    Animation SUalive extension. May you test beta version?
    60 Posts 9 Posters 23.9k Views 9 Watching
    • WhyDiW
      WhyDi
      Hello
      ...<Update each frame> feature and API revamped
      Thanks for your help. I was able to persuade my team and the modified option is now available on SUalive Free version. I extend particular thanks to Alan - reader but not member - and its point that leads us to keep the three options <pure> <undo> and <each frame> then add a <Free Output> item in Run drop down rather than updating the last option. 'HowTo' in API tab on the web site.
      Unfortunately no MAC user. too bad!
      Please note I unsubscribed this topic. SUalive in Plugin Forum replace
      Best Regards
      the devil is in the detail
      • O
        osx59
        On the Mac , I want to participate, provided things work .
        Currently , it is impossible to validate the installation .
        At the launch of Sketchup (2015 or 2016) and it does not work ca Sketchup crash.
        If you have a solution to the problem ...
        http://3dvs.fr/SUalive/Bug-01-Sualive.jpg
        • WhyDiW
          WhyDi
          osx59 Hello!
          Nice website you have!
          Before going further you need to know SUalive was designed on Windows but Mac-users helped such way on this forum that we made the decision their time was worth an OSX version. We want to make that kind of effort and all our best to achieve but we know hardly nothing about MAC which means OSX compatible version might run quickly or take much time before things work.
          With that said I need to know a bit more about the bug as 'load errors' line number and method name are not consistent with your snapshot - probably due to scrambled code. My understanding is license window opened then you checked 'I agree...' checkbox but only 'exit' button was enabled and SketchUp crashed when exiting.
          1 - Am I right?
          2 - Does SketchUp chrashes with bugsplat or only script stops and error message?
          If so this means that 'continue' button stayed disabled even after you checked 'I agre..'
          3 - Am I right?
          French - (il me semble que tu es français!)
          Avant d'aller plus loin tu dois savoir que SUalive visait les utilisateurs Windows mais l'aide et la disponibilité des utilisateurs MAC sur ce forum nous ont amené à faire l'effort d'essayer de produire une version compatible OSX. Nous ferons tout notre possible pour aboutir mais l'issue de ce travail peut être très rapide comme très longue. Je suis totalement incapable de répondre à cette question pour l'instant.
          Ceci dit j'ai besoin de comprendre un peu mieux ton problème car les numéro de ligne et nom de méthode de la fenêtre 'load errors' ne correspondent pas à la copie d'écran license (probablement du fait du scrambler de code). Donc la fenêtre de license s'est ouverte normalement puis tu as coché la checkbox 'I agree...'. Seul le bouton 'Exit' est resté disponible et tu as aboutis sur un crash de SketchUp en cliquant sur ce bouton.
          1 - Ai-je bien compris?
          2 - SketchUp crash avec bugsplat ou seulement arrêt du script avec message d'erreur?
          Ca signifie que le bouton 'continue' est resté indisponible après avoir coché 'I agree..'
          3 - C'est bien ça?
          French or English or both reply. As you wish!
          Réponse en français ou anglais ou les deux, comme tu veux!
          Have a good day
          Bonne Journée
          • O
            osx59
            Bonsoir,
            Effectivement :
            • je suis français (tu as du deviner à cause de mon anglais irréprochable 😉 )
            • Bref, oui tu as tout compris :
            1. installation, sans problème
            2. "Donc la fenêtre de license s'est ouverte normalement puis tu as coché la checkbox 'I agree...'. Seul le bouton 'Exit' est resté disponible" : OUI
            3. J'ai du fermer la fenêtre de licence, car aucun des bouton ne fonctionnait
            4. le crash intervient lors de la ré-ouverture de Sketchup, quelque soit la version (14, 15 ou 16)
            5. J'ai du supprimer manuellement le plugin pour retrouver une utilisation normal de SU
              Voilà, je reste à ta disposition pour tester ce plug car cela fait longtemps que j'attends une animation d'objet intégré.
