    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 602.7k Views 102 Watching
      rv1974
      @desertraven said:
      Dead end?
      Take sketchuv of Whaat and do 'triangulate'. 3ds will be exported with one texture.
      • fredo6F Offline
        @hsrhdrehre5654654 said:
        Hi, im really happy about this tool, but i have a slighty problem.
        Is there any way to disable the "auto join" feature???? i mean, when im painting, everything is great, but when two paths join, the texture scale/direction gets messed up and the whole thing looks really bad. SO i need to paint from scratch in those zones and continue painting. Curious thing is, before thrupaint treats the painted zone, everything looks great, but as i said, when you release the mouse button to join two patchs, everything mess up. If i couuld just deactivate that feature... it will be perfect. Other wise, there are always seams and different parts in the painted texture πŸ˜•
        Do you have an example. I am not sure to understand what is the "auto-join" feature and the junctions of 2 paths.
        • H Offline
          hsrhdrehre5654654
          The problem i probably dont know how to explain better in english. When you are painting, the way thrupaint works is you make a selection of the zone you want to paint (holding themouse while you paint) and when you release the mouse, thrupaint "tries" to correct the texture scale/position in some faces. This produces terrible results in some faces affected by the painted zone, and the whole thing is useless.
          I dunno how to explain it better, i will try to post a screenshot later.
          Its not something weird, im pretty sure everyone is having this problem. At least, im having in using it on complex meshes modelled with artisan. My guess is, in a low-polygon model, you dont get to notice it, but when you paint extensive zones happens very often.
          • H Offline
            hsrhdrehre5654654
            Is there any way to disable the "auto join" feature???? i mean, when im painting, everything is great, but when two paths join, the texture scale/direction gets messed up and the whole thing looks really bad. SO i need to paint from scratch in those zones and continue painting. Curious thing is, before thrupaint treats the painted zone, everything looks great, but as i said, when you release the mouse button to join two paths, everything mess up. If i couuld just deactivate that "feature"... it will be perfect. Other wise, there are always seams and different parts in the painted texture πŸ˜•
            • H Offline
              hsrhdrehre5654654
              Ok, so here is an example of the problem ->
              The only thing to avoid this, is to press CTRL (force re-paint) and start over, but you will lose the uv position and the texture will not be continous. If i try to pick a sample of the material/uv coordinates and try to kept the texture continuity, it wont work either.
              Is there any way to avoid this? thanks in advance.
                rv1974
                I'm struggling (unsuccessfully) to get the desired result (see the bottom variant- no distortions, continuity, aligned to the edge, one click solution)
                Is it possible with this tool?
                If not, may this mode be added?
                Thank you.
                Edit: Actually, there IS a defect with the bottom variant (BTW it was made by default with PB)- sometimes it can't keep contiguity in corners- it applies UV's anew each sector).
                kkk.zip
                • romboutR Offline
                  rombout
                  In the settings there is a option for thrupaint to activate it when native tools are used. Does this mean thupaint popups when we use the bucket tool? If so on mac using su2015 it doesnt show?
                  • fredo6F Offline
                    There is a icon, showing letter A, in the toolbar for auto launch.
                    Note that if you click again on the toolbar icon of ThurPaint, you will launch the native Bucket tool. Same with shortcuts (say B). If you are in Auto mode, then typing B twice will launch the native bucket tool.
                    • romboutR Offline
                      rombout
                      Thanks I'll check if I can find that. I thought that option being checked already would launch thrupaint together with bucket.
                      • romboutR Offline
                        rombout
                        Aha, got it. i was looking in the main toolbar. thanks!
                        Its still a bit tiny on mac but the retina settings do work, i cant set them any bigger right?
                        • Z Offline
                          Zekiuar
                          Thank you
                          • romboutR Offline
                            rombout
                            i got a question about using the visual editor. Im using this on mac su2015.
                            When i want a texture to scale in U and press alt (option) left click i get the editor. When i try to use the sliders for the U and V, im having a hard time getting them to actually do something. Most of the time i need to click a couple before i get it to work.
                            Im working on macbook pro mid 2015
                            How can i use this editor with the U and V sliders without the texture getting skewed by QuadUV mesh option?
                            • romboutR Offline
                              rombout
                              Wondering if you still thinking about getting the material selector to work better on mac. It really a pain in the ass to work with it now πŸ˜„
                              • fredo6F Offline
                                @rombout,
                                On Mac with high-resolution screens, I am afraid that it's not possible to change the text size for the palette button.
                                However, for the gizmo to modify texture size and orientation, it should work normally. Note that for resizing in U and V, you can use the arrow keys (keep them pressed).
                                For the material editor on Mac, this is a big task, and I think it would be up to the Sketchup team to improve it (as well as the underlying API).
                                • romboutR Offline
                                  rombout
                                  I do have some hard times when i want to work with the gizmo, but i think i should check some tuts about this again.
                                  Yes the main issue is selecting materials. Using the tab to switch is sort of annoying cause it jumps through the list without a normal pattern. Not sure why the API is that different then from Windows machines.
                                  Probably need to wait till they fix it.
                                    povuser
                                    Visual Editor - U-Scale V-Scale Sliders Have Disappeared
                                    I was having quite a good time with Thrupaint when for some reason, the scale-u and scale-v sliders in the visual editor disappeared and I can't figure out how to get them back. I have the sliders for translation, uniform scale, and rotation, but the sliders that normally appear in the middle of the axis are no longer there. I thought maybe it was because the material I was using had its aspect ratio locked in the SU material creation panel, but that didn't seem to work. I've tried various different modes in Thrupaint, but to no avail. Also tried repainting with default null material, restarting sketchup, etc.
                                    I think (?) I read somewhere something about uv scaling options being unavailable in natural mode, but I swear (90% at least) that I had this working in natural mode. I might be remembering wrongly.
                                    Edit - When the problem with the Visual Editor is present, shift arrows do not work either for separate u and v scaling. Shift-any arrow uniformly scales the texture. The VCB does however work, but is no good for fine work.
                                    Does it sound like another plugin might be capturing or interfering with things? But its hard to believe that would affect the visual editor widget.
                                    Using Windows 7, SU 2015Make
                                    Any ideas?
                                    Thanks,
                                    Dave
                                    A.K.A. DavePSB
                                    i7-4790 3.6GHz (32 Gb) / Nvidia GTX980Ti (6Gb) (Driver 372.70) / Win 7 Ultimate 64bit / SketchUpMake 2015 15.0.9350 / Blender 2.77a
                                    • fredo6F Offline
                                      It is true that non-uniform scaling is not available for Natural mode (essentially because Natural mode does not assume any particular reference orientation of the surface, as opposed to QuadMesh and Projection)
                                        povuser
                                        Thanks Fredo. I was just coming back to edit my post after re-reading (more carefully) your intro at the top of this topic that makes it clear separate scaling is not available in normal mode. My bad. Cheers.
                                        A.K.A. DavePSB
                                        • sicksickisckS Offline
                                          sicksickisck
                                          Great plugin πŸŽ‰ !! better,faster and more user friendly than sketchUV.. but one..
                                          feature request :
                                          • preview [mapped] texture out of the polygon* [ like in native skp foto/texture tool editor]
                                          *mapped area /tiled
                                          • fredo6F Offline
                                            @sicksickisck said:
                                            feature request :
                                            *mapped area /tiled
                                            I am not really clear on what you mean?
                                            • 16
                                            • 17
                                            • 8 / 17
