    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 489.1k Views 114 Watching
      sonder
      @jasonwd said:
      @driven said:
      404 Not Found
      (sketchucation.com)
      hi jason, have you tried this one...
      I havn't for a while, but yes!
      I think the problem is I like to show exploded stuff in Perspective and that creates challenges for seeing everything nicely in the explosion.
      The most annoying thing is that it interrupts my workflow because it makes you have another copy of the SU geometry in a separate file just for the explosion
      Rather than creating a separate file, why not just copy and create a separate group for the expoded view and set that on its own layer; then create the "exploded scene". That way, if each element is a component, you only have to modify once, in a single file.
      • JasonWDJ Offline
        JasonWD
        I think this came about because there were so many LayOut critical scenes in the SU file that if I created a new layer I would have to Update all the scenes with that new layer off. That's my excuse anyway!
        SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
        • pbacotP Offline
          Yeah that's tough, but now you can use the addlayer plugin for those situations.
            AirWindSolar
            This. Not sure why they won't give an option to have new layers default to off in all scenes, since 99 times out of 100, I'm creating the layer specifically so I can have something show in only one scene. Would be a lot easier to turn it on in that scene than go through all the others turning it off.
            And while we're on dumb behaviors, who had the drug addled idea that "save draft" should be the leftmost and most visible button?
            • JasonWDJ Offline
              JasonWD
              When I'm working away in solitude I assume I'm being an idiot and there is a good reason for things being the way they are so just go with the flow and bodge it.
              It's nice to know others have the same problems 😄
                malo8x
                Hi All
                Sorry if this question has been asked
                I am using LO for construction drawings, I have some strip Windows which are at higher level than the doors. Hence the section plane can't cut through those windows and I can't see them on the plan. Does anyone have any tip or any way to solve Thi issue. Thanks
                • ccaponigroC Offline
                  ccaponigro
                  There are a lot of people more skilled than I on here but I think you want to isolate those objects in a scene in sketch up create another section that does cut them and import it and overlay it on top of your other section in layout.
                  cfcaia.com
                  • bmikeB Offline
                    bmike
                    @malo8x said:
                    Hi All
                    You can isolate those objects, then cut a section, and place another view / window over your plan to show only those on the plan...
                      Drifter928
                      I have an example of a set of cd's on my website.
                      http://www.craigsdraftingservice.com/home.html
                      Craig
                      • pbacotP Offline
                        Excellent Craig! (I looked at your site--there was some problem with the other link).
                          Drifter928
                          Thanks for the compliment. I put up a pdf download on the link that didn't work.
                          Craig
                          • TommyKT Offline
                            TommyK
                            Those are great and detailed construction details Craig. Thanks for sharing.
                            There's a lot of detail in there that would tax me if I were to make revisions. What plugins do you use to speed up your workflow?
                              Drifter928
                              Section Cut Face
                              Dashed Line
                              1001 Bit
                              These custom homes go thru a lot of changes so I have gotten very good at editing in Sketchup.
                              Craig
                              • fouronethirtyF Offline
                                fouronethirty
                                hellow sketchucation,
                                sir this is some of the work ive been on utilizing su/lo.
                                residential project out of su/lo
                                  Lê Việt Trường
                                  I have some tips you can make your Sketchup's 2D scenes better before send to Layout.
                                  http://sketchucation.com/forums/viewtopic.php?f=12%26amp;t=65513
                                  Hope you like it.
                                    GigiCray
                                    Screen Shot 2016-11-01 at 4.51.26 PM.pngHelp.... my layout files often become corrupted with a grey box with a big red x in the middle of the grey box.. these typically are where I had copied and pasted an image. Can anyone tell me why and how to get back to my original file?
                                    • GMthompsonG Offline
                                      GMthompson
                                      @gigicray said:
                                      [attachment=0:brb0u6bc]<!-- ia0 -->Screen Shot 2016-11-01 at 4.51.26 PM.png<!-- ia0 -->[/attachment:brb0u6bc]Help.... my layout files often become corrupted with a grey box with a big red x in the middle of the grey box.. these typically are where I had copied and pasted an image. Can anyone tell me why and how to get back to my original file?
                                      file
                                      document setup
                                      references
                                      then relink the jpg
                                      is it a exploded skp?
                                      you can learn something everyday by paying attention
                                        ccaponigro
                                        So I thought I would share a little of my quest to work without CADD. One big thing for me was having to give up automated Door and Window Schedules and Room Finish Schedules fed by objects in the model with attributes assigned.
                                        So The Door and Window schedules are created by just isolating the objects and then numbering them sequentially with the help of the outliner. And then run the report generator save the cvs file and import to layout. In layout the label tool reads the instance number so the plan reads out the correct number and it is linked to the model. The reason the door labels are on the door knobs is because you don't have a problem selecting the door instead of the section cut.
                                        The Room Finish Schedule is generated by Isolating a set of components. One for each room that is painted with a material called "AREA" I just copy the component with the attributes and make unique and then edit the face size. You can paint the hidden side so it does not interfere with your floor color because the formula only picks up the area of the "area" material.
                                        Also all the dashed lines are directly in the model on the 2d layer and are created quickly using Profile Builder 2.
                                        I know it's rudimentary but it's pure Sketchup and layout and it is all linked to the model. And I know most architect types will be looking for symbols around the Door and Window numbers. You could just scrapbook some in. I decided I like just the bold font. I'm very lazy.
                                        Love to hear some feedback Thanks!
                                        ROOM FINISH SCHEDULE REPORT
                                        WINDOW SCHEDULE REPORT
                                        FLOOR PLANS
                                        cfcaia.com
                                        • 2 Offline
                                          2liv
                                          Looking for scrapbook templates:
                                          drafting symbols
                                          electrical symbols
                                          Could someone help me find them ?
                                          thank you
                                          • pbacotP Offline
                                            @2liv said:
                                            drafting symbols
                                            electrical symbols
                                            thank you
                                            a search of Sketchucation gives this first result. You might find other things in the search too.
                                            [UPDATED] My LayOut Scrapbook for Architectural Drawings.
                                            403 Forbidden
                                            (sketchucation.com)
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
