help me find them ?
                                    thank you
                                    • pbacotP
                                      @2liv said:
                                      drafting symbols
                                      electrical symbols
                                      thank you
                                      a search of Sketchucation gives this first result. You might find other things in the search too.
                                      [UPDATED] My LayOut Scrapbook for Architectural Drawings.
                                      403 Forbidden
                                      (sketchucation.com)
                                      • FlexanF
                                        Flexan
                                        Thanks! It's really useful information.
                                        • RichardR
                                          Richard
                                          Technical images for a manual.
                                          I rarely have ever been asked to prepare technical style drawings for clients (they know I avoid them). These are for a technical manual for the use of their panelised building system.
                                          Wall section exported from Layout:
                                          Another typical page of artwork exported from sketchup and rendered with maxwell:
                                          BUILTBRAND.COM.AU
                                          • fionmacoolF
                                            fionmacool
                                            Following on from SketchUp's Section Tools improvements, I've released a follow on to my previous book on this subject. Construction Documentation Using SketchUp Pro 2020 is light years ahead of it's predecessor released in 2012.
                                            SketchUp for Construction Documentation UPDATED (2024) | SketchUcation
                                            Construction Documents using SketchUp Pro & LayOut by Paul Lee shows professionals & enthusiasts how to tie all the parts of SketchUp together to produce drawings that were traditionally the domain of CAD.
                                            (sketchucation.com)
                                            The book contains a course based around a building project that I designed and project managed years ago. I chose this project as it's the right balance of simple/ complex- You spend the least amount of time getting the maximum experience.
                                            I've been writing this book on and off for 2 years, preparing the concept and polishing the models to make them user friendly. Each of the 120 or so pages is carefully put together to make the steps easy to follow.
                                            https://viewsion.ie/wp-content/uploads/2020/01/CDSP_2020.5_001.jpg
                                            I'm going to be doing a few videos from it shortly. I'm still working on the website to place some cool resources on it. The idea for the website is to focus on construction documentation and BIM.
                                            In the meantime, here's a short extract from the book for you to download- My 5 killer shortcuts. Hopefully it will download OK.
                                            https://viewsion.ie/wp-content/uploads/2020/01/5_Killer_Shortcuts-for_SketchUp_Pro.pdf
                                            Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
