    Unwanted line snapping
    11 Posts 4 Posters 911 Views 4 Watching
    • alllA Offline
      alll
      This is my first post, long time hobby user of su.
      Something really annoying. Lines get automatically joined even when i don't want it! (see video)
      I make small pieces (1/10mm precision needed) for 3d printing.
      Is there something to prevent this?
      Thanks,
      manu
        Model 100x larger then scale down.
        SketchUp doesn't like small dimensions.
        • alllA Offline
          alll
          Should i draw in meters (model units) or just enter big numbers without using decimal precision?
          so 1 mm i draw 1000mm instead?
          Strange, is there a valid explanation to this behavior? How does su handles this?
          Thanks for your quick reply.
          manu
          • alllA Offline
            alll
            still no luck!
            • alllA Offline
              alll
              on a mac
                slbaumgartner
                Do you have length snapping enabled in the model info->units setting?
                • alllA Offline
                  alll
                  Setting my units to meter and these precision, i found a work around ?.??...
                  https://mail.google.com/mail/u/0/?ui=2&ik=05f660f83b&view=fimg&th=157136caf02651e8&attid=0.1&disp=inline&realattid=f_iswznkz20&safe=1&attbid=ANGjdJ8P6xoV2nvxGQPxAW4jhd730u9yN4Wshg42VUoH-B3OG9ZkazUQUDn7PZZakeH_jYKolNsc408teghb7VWyTPC1iXTr9fUikXZU-NBdeMwkFsVP0VKrpNHt-p0&ats=1473512441060&rm=157136caf02651e8&zw&sz=w1920-h988
                  • TIGT Online
                    Please attach your image directly.
                    This method does not work !
                    • alllA Offline
                      alll
                      like this?
                      Measure units are meter, i export in stl and model-units, import in 3d-slicing where units are milimeter...
                      • TIGT Online
                        With 100mm precision ???
                        If you uncheck that - any advance ?
                        • alllA Offline
                          alll
                          If i leave the precision at 0,0000 and snap at 0,1 and set the units to mm, I get the unwanted snapping!
                          Setting the units to meter, keeping 0,0000 and snap at 0,1 it "works"...
                          To summarize:
                          Precision:0.01
                          Snap:0.1
                          Draw 2 // lines L1=1.00”units” and L2=0.98”units” along the x-axis
                          Draw L3 from end of line L1 straight up along z-axis
                          With m (meter) units all is OK!
                          With mm (millimeter) units it screw it up!!!!!
                          So that is why I set units to meters, export to .obj, import into slicing software for 3D printing.
                          If somebody can explain this behavior? Because I still have other artifacts while merging different groups and “outer shell” them or do intersections, flat faces get “distorted” !!!
