    Real world Wip. Glass sculptures.
    120 Posts 21 Posters 60.5k Views 21 Watching
    • BoxB Online
      I'm in the process of creating two life size figures inside blocks of glass.
      In simple terms we are using layers to create the contour lines that will make up the details of the 3d image.
      The concept is two figures floating in blocks of water.
      So i thought I'd add a few images here as we go.
      This image is both of them full size, all layers laser etched onto card. These will hang on the wall as reference.
      Over the next few months these layers will be translated into glass, and eventually into two glass blocks weighing in at 3 metric tonnes each.
      So if you are wondering why I'm not around too much.....
      • ntxdaveN Offline
        ntxdave
        What an undertaking!! Hope you will share the finished project with us. My guess is that it will be amazing.
        • tuna1957T Offline
          tuna1957
          Box, this is just crazy !!!! crazy cool.
          • cottyC Offline
            cotty
            Let's hope you're not the person on the right πŸ˜‰
            Impressive project, I'm looking forward to updates here!
            my SketchUp gallery
            • BoxB Online
              Here's an early sample/test hand as proof of concept.
                Looks amazing, nicely done.
                  Cool! 😎
                  There is an optic effect at the first image! πŸ˜‰
                  Feet seems flipped! So very perturbating! 😲
                  Pareodoly advanced! πŸ’š
                  • BoxB Online
                    Is it a head in a block or just a blockhead.
                    • Rich O BrienR Online
                      that's crazy!
                      is it hollow? like a mould?
                      • BoxB Online
                        No, it is solid. It's basically a topographic map of the head. Same basic idea as a 3d terrain.
                          So is each pane etched with the contour?
                          Really cool project.
                          • BoxB Online
                            Yep, there are 100 layers per figure, each with the contour line plus acid shading. The shading isn't in the samples.
                              Glass are moving or it's pasted ?
                              • BoxB Online
                                Not the best quality image as it's only a phone photo.
                                We've been working the contours to add detail, it seems to be coming together nicely.
                                  What app are you using? Hats off if it's SU. Looks like a dense mesh.
                                  • andybotA Offline
                                    andybot
                                    wow, very cool! Will the contours be closer together (relative to the shapes) in the full version? The contours are a bit distracting imo in the block head.
                                    • BoxB Online
                                      Yes. Block head was a low res sample.
                                      • BoxB Online
                                        Rich, we are jumping around various programs to get the data sliced, diced and tweaked. And one of the most rediculous things is we still need to move it all to an XP pc as the laser software still hasn't moved with the times.
                                        I did once import the male figure obj into SU, it took more than 24 hours. It would orbit but anything else was impossible.
                                          Wow! I'd love to see you working on this in person.
                                          • BoxB Online
                                            Pop over to Sydney before December and you can see it in process and enjoy an amber fluid or two. You would also see who Box is in reality.
                                            • 1 / 6
