    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 519.0k Views 114 Watching
    • pbacotP
      Excellent Craig! (I looked at your site--there was some problem with the other link).
        Drifter928
        Thanks for the compliment. I put up a pdf download on the link that didn't work.
        Craig
        • TommyKT
          TommyK
          Those are great and detailed construction details Craig. Thanks for sharing.
          There's a lot of detail in there that would tax me if I were to make revisions. What plugins do you use to speed up your workflow?
            Drifter928
            Section Cut Face
            Dashed Line
            1001 Bit
            These custom homes go thru a lot of changes so I have gotten very good at editing in Sketchup.
            Craig
            • fouronethirtyF
              fouronethirty
              hellow sketchucation,
              sir this is some of the work ive been on utilizing su/lo.
              residential project out of su/lo
              • L
                Lê Việt Trường
                I have some tips you can make your Sketchup's 2D scenes better before send to Layout.
                http://sketchucation.com/forums/viewtopic.php?f=12%26amp;t=65513
                Hope you like it.
                • G
                  GigiCray
                  Screen Shot 2016-11-01 at 4.51.26 PM.pngHelp.... my layout files often become corrupted with a grey box with a big red x in the middle of the grey box.. these typically are where I had copied and pasted an image. Can anyone tell me why and how to get back to my original file?
                  • GMthompsonG
                    GMthompson
                    @gigicray said:
                    [attachment=0:brb0u6bc]<!-- ia0 -->Screen Shot 2016-11-01 at 4.51.26 PM.png<!-- ia0 -->[/attachment:brb0u6bc]Help.... my layout files often become corrupted with a grey box with a big red x in the middle of the grey box.. these typically are where I had copied and pasted an image. Can anyone tell me why and how to get back to my original file?
                    file
                    document setup
                    references
                    then relink the jpg
                    is it a exploded skp?
                    you can learn something everyday by paying attention
                    • ccaponigroC
                      ccaponigro
                      So I thought I would share a little of my quest to work without CADD. One big thing for me was having to give up automated Door and Window Schedules and Room Finish Schedules fed by objects in the model with attributes assigned.
                      So The Door and Window schedules are created by just isolating the objects and then numbering them sequentially with the help of the outliner. And then run the report generator save the cvs file and import to layout. In layout the label tool reads the instance number so the plan reads out the correct number and it is linked to the model. The reason the door labels are on the door knobs is because you don't have a problem selecting the door instead of the section cut.
                      The Room Finish Schedule is generated by Isolating a set of components. One for each room that is painted with a material called "AREA" I just copy the component with the attributes and make unique and then edit the face size. You can paint the hidden side so it does not interfere with your floor color because the formula only picks up the area of the "area" material.
                      Also all the dashed lines are directly in the model on the 2d layer and are created quickly using Profile Builder 2.
                      I know it's rudimentary but it's pure Sketchup and layout and it is all linked to the model. And I know most architect types will be looking for symbols around the Door and Window numbers. You could just scrapbook some in. I decided I like just the bold font. I'm very lazy.
                      Love to hear some feedback Thanks!
                      ROOM FINISH SCHEDULE REPORT
                      WINDOW SCHEDULE REPORT
                      FLOOR PLANS
                      cfcaia.com
                        2liv
                        Looking for scrapbook templates:
                        drafting symbols
                        electrical symbols
                        Could someone help me find them ?
                        thank you
                        • pbacotP
                          @2liv said:
                          drafting symbols
                          electrical symbols
                          thank you
                          a search of Sketchucation gives this first result. You might find other things in the search too.
                          [UPDATED] My LayOut Scrapbook for Architectural Drawings.
                          403 Forbidden
                          (sketchucation.com)
                          • FlexanF
                            Flexan
                            Thanks! It's really useful information.
                            • RichardR
                              Richard
                              Technical images for a manual.
                              I rarely have ever been asked to prepare technical style drawings for clients (they know I avoid them). These are for a technical manual for the use of their panelised building system.
                              Wall section exported from Layout:
                              Another typical page of artwork exported from sketchup and rendered with maxwell:
                              BUILTBRAND.COM.AU
                              • fionmacoolF
                                fionmacool
                                Following on from SketchUp's Section Tools improvements, I've released a follow on to my previous book on this subject. Construction Documentation Using SketchUp Pro 2020 is light years ahead of it's predecessor released in 2012.
                                SketchUp for Construction Documentation UPDATED (2024) | SketchUcation
                                Construction Documents using SketchUp Pro & LayOut by Paul Lee shows professionals & enthusiasts how to tie all the parts of SketchUp together to produce drawings that were traditionally the domain of CAD.
                                (sketchucation.com)
                                The book contains a course based around a building project that I designed and project managed years ago. I chose this project as it's the right balance of simple/ complex- You spend the least amount of time getting the maximum experience.
                                I've been writing this book on and off for 2 years, preparing the concept and polishing the models to make them user friendly. Each of the 120 or so pages is carefully put together to make the steps easy to follow.
                                https://viewsion.ie/wp-content/uploads/2020/01/CDSP_2020.5_001.jpg
                                I'm going to be doing a few videos from it shortly. I'm still working on the website to place some cool resources on it. The idea for the website is to focus on construction documentation and BIM.
                                In the meantime, here's a short extract from the book for you to download- My 5 killer shortcuts. Hopefully it will download OK.
                                https://viewsion.ie/wp-content/uploads/2020/01/5_Killer_Shortcuts-for_SketchUp_Pro.pdf
                                Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                • jujuJ
                                  juju
                                  (sketchucation.com)
                                  Has SketchUp Pro 2020 been released? Did you have early access to SUP2020?
                                  • pbacotP
                                    Maybe 2020 refers to the version of the BOOK not the SW.
                                    • jujuJ
                                      juju
                                      I also thought of that, but the lack of punctuation infers otherwise.
                                      • fionmacoolF
                                        fionmacool
                                        Hey thanks for asking that question. Yes the book refers to the year not the software.
                                        However...
                                        The updates to 2020 will be covered on my website http://www.sketchup.expert
                                        • utilerU
                                          utiler
                                          Look forward to seeing when its ready to be released, fionmacool!
                                          Just Curious...
                                            Drifter928
                                            This is a set of CD's I drew in Sketchup/Layout
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 23 / 23
