    ICON MF_ENABLED, MF_CHECKED
    37 Posts 5 Posters 6.1k Views 5 Watching
    • K
      kaas
      @TNTDAVID - to investigate problems like this yourself, you just do puts valeur just after valeur = model_def.get_attribute 'dynamic_attributes','mode'
      At that moment you will see a value, an error, a string etc - when you expected an int etc etc. Next you can try to fix it.
      If that puts returns a value though as expected you do the same in the next line where some code is executed etc etc. Repeat until you solved the problem.
      Leaving the ruby console open is essential because errors are displayed there with some hints/line numbers where the code fails.
      For anyone new in ruby (also for me), this really helps in learning why code fails. Asking here might result in a solution but you will learn not as much compared to trying to debug your code yourself.
      • TNTDAVIDT
        TNTDAVID
        I do not have the expected result, but at least the code works with the "puts".
        @commandB.set_validation_proc{ puts MF_DISABLED }
        The ruby console goes crazy, and sending 0 continuously after clicking on an icon ...
        Here's the code:
        module TesteCube
            module ClickWindow
            @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources')
            if !file_loaded?(__FILE__)
            su_menu = UI.menu("Plugins")
            cc_menu = su_menu.add_submenu(%Q(TesteCube))
            tb = UI;;Toolbar.new(%Q(TesteCube))
            @commandA = UI;;Command.new("mode1"){ ClickWindow.cmdA()}
            @commandA.small_icon = File.join(@@path_to_resources,"add_A.png")
            @commandA.large_icon = File.join(@@path_to_resources,"add_A.png")
            @commandA.tooltip = %Q(Opens Settings SketchUp)
            @commandA.status_bar_text = %Q(Opens Settings SketchUp)
            @commandA.menu_text = %Q(Opens Settings SketchUp)
            cc_menu.add_item(@commandA)
            tb.add_item(@commandA)
            @commandB = UI;;Command.new("mode1"){ ClickWindow.cmdB()}
            @commandB.small_icon = File.join(@@path_to_resources,"add_B.png")
            @commandB.large_icon = File.join(@@path_to_resources,"add_B.png")
            @commandB.tooltip = %Q(Opens Settings SketchUp)
            @commandB.status_bar_text = %Q(Opens Settings SketchUp)
            @commandB.menu_text = %Q(Opens Settings SketchUp)
            cc_menu.add_item(@commandB)
            tb.add_item(@commandB)
            tb.restore
            file_loaded(__FILE__)
            def self.cmdA()
            puts MF_DISABLED
            model = Sketchup.active_model
            model_definition = model.definitions
            model_def = model_definition['Box']
            model_def.set_attribute 'dynamic_attributes','a0000mode', '1'
            model_def.set_attribute 'dynamic_attributes','_a0000mode_label', 'mode'
            model_def.set_attribute 'dynamic_attributes','_a0000mode_units', 'STRING'
            model_def.set_attribute 'dynamic_attributes','_a0000mode_access', 'TEXTBOX'
            puts MF_ENABLED
            ### you say you want vice vers affects from the two toolbar buttons ! ?????
            def self.cmdB()
            @commandA.set_validation_proc{
            puts MF_DISABLED
            model_def.set_attribute 'dynamic_attributes','mode', '2'
            model_def.set_attribute 'dynamic_attributes','_mode_label', 'mode'
            model_def.set_attribute 'dynamic_attributes','_mode_units', 'STRING'
            model_def.set_attribute 'dynamic_attributes','_mode_access', 'TEXTBOX'
            puts MF_ENABLED
        The code inside the methods are properly executed, but the icons state does not change.
        What's wrong?
        @tig said:
        DC values are strings
        If it exists it might be say "1" rather than 1
        TIG thank you, it works fine now. 👍
        The message is passed, "Kaas" I work only with the ruby consol to find my mistakes.
        I just noticed that the ruby consol, create the toolbar and the icons. 😛
        It lacks the "png", but this is normal.
        Big thank you to you both for your advice.
        Thank you
        [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
        • K
          kaas
          The 'crazy console' is because you put a puts at a very strange position ?!?
          @commandB.set_validation_proc{puts MF_DISABLED}
          Why did you put the puts there?? It makes no sense (to me). Think about the difference.
          @commandB.set_validation_proc{MF_DISABLED}
          • K
            kaas
            If I remove the strange puts it still doesn't work and I think the reason is; you mixed up the logic for enabling / disabling the buttons;
            if you enable A, you should disable B and vice versa. In your code you first enable A and then disable the same again.
