    Introducing Viz - parametric modeling for SketchUp
    extensions
    85 Posts 21 Posters 39.8k Views 21 Watching
    • PixeroP
      Pixero
      Can't wait to try it.
        This looks killer.
        Smaller fonts would be nice.
        • F
          fluid
          We just released Viz 0.2.1, you can get it here.
          The biggest feature is the possibility to create and export custom nodes, for reuse and sharing. Adding this feature required a major code rewrite, and forced us to drop the support for files saved in the previous format. In the download page there is a new sample project that includes a custom node.
          Here are the other features:
          • Improved node creation dialog (bigger and resizable), adding the possibility to sort by node category or description.
          • Grouped many nodes into a single one, with the possibility to choose the function performed by the node
          • Added nodes for loading and sampling image files
          • Added a node for loading arrays from text files
          • Added nodes for constant and gradient array creation
          • Added Clamp and Fxy nodes
            A new toy to try! You will ruin my weekend! ๐Ÿ’š
              I am alone to try it ? Works fine but ask a very precise training! ๐Ÿ˜„
              Curious that so many steps are necessary! ๐Ÿ˜ฎ
              You have created all that from zero or have inspiration from some existing systems ?
              PS If possible that new node will be not at the creation under other previous existing nodes
              so on an empty space that will be more cool! ๐Ÿ˜„
              • srxS
                srx
                This is great. I was aware of Grasshopper, but never used it. I learned more about it from the latest Archicad 20 versions which has hotlink to Grasshopper output. These are very important thing happening:
                http://bim42.com/2012/07/geometry-gym/
                If you could integrate IFC in your plugin, you could make Sketchup the best "slim" BIM software just like that.
                Like this:
                https://youtu.be/4n8U-PGmhCk
                And the code is open source:
                http://geometrygym.blogspot.rs/2016/02/openbim-just-became-more-open.html
                www.saurus.rs
                • F
                  fluid
                  We just released a new version of Viz, you can get it here.
                  In this version:
                  • Added smooth shading and texture mapping output into SketchUp
                  • Added a few new nodes, including Extrude
                  • Preliminary Mac support, on SketchUp 2015/2016
                  • Updated sample scenes
                  Here is a tutorial video about extrusions:
                  [flash:2jxsg7a4]https://www.youtube.com/v/_lLORq8ZZo8[/flash:2jxsg7a4]
                    Parametric indeed! ๐Ÿ˜Ž
                    Why not 3D for thickness? (sure we have yet Joint PushPull by Fredo6)
                    • JQLJ
                      JQL
                      In this version:
                      OMG This is getting Huge
                      www.casca.pt
                      Visit us on facebook!
                      • genki.ttG
                        genki.tt
                        Great Update ! I could try on my mac, THX.
                        • F
                          fluid
                          We are writing a getting started manual here.
                          It's still a work in progress and we would like to have your feedback about missing topics or things that need extra clarification.
                            If you are interested by a French version of the guide,
                            if it's not yet existing,
                            i can do it for the fun! ๐Ÿค“
                            Same for the UI - if you have some texts, lists ...for not have to swim in the code! ๐Ÿ˜„
                            French Translation of the guide done! ๐Ÿ˜„
                            • F
                              fluid
                              Thanks Pilou, great job!
                              • F
                                fluid
                                We now have 3d boolean operations in Viz! You can grab the new version here.
                                Version 0.5.0 highlights:
                                • 3d Boolean Operations
                                • Extrude node now works on surfaces as well, to create solids
                                • Added a few more nodes, like CapEdge, ExtractEdge, etc
                                • Updated the getting started guide
                                [flash:umzgk0ah]https://www.youtube.com/v/YJ2gFgG3Mk8[/flash:umzgk0ah]
                                • PixeroP
                                  Pixero
                                  Looking great. ๐Ÿ‘
                                  Now if we can have non destructive quad chamfer/bevel please. ๐Ÿ˜‰
                                    Cool! ๐Ÿ˜Ž
                                    Does it the same is possible with 2 existing solids (not created with nodes) ?
                                    Ps
                                    So I must update my French manual! ๐Ÿ˜„
                                    • F
                                      fluid
                                      @Pixero: added to the todo list
                                      @pilou: Yes, you can use a "GeometrySource" node to get geometry from SketchUp and then perform boolean operations. Keep in mind the solids need to be closed.
                                        French Version Updated! ๐Ÿ˜„
                                          Does the Boolean Viz works with SU MAKE ?
                                          Seems not! Even Union! (Maybe it's different than Envelopp ?
                                          Suggestion : a Box Selection moving for place it for see that is behind! ๐Ÿ˜„
                                          • F
                                            fluid
                                            Did you turn off the preview on node "GeometrySource-1" and "GeometrySource-2"? Otherwise they'll probably cover the result of the boolean operation. Also, you should connect the "Out Geometry" pins to the inputs of the boolean operation, not the "Active" pins.
                                            • 3 / 5