              Sous SU 8, j'utilisai : https://www.youtube.com/watch?v=brQcAnd3DmA, qui n'existe plus
              Donc "wait and see" avec impatience 😉
              Vincent
            • WhyDiW
              WhyDi
              Bonjour Vincent
              C'est ton site m'a donné ta langue!
              pourrais-tu lancer le script ci-dessous sur ton mac? l'image te montre ce qu'il est sensé faire.
              English readers
              Your website told me you are French!
              may you run the following script on the mac? picture tell you what it should show
              ruby script
              what the script should do
              script content
              require 'sketchup'
              module YDco_debug;module YDalv
              	class Dlg_debug < UI;;WebDialog
              		def initialize()
              			super "SUalive debug", false, "SUalvDebug", 512, 256, 100, 50, false
              			str_html = '<html><head>' +
              				'<meta http-equiv="content-type" content="charset=UTF-8">'+
              				'<meta http-equiv="MSThemeCompatible" content="Yes">'+
              				'<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">'+
              				'<script type="text/JavaScript">'+
              				'function jsDebugSwitch(obj){document.getElementById("btn").disabled=!obj.checked}'+
              				'function jsDebugTellMe(obj){alert(obj.id)}'+
              				'</script>'+
              				'</head><body>'+
              				'<input type="checkbox" onclick="jsDebugSwitch(this)">check me please ' +
              				'<button id="btn" style="margin-left; 7px" onclick="jsDebugTellMe(this)" disabled>tell me</button>' +
              				'</body></html>'
              			set_html(str_html)
              			show_modal
              	puts "Start debug ------------------------------------------------" + RUBY_VERSION.to_s
              		dlg = Dlg_debug.new()
              	puts "--------------------------------------------------------debug End"
              end;end
              • O
                osx59
                J'ai lancé le script via la consol Ruby, car sur mac les extensions c'est .rbz (.rb sur pc)
                Effectivement le script marche sans problème, si non rien de changé coté SUalive.
                Vincent
                • WhyDiW
                  WhyDi
                  Bonjour Vincent,
                  Essaie celui-ci maintenant. rb script renommé rbz
                  tu devrais voir 'return false' dans la console
                  English readers
                  Try the following now. rb file renamed rbz
                  console should show 'return false'
                  script rbz renamed
                  what it should do
                  require 'sketchup'
                  		def initialize()
                  				'function jsDebugSwitch(obj){document.getElementById("btnContinue").disabled=!obj.checked}'+
                  				'</script>'+
                  				'</head><body>' +
                  				'<div style="width; 496px; font-family; Arial">' +
                  				'<div style="border; solid 1px #CECECE; padding; 0px 10px 0px 10px; ' +
                  						'font-family; Arial; font-size; 14px; width; 470px; height; 150px; ' +
                  						'text-align; justify; overflow; auto">'+
                  				'Lorem ipsum dolor sit amet, consectetur adipiscing elit. Aliquam gravida nunc metus, '+
                  				'id vulputate metus rutrum at. Curabitur et pretium arcu. Morbi vehicula arcu a nisl ' +
                  				'consequat, non vulputate ligula congue. Aenean sit amet orci nec leo cursus tempus. '+
                  				'Nulla facilisi. Mauris vestibulum elit magna, ut pellentesque enim tincidunt placerat. '+
                  				'Nunc volutpat varius maximus. Praesent bibendum convallis tellus ut fringilla. '+
                  				'Vestibulum dignissim lacinia sapien, sed porttitor justo dictum quis. Curabitur laoreet '+
                  				'nisl nunc. Ut egestas magna eget laoreet gravida. '+
                  				'</div>' +
                  				'<div style="width; 482px; margin; 20px 7px 0px 7px; font-size;smaller">' +
                  							'<div style="float; right">' +
                  								'<button id="btnContinue" style="margin-right; 7px" onclick="jsDebugTellMe(this)" disabled>Continue</button>' +
                  								'<button id="btnExit" onclick="jsDebugTellMe(this)">Exit</button>' +
                  							'</div>' +
                  							'<input type="checkbox" onclick="jsDebugSwitch(this)">Check me please' +
                  						'</div>' +
                  					'</div>' +
                  				'</body></html>'
                  			set_html(str_html)
                  		def load_dialog()
                  			show_modal
                  			return false
                  		end#def
                  	lics = YDalv;;Dlg_debug.new()
                  	if lics.load_dialog()
                  		puts "Dlg_debug returns true"
                  	else
                  		puts "Dlg_debug returns false"
                  end;end
                  bonne journée
                  have a good day
                  • O
                    osx59
                    Résultat :
                    http://3dvs.fr/good.jpg
                    Vincent
                    • O
                      osx59
                      Ok tout va bien jusque là !
