    Real world Wip. Glass sculptures.
    120 Posts 21 Posters 70.5k Views 21 Watching
    • cottyC Offline
      cotty
      I'm surprised how good you can see through the whole glass block...
      my SketchUp gallery
      • pbacotP Offline
        Looks incredible! Is the green color a choice or is that always the result with a huge block of glass.
        • BoxB Offline
          Yes it is remarkable, when correctly laminated the optical quality is almost perfect.
          All clear glass has a colour, usually this greenish tint, sometimes it is a little bluer, but it's not normally noticeable when looked through. If you look at the edge of a piece of glass you will see the colour better.
          You can get several varieties of "white" glass, Saphire, Starfire, Low iron etc. They are expensive and not what we wanted in this case. We had to make sure we were able to get all the glass we needed from one batch so the colour was uniform. I made a sculpture many years back that ended up with a blue stripe through it.
          • BoxB Offline
            A bit of an update, this is what about 1/3 of a block looks like. This is just a dry stack of glass so it is too dense to see deeper than a few layers.
            • daleD Offline
              dale
              Have done lots of glasswork, but this is definitely a masterwork!
              Couple of questions...
              How are you actually attaining the contours?
              I know you mentioned acid shading, are you using hydroflouric acid?
              Are you laminating with a UV glue, or a film laminate?
              Sending links to all my glass buddies, thanks for sharing, this is a fantastic project.
              • BoxB Offline
                Those are some very knowledgeable questions Dale.
                Do you mean, how am I getting the data for the contours or how am I putting the contours on the glass?
                I have 3d scanned two posed models to get very detailed meshes which I have sliced vertically at .5mm . Then I laser engrave those contours onto the appropriate layers.
                We abandoned the acid shading, it confused the image. But no, it wasn't Hydrofluric. That stuff is just too complex to work with on such a large scale. I've used it a great deal over the years, seen the results of a tiny splash, a leaky respirator etc and didn't want to get involved with buckets of it for this job. We used the simpler version, Armour Etch, still dangerous, but thankfully not needed now.
                The laminating process is quite involved and isn't just one or the other. We have had to develop a unique combination of techniques and glues specifically for this job. UV would be no good as the Sculptures will be outside in a fairly harsh environment. The expansion and contraction of such a large block would tend to tear the layers part, the glue wouldn't fail but the glass would.
                So I've had to use a system that allows the whole block to flex, breath and enjoy the snow and sun on its face. It has been something of a challenge.
                  db11
                  Really spectacular work. Love the test block with the head, such a cool effect.
                  Looking forward to seeing the final result.
                  • daleD Offline
                    dale
                    Well I don't think there is anything more fascinating than projects that require you to push boundaries and invent new processes. This one must really be satisfying.
                    I worked with Hydroflouric for many years, and remember being told by an old glass master whom I very much admired that all of his contemporaries that had worked the acid baths in Germany where he had trained had passed in one way or another from their work with it.
                    And yes,glass is interesting in its relationship to other materials and its environment in terms of Coefficient of lineal expansion. I can see how a block of glass the size you are working with would be a head scratcher.
                    Please keep us updated as you go forward.
                      crazy result!
                      where is it going to be viewable?
                      • tuna1957T Offline
                        tuna1957
                        the head in the block video is frightening me 😲 !!!! πŸ‘
                        • pmolsonP Offline
                          pmolson
                          As I was going through this thread, I realized my heart rate and respiration were actually increasing.
                          This is exciting!
                          paul
                          • BoxB Offline
                            Will do Dale.
                            Practically around the corner from you Rich, they are for a new hospital being built in Bendigo http://en.wikipedia.org/wiki/Bendigo
                            There have been many different reactions to that video, but the real thing is somewhat different as your eyes don't quite see the same things a camera does.
                            Mine do that every day, I dream about these monsters and their problems every night and won't sleep through comfortably until they are safely installed.
                            • BoxB Offline
                              A bit of a milestone today, finished all the cutting, polishing and etching.
                              So we have 172 sheets of decorated glass that just need to be stuck together, no problem.
                              So this is what 6 metric tons of glass look like, and the space we have to work with it.
                              • Bryan KB Offline
                                Excellent photos and nice looking workshop. Thank you for the pictures. πŸ‘
                                  Seriously impressive, I bet it took a lot of dedication.
                                    it's gonna look insane when it's together and lit.
                                    when they unveiling? need to book tickets to go to bendigo
                                    • BoxB Offline
                                      Still don't know when, there have been some delays on their end and some hiccups on my end...
                                      But steal a loaf of bread or rustle a sheep or two and you'll be out here in no time.
                                      • bazB Offline
                                        baz
                                        Haven't been to Bendigo for yonks, might have to detour there on my next trip north.
                                        • BoxB Offline
                                          Moving into the next stage, the lamination process.
                                          Some awfully big and temperamental machines.
                                          Here we will be heat bonding batches of six layers together to form 28 200kg blocks.
                                          These will then be cold bonded to create the final two block.
                                          Here's a couple of pics to give the lie of the land.
                                          Sorting the sheets.
                                          The big double pizza ovens.
                                          The damn glass washer that is louder than a jet taking off from the roof, which has been non functional for two weeks waiting for a tiny electrcal component to arrive.
                                          The vacuum sealing hot bed.
                                          ![One 200 kg test lump of glass loaded on the final gluing rack.
                                          And yes, all the racks you see here have been designed and constructed using sketchup.](/uploads/imported_attachments/H30m_5.jpg "One 200 kg test lump of glass loaded on the final gluing rack.
                                          And yes, all the racks you see here have been designed and constructed using sketchup.")
                                          • andybotA Offline
                                            andybot
                                            looks like a very painstaking process, bet it will look pretty incredible when complete.
                                            • 3 / 6