            The code below does show switching icons. I used CHECKED instead of ENABLED so its more clear.
            module TesteCube
                module ClickWindow
            				tb.restore
            			def self.cmdA()
            				#puts'cmdA'
            				@commandA.set_validation_proc{MF_CHECKED}
            			def self.cmdB()
            				#puts'cmdB'
            				@commandA.set_validation_proc{MF_DISABLED}
            				@commandB.set_validation_proc{MF_CHECKED}
            • TNTDAVIDT
              TNTDAVID
              Kaas Congratulations!
              A simple test of logic and the code works. 👍
              For "puts", I misunderstood fredo:
              @fredo6 said:
              This is a proc, so it is called by Sketchup and expect a return value to set the state of the icon. It is called almost continuously (you can check that by the statement command18.set_validation_proc { puts "icon proc" ; MF_GRAYED }.
              I can resume my labors, and I hold you informed of advancements or problems. 💚
              Thank you for your help!
              See you soon
              David
              • TNTDAVIDT
                TNTDAVID
                A question that comes to mind. 💚
                How an icon can be activated and deactivated with each click.
                Example:
                1st click on iconeA = "MF_CHECKED"
                2nd click on iconeA = "MF_ENABLED"
                3rd click on iconeA = "MF_CHECKED" ....
                I tried this line of code:
                @commandA.set_validation_proc{ MF_CHECKED; MF_ENABLED }
                It does not work.
                Do you know the method to be followed?
                Thank you
                • K
                  kaas
                  No surprise it doesn't work - you are making up code that doesn't exist in the API. http://www.sketchup.com/intl/en/developer/docs/ourdoc/command#set_validation_proc
                  Just make a @variable to store the current state (0/1/2) and after clicking on an icon read the variable, use the proper MF_... and set the @variable to another value.
                  Off-topic; coming from someone who is selling a SketchUp plugin for E99,- I find your questions and knowledge of Ruby rather 'strange'...
                  • TNTDAVIDT
                    TNTDAVID
                    I discovered the ruby ...
                    My plugins are tools that work only with Dynamic Components.
                    Many underestimate the power of dynamic components, which offer unlimited possibilitys.
                    Example:
                    Click-Change or Click-Kitchen, totaling 100,000 downloads, and more than a Million views in the entropot extensions.
                    And 100% of my clients are satisfied.
                    I am currently working on an updated Click-Window 3D, which will bring a lot of positive change.
                    If I cling to the ruby, it's in the one and only goal, to offer even more to my customers.
                      With your code
                      It should set the @commandA menu item to be checked and enabled.
                      It probably won't 'check' the toolbar button - which should be enabled or disabled/grayed ?
                      BUT before you do that have you added
                      puts @commandA in a line immediately before.
                      When you run the command from its button, then it is shows up in the Ruby Console as a reference to a command if it's working right, but if it's nil it's somehow coded wrongly...
                      • TNTDAVIDT
                        TNTDAVID
                        Good evening,
                        Icon 1, use the following method:
                        def self.panel
                              layers = model.layers
                              new_layer = layers.add "Click-Window 3D"
                              if new_layer.visible?
                              new_layer.visible = false
                              else
                              new_layer.visible = true
                        Icon 2, uses this method:
                        def self.layerhid
                              instance.layer = new_layer
                        When I use the two icons, the visibility of the layer starts to bugger.
                        Even if the code activates or deactivates the layer in the Layers window, the composents with this layer do not change state.
                        Do you know why this strange bug?
                        If so, how to avoid it?
                        Thank you in advance for your help.
                        David
                        • K
                          kaas
                          If you added some puts to your code, you could get some more info on what your code is doing and where/why your code fails.
                          In short:
                          your first block (self.panel) is just toggling the visibility of new_layer
                          your second block (self.layerhid) is always hiding the visibility of new_layer
                          instance has not been defined in that second block so if you try to change its layer using instance.layer= it will fail. It probably has to be @my_instance that you have defined elsewhere. There probably was an error message about that in the Ruby Console that you forgot to read/post...
                          def self.panel
                          		puts %(self.panel is setting visibility to false)
                          	else
                          		puts %(self.panel is setting visibility to true)
                          def self.layerhid
                          	puts %(self.layerhid is setting visibility to false)
                          	puts instance.layer
                          • TNTDAVIDT
                            TNTDAVID
                            @tig said:
                            With your code
                            Thank you for that clarification, TIG.