                      Si tu cherche quelqu'un sur Mac pour tester la version full
                      je suis candidat 😉
                      http://3dvs.fr/good-1.jpg
                      • WhyDiW
                        WhyDi
                        Bonjour Vincent,
                        et maintenant celui-ci s'il te plait!
                        Même script que ci-dessus mais ferme la fenêtre et affiche la valeur de retour dans la console.
                        EN:
                        And now the following please!
                        Same script than above but closes window then shows result in console
                        script rb
                        what it is meant to do
                        code
                        require 'sketchup'
                        		def initialize()
                        				'function jsDebugTellMe(obj){var isOK=(obj.id=="btnContinue");alert(isOK);window.location="skp;qwerty@"+isOK}'+
                        				'</script>'+
                        				'</head><body>' +
                        				'</div>' +
                        							'</div>' +
                        						'</div>' +
                        					'</div>' +
                        				'</body></html>'
                        			set_html(str_html)
                        			add_action_callback("qwerty") do |wdialog, str_params|
                        				@is_ok = (str_params == "true")
                        				wdialog.close()
                        		def load_dialog()
                        			show_modal
                        			return @is_ok
                        		end#def
                        	else
                        end;end
                        Bonne après-midi
                        Regards
                        • O
                          osx59
                          Bonjour,
                          Bon, là par contre, nada ... rien ne ce passe hormis l'apparition du script dans la console Ruby ...
                          V
                          • O
                            osx59
                            Heuuu, pardon, autant pour moi ... mais ça me semble très léger ...
                            Start debug ------------------------------------------------2.0.0
                            with ENV[*].nil?
                            USERPROFILE true; HOMEDRIVE true; HOMEPATH true; HOME false
                            with ENV.all.keys
                            TMPDIR;__CF_USER_TEXT_ENCODING;HOME;SHELL;Apple_PubSub_Socket_Render;
                            SSH_AUTH_SOCK;PATH;LOGNAME;DISPLAY;XPC_SERVICE_NAME;USER;XPC_FLAGS;
                            IG_ROOT;GEM_PATH;GEM_HOME;RLM_DIAGNOSTICS;RLM_ROAM;
                            with user_home
                            path /Users/iMac27-Y
                            • WhyDiW
                              WhyDi
                              Bonjour Vincent,
                              Nous parlions justement de toi hier soir, ton site ainsi que de tes animations et les vidéos que tu publies. Nous nous demandions si tu accepterais de tester SUalive Full. Donc je suis ravi de t'accueillir dans notre SUaliveDreamTeam. SUaliveDreamTeam est l'endroit idéal pour rêver de modèles SketchUp quittant l'espace restreint de leur écran pour prendre vie en trois dimensions devant nos yeux éblouis. Dans la réalité notre ambition principale est de permettre à chaque utilisateur l'animation de son modèle. Quel boulot!
                              Pour l'instant j'espère simplement que la compatibilité Mac soit possible.
                              Peux-tu lancer le script suivant afin de vérifier la variable d'ENVvironnement de ton système?
