    Trouble undoing a joint push pull command
    4 Posts 4 Posters 626 Views 4 Watching
      cuttingedge
      I have a model with lots of faces (less than a hundred) which i need to jointly extrude. i run Joint-push-pull and while the preview is almost real-time, the process took so long to complete. But when I wanted to undo the command (which is supposed to be one command). It simply wont undo and therefore messing up my geometry. Wish there's a better way to do this.
      • Rich O BrienR Online
        I think if you found a limitation or error in using JPP you should probably mention it in the JPP thread so Fredo can respond to it.
        • JQLJ Offline
          JQL
          Also make sure you have the Outliner window hidden or shut down before you use JPP. It will slow down JPP to a crawl if open.
          www.casca.pt
          Visit us on facebook!
          • fredo6F Offline
            Well, difficult to tell without seeing the model and having something reproducible.
            In any case, this is not intended and would be a bug
