ICON MF_ENABLED, MF_CHECKED
37 Posts 5 Posters 3.7k Views 5 Watching
    TNTDAVID
    Hello everybody. ☀
    I want to create an icon linked to another icon.
    If I enable "Icon A", "Icon B" is automatically désativé, and it must be the same in the other direction.
    To be as clear as possible, here is the example GIF:
    http://i.imgur.com/Q3gE9pf.gif
    Thank you in advance for your help.
    David
    [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      You issue is one of convoluted logic...
      You need both buttons to be enabled as the toolbar first opens.
      The two commands need setting up in your module as enduring references - e.g. @cmdA and @cmdB...
      When the user clicks on @cmdA a specified method runs [ let's call it self.cmdA() set up in the @cmdA=UI.command.new('cmdA'){self.cmdA()) section of your code ] immediately @cmdB is disabled [ @cmdB.set_validation_proc{MF_GRAYED} ] and some actions then take place, on their completion / cancellation @cmdB is ALWAYS re-enabled [ @cmdB.set_validation_proc{MF_ENABLED} ] - otherwise you would never again be able to click on it, without a restart !
      The converse is true for using @cmdB and disabling @cmdA temporarily...
        TNTDAVID
        Please, Can you show me a complete sample code, with all these elements:
        ` def self.cmdA
        def self.cmdB
        end`
        the creation of the command:
        @cmdA=UI.command.new('cmdA'){self.cmdA()) @cmdB=UI.command.new('cmdB'){self.cmdB())
        and also the validation:
        @cmdA.set_validation_proc{MF_ENABLED} @cmdB.set_validation_proc{MF_GRAYED}
        You can take into account these objectives:
        "CMDA" disables "CMDB" / "CMDB" off "CMDA".
        Thank you in advance for your help. 😉
        David
          module ...
          ### set up menu/toolbar with commands [@cmdA and @cmdB] which run the methods [cmdA() and cmdB()] etc...
          def self.cmdA()
            ### disable the @cmdB command for the duration of the process...
            ### do some code here, why else has the user click the button ???
            ### note IF the user cancels you MUST re-enable @cmdB command
            ### perhaps do some more code here...
            ### finally the process completes, so enable @cmdB command anyway.
            ### repeat for def self.cmbB() ... end
            ### but swapping cmdB for cmdA and vice versa...
          end#module
            TNTDAVID
            Hello,
            Your method seems much more simple and logical, that my research. 👍
            This is a very good thing, but I can not make it work. 😕
            Here is part of my code:
                  def self.panel #method called by the command17, which must temporarily disable the command 18.
                  command18.set_validation_proc{MF_GRAYED}
                  methode00
                  panelmove
                  $dc_observers.get_latest_class.close_configure_dialog
                  Sketchup.active_model.select_tool(DCInteractTool.new($dc_observers))
                  model = Sketchup.active_model
                  layers = model.layers
                  new_layer = layers.add "Click-Window 3D"
                  new_layer.visible = true
                  sang = Sketchup.active_model
                  sang_definition = sang.definitions
                  sang_def = sang_definition['Control Panel']
                  sang_def.set_attribute 'dynamic_attributes','a0000mode', '1'
                  sang_def.set_attribute 'dynamic_attributes','_a0000mode_label', 'a0000mode'
                  sang_def.set_attribute 'dynamic_attributes','_a0000mode_units', 'STRING'
                  sang_def.set_attribute 'dynamic_attributes','_a0000mode_access', 'TEXTBOX'
                  $dc_observers.get_latest_class.redraw_with_undo(sang_def)
                  command18.set_validation_proc{MF_ENABLED}
                  command18 = UI;;Command.new("Opens Settings SketchUp"){ CW_Pro_mm.options }
                  command18.small_icon = File.join(@@path_to_resources,"add_18.png")
                  command18.large_icon = File.join(@@path_to_resources,"add_18.png")
                  command18.tooltip = %Q(Opens Settings SketchUp)
                  command18.status_bar_text = %Q(Opens Settings SketchUp)
                  command18.menu_text = %Q(Opens Settings SketchUp)
                  cc_menu.add_item(command18)
                  tb.add_item(command18)
            When I click on my icon, nothing happens because " command18.set_validation_proc{MF_GRAYED}" does not work.
            Or is my mistake?
            What does the "@" is it essential?
