    Schemas
    18 Posts 5 Posters 1.7k Views 5 Watching
      Laggingbehind
      Does anybody know of anyone who writes Schemas for people.. I need a simple 6 line schema for my project work. Obviously I don't mind paying someone if it gets the job done.
        slbaumgartner
        Could you expand on what you mean by "schemas"? I'm not familiar with that as a SketchUp term.
        • jujuJ Offline
          juju
          I believe it to be of literary reference. A representation of a plan or theory in the form of an outline or model.
            slbaumgartner
            I know what the word means, but that doesn't clarify what the OP wants with respect to SketchUp. A text description of the steps to create a model? For what kind of "project work"? And why 6-line?
              Jim
              I assume the original poster is talking about a Classification Schema, although a 6-line classification schema seems... unlikely.
              • cottyC Offline
                cotty
                Doesn't seem to be a very urgent problem ...
                my SketchUp gallery
                  Laggingbehind
                  Sorry Guys been away for a couple of weeks & wasn't able to log onto the forum. The schema is to do with the classification of catering components. I'm using sketchup 15 which has the ifc3x2 classification but its far to in depth for what I need & doesn't appear to have the fields I would ideally like so looking at something much more simple. The information I think would need/want are as follows
                  1. Description
                  2. Size
                  3. Manufacturer
                  4. Model ref
                  5. Electrical supply
                  6. Gas supply
                  7. Cold water supply
                  8. Hot water supply
                  9. Waste
                  10. URL
                  Just a couple more than the original 6 in the OP.. Help would be greatly appreciated & apologises again for the delay in responding
                  • jujuJ Offline
                    juju
                    It sounds like you want a personalised IFC-type system. Take a look at this article in the SketchUp knowledge base.
                    It may be of some use.
                      Laggingbehind
                      Exactly. I did go thro the article before posting this thread but failed in my attempts to get a working classification... No idea what I was doing wrong but still couldn't get it to load into sketchup so hence the thread.
                        Jim
                        I am interested in learning about this in relation to SketchUp. I will preface this by saying I don't quite understand everything that is going on with SketchUp Classifications and XML Schemas, but here is something simple and which may work for you.
                        The SketchUp Help Center article says SketchUp can import both .skc and .xsd files. .xsd file is a simple text file. I just googled an example .xsd file, modified it slightly, and imported into SketchUp via the Classification dialog.
                        [1] Import the Thing.xsd file (from Model Info/Classification Dialog)
                        [2] Classify your components as a "Thing" type (in Entity Info)
                        [3] Open the Components Options Dialog.
                        Of course, you will want to rename the Thing.xsd file and edit it's contents from "Thing" to whatever you want to name your classification.
                        Rename to Thing.xsd
                        • jujuJ Offline
                          juju
                          I've also been toying with this but I have not had enough time to really get to the bottom of things.
                          I've downloaded and tried the latest IFC schema (IFC4_ADD2) but that seems even more elaborate and technical than the one that ships with SketchUp.
                          The option you've posted above seems like a viable option. Thanks.
                            Jim
                            I see SketchUp will create a drop-down for enumerations which is a nice feature. I'm out of time now but can post an example later.
                              Laggingbehind
                              That's great Jim & really appreciated πŸ˜„
                              I'll have a proper look later in the day, apparently my boss thinks I should we working hahaha
                                Jim
                                For reference, the following page is a good place to start.
                                http://www.w3.org/TR/xmlschema-0/
                                • jujuJ Offline
                                  juju
                                  Also take a look at the IFC Doc application over at buildingSMART to help you "roll your own".
                                    Jim
                                    You could use plain old Dynamic Component attributes for this - then you could use the fields with Generate Report. Any reason you want a schema?
                                      Laggingbehind
                                      I guess the reason I wanted to go down the Schema route is because if I have a drawing with 30 components I thought it would be easier than creating the attributes each time....however I stand to be corrected if I'm wrong
                                        Jim
                                        That sounds about right if you don't need reporting directly in SketchUp. I don't know if there are extensions that provide Classification reporting for SketchUp - there is no reason there couldn't be one similar to "Generate Report" only for Classifications.
