    [Plugin] QuadFaceTools
    673 Posts 116 Posters 499.3k Views 116 Watching
      Carto
      Hello ThomThom,
      I'm currently attempting to size a UV texture using the UV Mapping tool with standard measurements (i.e inches 12", 12") but the value is ignored when typed. Did I type the values correctly or miss something else? Thanks.
      Regards
        Hm... can you share a sample model? Maybe it's related to model units or something. (which version of QFT do you have?)
          Carto
          Hello ThomThom,
          See attached model. I have the latest version 0.11.0
          UV_Example.skp
            Oh, I see now. The input is accepting input as relative scale - not model units. The input currently represent how many times the texture tiles across the X and Y UV axes.
              Carto
              Hello ThomThom,
              Thank you for looking at this. I was just converting from metric to standard, but it would be convenient if you could enter the actual model units. Thanks again for a great plugin.
              Regards
                Version 0.12.0
                • Made OBJ importer create groups from OBJ groups.
                • Made OBJ importer correct SketchUp's "auto-orientation" of faces which was some times confused by internal faces.
                  Version 0.12.0 was made to allow OBJs exported using Mineways read properly in SketchUp:
                  Mineways
                  (www.realtimerendering.com)
                  • eneroth3E Offline
                    eneroth3
                    This is my home in minecraft 😄 . This really works and it's amazing! Some manual labor was needed to clean up the edges between blocks but that's fine, the plugin does a great job!
                    3D Warehouse
                    (3dwarehouse.sketchup.com)
                    My website: http://julia-christina-eneroth.se/
                      kaas
                      Anyone uses OffsetLoop? Whats the best way to use it? I'm getting mostly crashes / bugreport Oops-loops with 0.12.
                        Got a sample model? Screenshot?
                          kaas
                          Just a simple box and there we go again. If nobody else has problems I guess its a clash with other plugins. I will try to do a clean install for all my plugins soon.
                            Doesn't have to be a clash. The offset tool is a recent one that was more of an experiment. I had it hidden for a while but people insisted it should be visible by default. But it will have some problems still. I have an open issue to improve or rewrite it.
                            That being said - I wasn't able to reproduce your exact scenario. Can you share the model please?
                            Also, what version of the extension do you have?
                              kaas
                              I'm using
                              QFC 0.12.0
                              TTlib 2.10.6
                              I attached a file. The shape doesn't really matter though - sometimes it crashes on me on a simple box...
                              Edit 10-10-2016: just cleaned my plugin directory. Installed TT_lib2, QFT, Selectiontoys and tested again. Same crashes so I would suspect no clashing plugins.
                              qft_oops.skp
                                Hmm.... I cannot reproduce on this one either. Can you do a video capture to show your steps?
                                  kaas
                                  Here you go - shocking isn't it? I'm thinking I'm wasting your time. There must be something wrong at my end. Although it is strange; only TTlib2, QFT, Selection toys installed (all fresh from SketchUcation tools & TTlib2 from Extension warehouse). SU-pro 16.1.1449 64 bit.
                                  Edit + pic: it also crashes after adding a few loops and at some point it doesn't detect the loop anymore (blue line) and...ooops
                                  qft_oops.avi
                                    Hmm... have you submitted the reports? Did you include your name/email other info?
                                    Also, what version of Internet Explorer do you have installed? The error reporting dialog looks odd.
                                      kaas
                                      I have submitted only a very few (user name Max). Sometimes it caused an oops-loop and I didn't report those either.
                                      I'm running win7 x64 on my desktop with IE11.0.9600.18449
                                        I see the issue now. It's when you offset only one edge.
                                        https://bitbucket.org/thomthom/quadface-tools/issues/103/offsetloop-errors-when-selecting-only-one
                                        I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge.
                                        https://bitbucket.org/thomthom/quadface-tools/issues/104/offsetloop-missing-edges
                                          kaas
                                          .. I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge...
                                          Both true. Glad you could reproduce the issue. I'm a bit confused nobody has noticed this before. The offset tool itself could be quite useful.
                                            As it is now, consider the OffsetTool an alpha-version. I would not have exposed it yet had it not been for being persistently nagged to do so. 😉
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 33
                                            • 34
                                            • 19 / 34