            Thank you
            • F Offline
              @TNTDAVID
              Just put an instance variable between the brace, say @status_icon1.
              command18.set_validation_proc { @status_icon }
              Depending on your context, your script will change the variable between the values MF_ENABLED, MF_GRAYED or MF_ENABLED.
              This is a proc, so it is called by Sketchup and expect a return value to set the state of the icon. It is called almost continuously (you can check that by the statement command18.set_validation_proc { puts "icon proc" ; MF_GRAYED }.
              This is just State programming (as opposed to Event programming).
                Note that the validation proc is bugged for toolbars on Mac. They don't update right. In my extensions I ended up not using validation procs for commands used for toolbars - but still use them for menus.
                  @TNTDAVID
                  You have failed to appreciate that you need an instance variable @ to make it become available within a related module's methods [aka def]
                  I explained the difference of the variable types at some length, last week...
                  If you suddenly "out-of-the-blue" refer to something called command18, then that method will NOT understand what you mean by it.
                  BUT if you had set it up earlier, within the module, as @command18=... then it would also be visible within the nested method...
                  Also, please stop using confusing terminology !
                  Why ??
                  The sang is component in an old default template.
                  Use model= or mod= etc
                  Using 'ang' in a name hints that it might be an angle !
                    TNTDAVID
                    Wow I am very pleased to see the Great Masters of ruby ready to help me. 😍
                    I discovered the ruby, so thank you for your extreme indulgence.
                    I added the "@", but it's always the same problem.
                    Here is the updated code:
                          command18.set_validation_proc{@MF_GRAYED}
                          methode00
                          panelmove
                          model_definition = model.definitions
                          model_def = model_definition['Control Panel']
                          model_def.set_attribute 'dynamic_attributes','a0000mode', '1'
                          model_def.set_attribute 'dynamic_attributes','_a0000mode_label', 'a0000mode'
                          model_def.set_attribute 'dynamic_attributes','_a0000mode_units', 'STRING'
                          model_def.set_attribute 'dynamic_attributes','_a0000mode_access', 'TEXTBOX'
                          $dc_observers.get_latest_class.redraw_with_undo(model_def)
                          command18.set_validation_proc{@MF_ENABLED}
                    What is my mistake?
                    Thank you
                      Please indent your coe consistently and helpfully...
                      You have NOT added the @ !
                      None of your commands have a @ prefix.
                      If this is all of your code it's also wrong in other ways.
                      The various @ references need a commond 'parent' module, so they can be seen by the methods...
                      It all needs to be inside your own module[s].
                      The commands are set up as the code loads.
                      These should have @ names so that the methods can also access them.
                      Here is an outline - I have already given you something like this earlier in the week...
                      Do NOT following the exact naming etc just understand how the parts work, and apply them to your own needs...
                      module TNTDAVID
                        module ClickWindow
                          ### set up commands
                          @commandA = UI.command.new('CmdA'){self.cmdA()}
                          ### add icons, tooltips etc
                          @commandB = UI.command.new('CmdB'){self.cmdB()}
                          ### add it's toolbar
                          ### add the buttons to toolbar to run the commands
                          ### etc
                          ### the methods run by the commands...
                          def self.cmdA() ### the code run by commandA
                            ### do stuff here, that can then 'see' the @commandA and @commandB
                            ### which are instance variable references to the two commands !
                            ### disable @commandB
                            ### do some processing...
                            ### if the user jumps out of processing before the end ensure that @commandB is re-enabled
                            ### at the end re-enable @commandB
                          end#method
                          ### you say you want vice vers affects from the two toolbar buttons !
                          def self.cmdB() ### the code run by commandB
                            ### disable @commandA
                            ### if the user jumps out of processing before the end ensure that @commandA is re-enabled
                            ### at the end re-enable @commandA
                          end#method
                        end#module
                      end#module
                        TNTDAVID
                        I understand your logic in your example!
                        If I miss is the formulation of the code ....
                        **module TNTDAVID
                        module ClickWindow
                        ### set up commands OK
                        ### add icons, tooltips etc %(#FF0000)[OK]
                        ### add it's toolbar %(#FF0000)[OK]
                        ### add the buttons to toolbar to run the commands %(#FF0000)[OK]
                        ### etc
                        ### the methods run by the commands... %(#FF0000)[OK]
                        def self.cmdA() ### the code run by commandA %(#FF0000)[OK]
                          ### do stuff here, that can then 'see' the @commandA and @commandB %(#FF0000)[OK]
                          ### which are instance variable references to the two commands ! %(#BF0000)[OK]
                          ### disable @commandB %(#FF0040)[**1.how?**
                        The code does not work, even if I add an "@", between maybe curly braces.]
