    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 698.4k Views 121 Watching
    • fredo6F Offline
      NEW RELEASE: FredoTools v2.8a - 09 Jul 15
      FredoTools 2.8a is a minor release for:
      • SolidVolume, which now accepts solids with holes
      • ReportLabelArea, which now computes the correct area removing the space taken by the glued componentss in cut opening mode.
      • fredo6F Offline
        Warning:
        Please upgrade to LibFredo6 6.8c if you installed FredoTools v2.8.
        There is a bug in FredoTools::Convexify, which is fixed in LibFredo6 v6.8c.
        Sorry for inconvenience
        Fred
        • pbacotP Offline
          Thanks Fredo!
          • E Offline
            elvirem
            Hello Fredo, je viens de passer sur skp 2015. J etais sur 2008 et tout allait bien et voici ce qui m'arrive malgré pas mal de tentatives.. ça fait 15 jours que c'est comme ça... et moi SKP sans libfredo, c'est comme si on me coupait un bras...tu saurais ce que je pourrais faire pour telecharger ton plugin et qu il fonctionne ? je suis sous mac yosemite ( non de Dieu que Mavericks me manque!!!)
            Merci de tes lumières.... si tu en as !
            Elvirem
            Erreur de chargement du fichier Fredo6_!LibFredo6.rb
            Error: #<ArgumentError: invalid byte sequence in UTF-8>
            /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in match' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in block (2 levels) in load_from_config'
            /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in each' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in block in load_from_config'
            /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in foreach' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in load_from_config'
            /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in block in load_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in each'
            /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in load_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:786:in load_from_config'
            /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:338:in module:LibFredo6'
            /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in <top (required)>' `
              BIANI patrick
              Where downloading Move along ???????
              • cottyC Offline
                cotty
                It's part of this collection and you can download it at the first post or with the Plugin store.
                Make sure that you have installed LibFredo too.
                my SketchUp gallery
                • JClementsJ Offline
                  JClements
                  VOLUME Calculator.
                  I am getting a very large difference in calculated volumes between what SU displays in the Entity Info and what the volume calculator comes up with. I suspect it is due to a small sized object with many very small facets.
                  Can I send you the model to look it over?
                  Model created in SU2015, 64-bit. Windows 7.
                  • fredo6F Offline
                    Yes. Please send the model.
                    By the way, do you already know which result is the correct one?
                      JClements
                      Please see your messages. Thanks.
                      • E Offline
                        Elster32
                        Is it possible to increase the size of the dialog box? On my screen it is so small it is almost impossible to see the buttons! I wondered whether there was an option but because of the small size I was unable to see it? Thank you
                        • fredo6F Offline
                          NEW RELEASE: FredoTools v3.0a - 20 Oct 16
                          FredoTools 3.0a is a release mainly related to FredoTools::ThruPaint with the introduction of a Purge feature.
                          • fredo6F Offline
                            NEW RELEASE: FredoTools v3.0b - 31 Oct 16
                            FredoTools 3.0b fixes a major bug bug preventing FredoTools to load properly for SU versions < 2014. So, if you run SU6, SU7, SU8 or SU2013, please upgrade to v3.0b.
                              SpookyChick1013
                              Hi Fredo,
                              Thanks for continuing to update your tools.
                              I'm having an issue with ThruPaint where I invoke the tool and it promptly does nothing. Nothing shows in the error console, it just refuses to come up.
                              EDIT:]Woops! Mybad. There is something in the Ruby console.
                              (eval):1: warning: already initialized constant T7
                              Hope this helps.
                              It was working fine for me prior to me updating things over the last two days. I'm using the latest downloads of FredoTools, and FredoLib, right out of the SU Plugin store.
                              I have double-checked the plugin footprint, and it looks like it should look.
                              Still on SU7.1.6860, Win7Prox64
                              Second update.
                              I have no idea why this worked but I unchecked Fredo Tools in the extensions, restarted and now Thrupaint is working just fine, as is everything else. The weird thing is, I did not re-enable The Fredo6 Fredo Tools extension, yet things are working fine. 😲 😕
                              Update weirdness makes my head hurt, 😆
                              I guess there's nothing to worry about after all.
                              Thanks in advance,
                              Cathryn
                              https://kuromatsudriveyards.com
                              Fo-su to tomo ni aran koto o...
                                bharralure
                                Bonjour Fredo
                                Puisque c'est ma journée "réclamations", après LibFredo6, je reviens avec FredoTools.
                                Depuis un certain temps, je ne me souviens plus trop quand d'ailleurs (peut-être depuis ma migration vers Windows 10, il y a seulement quelques mois), la fenêtre qui s'affiche à l'écran après avoir lancé l'outil "Étiqueter les Surfaces" se trouve réduite en hauteur tel que montré sur la capture d'écran qui suit.
                                Ce n'est pas un gros problème, mais dans sa taille d'origine, je suis pas obligé de jouer de l'ascenseur.
                                • fredo6F Offline
                                  This is due to SU2017, which is messing up dimensions in web dialogs.
                                  Can you tell me if you can resize the dialog box?
                                  Fred
                                    bharralure
                                    Non, la boîte de dialogue n'est pas redimensionnable.
                                    • fredo6F Offline
                                      NEW RELEASE: FredoTools v3.0c - 13 Feb 17
                                      FredoTools 3.0c fixes sizing issues for some dialog boxes in SU2017
                                      • V Offline
                                        vlad_s
                                        Good day, does not work markvertex with fredolib 7.3 and 7.5 in windows xp. In fredolib 6.4 worked.
                                        Sorry for the English language, computer translation from Russian.
                                          cadmunkey
                                          Hi Fredo, any reason the Sold Volume calculator would report a solid back as a minus figure?
                                          I took volume calc from my marble model and thought something was strange with the result. So checked individual pieces and some are reporting a minus figure, which of course deducts itself from the final overall result.
                                            Cadmunkey, is it possible the faces are reversed on the volume?
                                            • 23
                                            • 24
                                            • 7 / 24