                              EN
                              We were talking about you yesterday evening and your website and also the animations you turned into video. We all agreed that you are the perfect candidate for SUalive Full version testing. So I am pleased to welcome you in our SUaliveDreamTeam. In SUaliveDreamTeam We most of time dream about SketchUp model jumping out the computer screen and coming to life in a virtual space right in front of our eyes opened in wonder. In the real world we work on the daily basis so that every single SketchUp user can animate its model which is our main aspiration. What a job!
                              At the moment I merely hope SUalive can work on Mac.
                              May you run the following script so that checking ENVironement variable of the operating system?
                              ENV check script file
                              Windows ENV
                              code
                              require 'sketchup'
                              	puts "with ENV[*].nil?"
                              	puts "  USERPROFILE " + ENV['USERPROFILE'].nil?.to_s +
                              			"; HOMEDRIVE " + ENV['HOMEDRIVE'].nil?.to_s +
                              			"; HOMEPATH " + ENV['HOMEPATH'].nil?.to_s +
                              			"; HOME " + ENV['HOME'].nil?.to_s
                              	max_line_len = 75
                              	str_line = "  "
                              	puts "with ENV.all.keys"
                              	ENV.each do |key, value|
                              		if str_line.length + key.length + 1 > max_line_len
                              			puts str_line
                              			str_line = "  "
                              		str_line += key + ";"
                              	if str_line.strip.length > 0
                              		puts str_line
                              	user_home = ENV['USERPROFILE'].nil? ? ENV['HOME'] ; ENV['USERPROFILE']
                              	puts "with user_home"
                              	puts "  path " + user_home
                              end;end
                              Have a good week-end
                              Passe un bon week-end
                              • WhyDiW
                                WhyDi
                                Bonjour Vincent,
                                Bien peu d'informations comme tu le dis mais pleines d'intérêt. Suis mon raisonnement! Avons-nous besoin d'une version spécifique à chaque OS ou une seule version multi-plateformes suffirait-elle? je suis incapable de répondre à cet instant. Tes retours à mes questions sont une part cruciale dans la réponse.
                                Les prochains jours te sont consacrés! Nos échanges de la semaine passée devraient aboutir à ce que l'onglet 'Project' s'affiche sur ton Mac.
                                Mais avant pourrais-tu lancer le script ci-dessous s'il te plaît?
                                EN
                                It looks like small amount but is of full use. Follow my way! Do we need SUalive.Win AND SUalive.Mac or does any SUalive.CrossPlatform be able to make the whole job? I really don't know right now. Your returns are key part of the answer.
                                The following days are only for you! we expect our previous week exchange leading you to see the 'Project' tab of SUalive.
                                Before that may you run the below script please?
                                script file
                                what it shows
                                require 'sketchup'
                                		def initialize()
                                				'function jsDebugIsMac(){return navigator.platform.indexOf("Mac")!=-1}'+
                                				'function jsDebugIsWin(){return navigator.platform.indexOf("Win")!=-1}'+
                                				'</script>'+
                                				'</head><body>'+
                                				'<br>'+
                                        '<script type="text/javascript">'+
                                            'var strOut = "with navigator.platform<br>' +
                                                '&nbsp;&nbsp;" + navigator.platform.length + " chars => " + navigator.platform + "<br>' +
                                                '&nbsp;&nbsp;isMac? " + jsDebugIsMac() + "<br>' +
                                                '&nbsp;&nbsp;isWin? " + jsDebugIsWin() + "<br>' +
                                            'end with";' +
                                            'document.write(strOut)' +
                                        '</script>' +
                                				'</body></html>'
                                			set_html(str_html)
                                			show_modal
                                end;end
                                Have a good week
                                Bonne semaine
                                • O
                                  osx59
                                  Voilà la réponse à ton script ...
                                  8 chars => MacIntel
                                  isMac? true
                                  isWin? false
                                  end with
                                  Cela fait-il avancer le Schmilblick ?