                            Oops! I made a mistake in my copy / pasted, instance.layer should not exist in "Method layerhid".
                            As I noticed the error in the ruby ​​console, and there to any subject in the API on "instance.layer", I ended up deleting it.
                            Regarding "Puts", I added them more, because it can prevent in some cases, a method of work.
                            Example:
                                 puts new_layer.visible = false # action 1A
                                 puts Sketchup.send_action "selectSelectionTool;" # action 2A
                                 elsif
                                 puts new_layer.visible = true # action 1B
                                 puts Sketchup.active_model.select_tool(DCInteractTool.new($dc_observers)) # action 2B
                            This does not work!
                            If I remove the puts as:
                                 elsif
                                 pnew_layer.visible = true # action 1B
                            The code works!
                            With or without "Puts", the console displays the line number or there is an error.
                            So what are the avanatges of "Puts"?
                            @kaas said:
                            def self.panel
                               else
                            def self.layerhid
                                puts instance.layer
                            Thank you for your example code.
                            Unfortunately the problem still exists.
                            Here is the error message:
                            Error: #<NoMethodError: undefined method transform!' for #<Sketchup::ComponentDefinition:0x0000000e47fb40>> c:/users/david/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:454:in redraw'
                            c:/users/david/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:406:in redraw_with_undo' C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Pro_mm/logic.rb:217:in mode1'
                            C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Pro_mm/logic.rb:252:in block in <module:CW_Pro_mm>' SketchUp:1:in call'
                            Here are the relevant lines:
                            L217 - $dc_observers.get_latest_class.redraw_with_undo(model_def) # mode 1
                            L252 - @commandA = UI::Command.new("Mode 1"){ CW_Pro_mm.mode1 }
                            L406 - command12.tooltip = %Q(add Crank Window)
                            L454 - @commandO.small_icon = File.join(@@path_to_resources,"add_O.png")
                            I'm surprised these lines triggers an error message!
                            They exist in other methods or command, with these objects that works.
                            It is therefore difficult to understand the reasons of the error message. 😼
                            Thank you
                            David
                              I think the changing of button states on the fly is an issue.
                              So try this alternative:
                              module TesteCube
                              	module ClickWindow
                              		if ! file_loaded?(__FILE__)
                              				@disableA=false
                              				@disableB=false
                              				@commandA = UI;;Command.new("mode1"){ @disableB=true; self.cmdA(); @disableB=false }
                              				@commandB = UI;;Command.new("mode1"){ @disableA=true; self.cmdB(); @disableA=false }
                              					if @disableA
                              						MF_DISABLED
                              					else
                              						MF_ENABLED
                              					if @disableB
                              						MF_DISABLED
                              					else
                              						MF_ENABLED
                              				tb.restore
                              		def self.cmdA()
                              			UI.messagebox('cmdA')
                              		def self.cmdB()
                              			UI.messagebox('cmdB')
                              It sets two possible states for the buttons and sets/resets those each time the commands are run, running the code between those 'bookends'...
                              I've made it a UI.messagebox so you can the affect on the toolbar buttons - otherwise it'll be transitory...
                              • TNTDAVIDT
                                TNTDAVID
                                TIG thank you, but the state of the buttons is not the problem!
                                The bontons work fine with my current code.
                                I was wrong on all the line! 😳
                                The problem is this object:
                                It is used in this method:
                                      def self.mode1
                                      @commandA.set_validation_proc{MF_GRAYED}
                                      @commandB.set_validation_proc{MF_ENABLED}
                                      @commandP.set_validation_proc{MF_GRAYED}
                                      @commandO.set_validation_proc{MF_ENABLED}
                                      model_def = model_definition['Control Panel']
                                      model_def.set_attribute 'dynamic_attributes','_a0000mode_label', 'a0000mode'
                                This method changes a component attribute that uses the "Click-Window 3D"
                                Once this method is used, the component's display starts messing.
                                Here is my problem:
                                http://i.imgur.com/kYuvpNF.gif
                                Have you an idea of the problem?
                                Thank you
                                  Isn't that method used on the currently selected DC instance NOT a definition !?
                                  So perhaps it should be something like
                                  $dc_observers.get_latest_class.redraw_with_undo(model_def.instances[0])
                                  • TNTDAVIDT
                                    TNTDAVID
                                    It is in this kind of situation that your experience is very beneficial, TIG.
                                    Congratulation! 👍
                                    • 2 / 2
