    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 537.0k Views 102 Watching
    • fredo6F Offline
      @rombout said:
      In the settings there is a option for thrupaint to activate it when native tools are used. Does this mean thupaint popups when we use the bucket tool? If so on mac using su2015 it doesnt show?
      There is a icon, showing letter A, in the toolbar for auto launch.
      Note that if you click again on the toolbar icon of ThurPaint, you will launch the native Bucket tool. Same with shortcuts (say B). If you are in Auto mode, then typing B twice will launch the native bucket tool.
      • romboutR Offline
        rombout
        Thanks I'll check if I can find that. I thought that option being checked already would launch thrupaint together with bucket.
        • romboutR Offline
          rombout
          Aha, got it. i was looking in the main toolbar. thanks!
          Its still a bit tiny on mac but the retina settings do work, i cant set them any bigger right?
          • Z Offline
            Zekiuar
            Thank you
            • romboutR Offline
              rombout
              i got a question about using the visual editor. Im using this on mac su2015.
              When i want a texture to scale in U and press alt (option) left click i get the editor. When i try to use the sliders for the U and V, im having a hard time getting them to actually do something. Most of the time i need to click a couple before i get it to work.
              Im working on macbook pro mid 2015
              How can i use this editor with the U and V sliders without the texture getting skewed by QuadUV mesh option?
              • romboutR Offline
                rombout
                Wondering if you still thinking about getting the material selector to work better on mac. It really a pain in the ass to work with it now πŸ˜„
                • fredo6F Offline
                  @rombout,
                  On Mac with high-resolution screens, I am afraid that it's not possible to change the text size for the palette button.
                  However, for the gizmo to modify texture size and orientation, it should work normally. Note that for resizing in U and V, you can use the arrow keys (keep them pressed).
                  For the material editor on Mac, this is a big task, and I think it would be up to the Sketchup team to improve it (as well as the underlying API).
                  • romboutR Offline
                    rombout
                    I do have some hard times when i want to work with the gizmo, but i think i should check some tuts about this again.
                    Yes the main issue is selecting materials. Using the tab to switch is sort of annoying cause it jumps through the list without a normal pattern. Not sure why the API is that different then from Windows machines.
                    Probably need to wait till they fix it.
                      povuser
                      Visual Editor - U-Scale V-Scale Sliders Have Disappeared
                      I was having quite a good time with Thrupaint when for some reason, the scale-u and scale-v sliders in the visual editor disappeared and I can't figure out how to get them back. I have the sliders for translation, uniform scale, and rotation, but the sliders that normally appear in the middle of the axis are no longer there. I thought maybe it was because the material I was using had its aspect ratio locked in the SU material creation panel, but that didn't seem to work. I've tried various different modes in Thrupaint, but to no avail. Also tried repainting with default null material, restarting sketchup, etc.
                      I think (?) I read somewhere something about uv scaling options being unavailable in natural mode, but I swear (90% at least) that I had this working in natural mode. I might be remembering wrongly.
                      Edit - When the problem with the Visual Editor is present, shift arrows do not work either for separate u and v scaling. Shift-any arrow uniformly scales the texture. The VCB does however work, but is no good for fine work.
                      Does it sound like another plugin might be capturing or interfering with things? But its hard to believe that would affect the visual editor widget.
                      Using Windows 7, SU 2015Make
                      Any ideas?
                      Thanks,
                      Dave
                      A.K.A. DavePSB
                      i7-4790 3.6GHz (32 Gb) / Nvidia GTX980Ti (6Gb) (Driver 372.70) / Win 7 Ultimate 64bit / SketchUpMake 2015 15.0.9350 / Blender 2.77a
                      • fredo6F Offline
                        It is true that non-uniform scaling is not available for Natural mode (essentially because Natural mode does not assume any particular reference orientation of the surface, as opposed to QuadMesh and Projection)
                          povuser
                          Thanks Fredo. I was just coming back to edit my post after re-reading (more carefully) your intro at the top of this topic that makes it clear separate scaling is not available in normal mode. My bad. Cheers.
                          A.K.A. DavePSB
                          • sicksickisckS Offline
                            sicksickisck
                            Great plugin πŸŽ‰ !! better,faster and more user friendly than sketchUV.. but one..
                            feature request :
                            • preview [mapped] texture out of the polygon* [ like in native skp foto/texture tool editor]
                            *mapped area /tiled
                            • fredo6F Offline
                              @sicksickisck said:
                              feature request :
                              *mapped area /tiled
                              I am not really clear on what you mean?
                                sicksickisck
                                πŸ’š
                                • fredo6F Offline
                                  I am still unclear. The Gizmo is fully interactive and putting a semi-transparent layer would only be aesthetical.
                                  Do I miss anything?
                                  • romboutR Offline
                                    rombout
                                    I think he wasnt a preview of the tiling of the texture, just like native tool
                                    • fredo6F Offline
                                      I think it makes sense for a single face.
                                      I have to see what can be done for a surface; not trivial anyway.
                                        sicksickisck
                                        "I think he wasnt a preview of the tiling of the texture, just like native tool"
                                        kind of 😎
                                        it would be nice, to see all texture when I move a gizmo;
                                        "tiling" is nice option too;
                                        "I think it makes sense for a single face.
                                        I have to see what can be done for a surface; not trivial anyway"
                                        Yeah I think this is not easy mode thing πŸ˜› ;
                                        Thanks! for the reply anyway ;
                                        • fredo6F Offline
                                          That would be very difficult because
                                          • in Ruby, you can draw a picture (i.e. the texture png). So I would have to create a temporary fake face with the right dimensions to show the texture
                                          • again, would work for one face but not for several.
                                            sicksickisck
                                            thats would be helpful too, because sketchup native texture manipulator sux at all..
                                            Thanks.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