                                  V
                                  • WhyDiW
                                    WhyDi
                                    Bonjour Vincent,
                                    Merci. Rassure toi, les choses avancent. Le dernier script permet à une boîte de dialogue de connaître l'OS sous-jacent sans aucun paramètre envoyé à partir de Ruby. Ce n'est probablement pas totalement sûr mais très certainement utile.
                                    Maintenant que tu dois attendre quelques jours avant de connaître le résultat de ton travail je voudrais développer un peu plus avant le processus 'pas à pas'. Nous nous connaissons depuis peu et je comprends très bien que cette manière d'aborder un problème ne t'est pas habituelle, peut-être même un peu ennuyeuse. Mais c'est le moyen le plus rapide de faire fonctionner SUalive sur ton Mac. Tout autre façon d'agir peut conduire à l'empilement et/ou combinaison de bugs. Supposant que tout ce passe bien jusqu'à l'affichage de l'onglet 'Project' j'ai l'intention de te demander de na pas aller plus loin. Je sais que ce qu'une telle requête provoque comme frustration mais fais moi confiance. Le confort de l'utilisateur final est au prix d'un code solide et robuste. Nous passons maintenant plus de la moitié de notre temps de développement à vérifier le fonctionnement de SUalive puis vérifier à nouveau et encore une fois. Après ça quand tout est terminé, tu sais quoi? nous recommençons le processus complet de vérification. Au moindre doute nous reprenons tout à zéro. Tu n'es pas seul, nous aussi avons une idée précise du niveau de frustration provoqué par cette nécessité.
                                    Si tu as des questions, c'est le bon moment!
                                    EN
                                    Thanks. Of course things are moving forward. The last script allows a WebDialog for knowing about the operating system without any parameter sent from Ruby. Probably not fully secure but useful for sure.
                                    Now you have to wait some days before having the result of your work I would like talking a bit about this step-by-step process. We meet not for long and I understand the checking process one step after another may be unusual for you perhaps even a bit annoying but it's the shortest way to quickly make SUalive at work on your Mac. More intuitive way could lead to bugs stacking and/or merging. Assuming things go right up to the 'Project' tab shown I'm going to ask you for not going further. I know how frustrating you will feel with that but trust me. Aiming the end user ease there are no other way to achieve a robust and strong code. We now spend more than half of our full developing time to check then check and check another time SUalive. And after that when finished and before releasing you know what? we restart to check once. If we get in doubt we start another time the full check process. You are not alone we also know about frustration!
                                    If you want to ask for anything. It's the right time!
                                    Best Regards
                                    • WhyDiW
                                      WhyDi
                                      Bonjour Vincent,
                                      La version corrigée est disponible en téléchargement sur le site web. Si le bug a disparu j'aurais aimé que tu me montres une copie d'écran de l'onglet 'Project' (png format si possible) puis que tu cliques sur l'icône menu en haut à gauche et charge la boîte de dialogue 'Preferences' (copies d'écran de chaque onglet si tu le peux). Enfin lance la fenêtre d'aide à partir du même menu (ici aussi une copie d'écran serait bien venue).
                                      Ces trois fenêtres recèlent un foule de détails concernant le code multi-plateformes.
                                      EN
                                      Patched version available on the website. If bug fixed I would have liked you to show me a screen copy of the 'Project' tab - png picture if you can - then click the top-left icon menu and load 'Preferences' - screen copy of each tab appreciated - and finally launch 'Help' from the same menu - here also screen copy would be great!
                                      These three windows hold much as regard cross-platform code.
                                      have a good day
                                      • O
                                        osx59
                                        Bon, retour rapide :
                                        Sur SU 15 : instal ok, puis plus rien, l' extension apparait bien dans le menu correspondant, mais au lancement, affiche toujours la fenêtre de démarrage avec les 2 boutons à valider, puis une fois validée la fenêtre disparait sans
                                        autre menu, icône ou autre renseignement, à l'écran.