                          ### do some processing... %(#FF0000)[OK]
                        2.How should write the code?
                          ### at the end re-enable @commandB **%(#FF0000)[3.how?]**
                        end#method
                        ### you say you want vice vers affects from the two toolbar buttons !** %(#FF0000)[OK]
                        I think I expressed myself badly, is you do not have can understand my goals. 😕
                        "cmdA" is "GRAYED" by défeaut which is (mode1), even when you start SketchUp.
                        It remains "GRAYED" all the TIME! unless the user clicks on the icon "CMDB" to enter in the (mode2).
                        Under this condition, the icon "cmdB" becomes "GRAYED" is "cmdA" becomes "ENABLED".
                        ---cmdA- cmdB
                        http://i.imgur.com/WakoRGT.gif
                        4.I think your example, does not have the same objectives?
                        Thank you
                        David
                          Reread what you wrote...
                          @cmdB
                          is a method NOT a command, so try
                          @commandB.set_validation_proc{MF_GRAYED}
                          In Ruby there is the:
                          begin ... #a rescue ... #b ensure ... #c end
                          function
                          After you disable @commandB then you ought to do all of your remaining processing within the ' begin......end' - starting at #a
                          If these is a possibility that the user stops the process part way through, then you need to somehow spot it and then re-enable @commandB - that depends on your own code...
                          If it fails with an error - it invokes 'rescue' at #b - so then you also need to re-enable @commandB in that part.
                          The safety-net is the 'ensure' at #c - then you also need to re-enable @commandB in that part as well.
                          For further confidence I'd also add a re-enable for @commandB after the end of the begin......end - although I think it'll survive without it [obviously I haven't tested any of the is !]
                          NB: The re-enable code is:
                          @commandB.set_validation_proc{MF_ENABLED}
                            TNTDAVID
                            TIG, I just write code that conforms to your example:
                            module TesteCube
                              module ClickWindow
                                @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources')
                                if !file_loaded?(__FILE__)
                                su_menu = UI.menu("Plugins")
                                cc_menu = su_menu.add_submenu(%Q(TesteCube))
                                tb = UI;;Toolbar.new(%Q(TesteCube))
                                @commandA = UI;;Command.new("mode1"){ ClickWindow.cmdA()}
                                @commandA.small_icon = File.join(@@path_to_resources,"add_A.png")
                                @commandA.large_icon = File.join(@@path_to_resources,"add_A.png")
                                @commandA.tooltip = %Q(Opens Settings SketchUp)
                                @commandA.status_bar_text = %Q(Opens Settings SketchUp)
                                @commandA.menu_text = %Q(Opens Settings SketchUp)
                                cc_menu.add_item(commandA)
                                tb.add_item(commandA)
                                @commandB = UI;;Command.new("mode1"){ ClickWindow.cmdB()}
                                @commandB.small_icon = File.join(@@path_to_resources,"add_B.png")
                                @commandB.large_icon = File.join(@@path_to_resources,"add_B.png")
                                @commandB.tooltip = %Q(Opens Settings SketchUp)
                                @commandB.status_bar_text = %Q(Opens Settings SketchUp)
                                @commandB.menu_text = %Q(Opens Settings SketchUp)
                                cc_menu.add_item(commandB)
                                tb.add_item(commandB)
                                tb.restore
                                file_loaded(__FILE__)
                                def self.cmdA()
                                model_def = model_definition['Box']
                                model_def.set_attribute 'dynamic_attributes','mode', '1'
                                model_def.set_attribute 'dynamic_attributes','_mode_label', 'mode'
                                model_def.set_attribute 'dynamic_attributes','_mode_units', 'STRING'
                                model_def.set_attribute 'dynamic_attributes','_mode_access', 'TEXTBOX'
                                @commandA.set_validation_proc{MF_GRAYED}
                                @commandB.set_validation_proc{MF_DISABLED}
                                ### you say you want vice vers affects from the two toolbar buttons ! ?????
                                def self.cmdB()
                                model_def.set_attribute 'dynamic_attributes','mode', '2'
                                @commandA.set_validation_proc{MF_DISABLED}
                            Error message:
                            Error: #<NameError: undefined local variable or method `commandA' for TesteCube::ClickWindow:Module>
                            There is a problem with "@" because without it, there is no error.
                            Or are my mistakes?