                                        Sur SU 16 : là c'est vite fait : plantage de SU dès le lancement (après installation, rien dans le menu correspondant)
                                        Tu devrais mettre les n° de version dans le titre de l'extension, histoire de savoir si c'est vraiment la bonne que je télécharge .
                                        Vincent
                                        • WhyDiW
                                          WhyDi
                                          Bonjour Vincent,
                                          Ce téléchargement n'était qu'un premier essais. Je vais t'envoyer un lien spécifique pour le suivant qui tente de répondre à la question : Où le script stoppe-t-il? Il n'est pas sensé fonctionner mais uniquement écrire des blocs d'identificateurs indentés dans la console Ruby, comme ci-dessous.
                                          Ne perd pas ton temps à tester les deux, Sketchup15 et 16 pour l'instant. Sketchup16 est très suffisant.
                                          EN
                                          The file you downloaded was merely a first trial. I am going to send you a specific link for the next one which aims to answer : Where does the script stop? It is not meant to show but only write indented blocks of identifiers in Ruby console like the following.
                                          Don't spent your time with both Sketchup15 and 16 at the moment. SketchUp16 is far enough!
                                          with Run vX.XX.xxxx
                                            id
                                          end with Run
                                          with Load
                                            id
                                            with Show
                                              id
                                            end with Show
                                            id
                                          end with Load
                                              id
                                          have a good day
                                          • WhyDiW
                                            WhyDi
                                            Hello,
                                            I'm meeting hard-time with Mac OSX!
                                            As you may read Postby WhyDi » Fri Aug 19, 2016 1:24 pm on previous page Vincent ran the script shown and got the right results which means dialogue-box returns True if Osx-user clicks 'continue' and False when 'exit' button clicked. His reply right underneath has lost the picture but he said 'So far so good'.
                                            Based on this result I updated SUalive then sent a copy to Vincent. Didn't work!
                                            I spent nearly a full day trying to catch why and ended up with the script below so that getting a better check. Please note this is the same script than previous page out of Dlg_debug.new() lays inside a Method embedded in two IF blocks.
                                            require 'sketchup'
                                            	class << self
                                            		def main_method()
                                            			puts "main_method() entry point"
                                            			bool_first = true
                                            			if bool_first
                                            				puts "..first true"
                                            				bool_second = false
                                            				if bool_second
                                            					puts "....second true"
                                            				else
                                            						puts "....Dlg_debug returns true"
                                            					else
                                            						puts "....Dlg_debug returns false"
                                            		def initialize()
                                            			puts "......class initializeentry"
                                            				'</script>'+
                                            				'</head><body>' +
                                            				'</div>' +
                                            							'</div>' +
                                            						'</div>' +
                                            					'</div>' +
                                            				'</body></html>'
                                            			puts "......" + str_html.length.to_s
                                            			set_html(str_html)
                                            			puts "......add_callback"
                                            				puts "........callback " + str_params
                                            				puts "........isOk " + @is_ok.to_s
                                            				wdialog.close()
                                            				puts "........close"
                                            		def load_dialog()
                                            			puts "......load_dialog entry"
                                            			show_modal
                                            			puts "......show_modal back"
                                            			puts "......isOk " + @is_ok.to_s
                                            			return @is_ok
                                            		end#def
                                            	puts "call main_method()"
                                            	main_method()
                                            end;end
                                            The script no longer works! always yields False due to WebDialog returns before lics.load_dialog() executed - pictures of return available if you wish. Consistent! may you reply related to show_modal cross-platform difference. Yes it is!
                                            Two points
                                            I'm fully aware of ThomThom wrote in Sketchup WebDialogs - The Lost Manual about show_modal . So
                                            1 - Just for my education on this.
                                            Please tell me why the first script is right and not the second?
                                            2 - Need for SUalive at work on OSX
                                            Is there any way to make WebDialog fully modal on Mac OSX? any workaround? way of coding to achieve?
                                            Have a good week
                                            WhyDi
                                            • 2 / 3