                            Thank you
                              kaas
                              Just looking at the error: Error: #<NameError: undefined local variable or methodcommandA'`
                              My guess would be you forgot to add the @ in these lines. If you don't add it, the commandA is not initialized/set.
                                As @kaas succinctly says...
                                Your code is full of typos or un-corrected errors. 😕
                                Please proofread more closely [see below]...
                                Also learn to read the error messages - where the reference or the line is given in the error-message in the Ruby Console...
                                If you have Notepad++ and still can't locate the erroneous line, then you could select a variable's name and use 'find' to 'mark' all matching strings in your code.
                                Any strings with a similar, BUT not exactly-matching, name can be found using a 'find' etc...
                                This is an issue of attention to detail and care, rather than understanding how the code might work...
                                5/10 😮
                                  TNTDAVID
                                  Thanks you kaas for your advices.
                                  I added the "@", and there is always the same error message.
                                  Or are errors frape TIG?
                                  That surprises me because the code works without any error message if there is no longer the @. 😮
                                  To my typos, you refer to your examples:
                                  I had to correct like this:
                                  @commandA = UI::Command.new("cmdA"){ ClickWindow.cmdA()}
                                  If not, there was a lot of error messages for a single line.
                                  Thank you to tell me that I have errors in my code, I would be happier if you show me. 😉
                                  Thank you
                                  David
                                    OK, gloves off... 😕
                                    You do not seem to be able to understand OR to appreciate good advice...
                                    Many of us had offered tips, which you then ignore - often annoyingly !
                                    In the example code you posted, you use 'commandA' and 'cmdA' with no thought as to what they refer to !!!
                                    One is a 'command' and the other is a 'method' resulting from that command...
                                    So as it is this will certainly fail.
                                    Please learn how to inspect your code, for at least some semblance of order, and correct it...
                                    The rest of us have other lives to lead and work to do - please try to help us to help you................
                                      TNTDAVID
                                      @tig said:
                                      OK, gloves off...
                                      Of course I'm taking your advice and I'm doing my best to move forward.
                                      I voluntarily writing new code, to follow your example, so it is not fair to say things like that. 😮
                                      I did the same thing on your example, "cmdA" is a method of command is "commandeA".
                                      So I do not understand or you see a problem?
                                      Perhaps if you do a simple copy / paste my code with your corrections, it would be much simpler and effective?
                                      It's allow myself to understand my mistakes very quickly.
                                        Sorry I got overwrought. 😳
                                        But you can be very frustrating...
                                        def self.cmdA() is the method that is run by the command @commandA
                                        The reason you make it an instance variable with the @ is that the method should see the reference to the command, without it it will not.
                                        As @kaas highlighted in yellow boxes you [correctly] set up @commandA and later on make a reference to commandA which will not work !
                                        You also make the same error for @commandB...
                                        Please read your code carefully.
                                        With Notepad++ if you select the text @commandA all occurrences of it will be colored.
                                        You can then 'mark' then, then select commandA [sans @] and all will color - including so that were not marked in the earlier step, because of the missing @...
                                          TNTDAVID
                                          TIG no problem. 😉
                                          Indeed "Kaas" had identified the problem!
                                          As a noodle, I did not understand that the "@" missing, should be in brackets.
                                          The solution to the error message is simply this:
                                          cc_menu.add_item (@commandA) tb.add_item (@commandA)
                                          And it's the same for "commandeB".
                                          As this problem is resolved, we can move forward hopefully. 💚
                                          TIG, the line of code:
                                          Does not work!
                                          If there are orders below this line, they will not be executed.
                                          I tried all possible variants, with the "@" among the accolades, but it does not change ...
                                          1.Do you knows why?
                                          Other subject:
                                          The more I discovered the ruby, the more I realize that it is an incredible complexity. 😮
                                          If I write this in ruby ​​consol:
                                          model_def = model_definition['box']
                                          valeur = model_def.get_attribute 'dynamic_attributes','mode'
                                          She references me the value of the "mode" attribute, which exists in the dynamic component, "box".
                                          Let's say the result is 1.
                                          If I add this logic test:
                                          if valeur == 1
                                          puts "MODE 1"
                                          else
                                          puts "MODE2"
                                          He answer each time, "Mode 2".
                                          Or am i completely off base of wall, if who is the safest, or the ruby ​​script is not logical. 😮 😮 😮
                                          2.Can you tell me, how such a thing is possible?
                                          I thank you for your emotional support.
                                          David
                                          1 / 2
