    Introducing Viz - parametric modeling for SketchUp
    extensions
    85 Posts 21 Posters 39.8k Views 21 Watching
      A new toy to try! You will ruin my weekend! ๐Ÿ’š
        I am alone to try it ? Works fine but ask a very precise training! ๐Ÿ˜„
        Curious that so many steps are necessary! ๐Ÿ˜ฎ
        You have created all that from zero or have inspiration from some existing systems ?
        PS If possible that new node will be not at the creation under other previous existing nodes
        so on an empty space that will be more cool! ๐Ÿ˜„
        • srxS
          srx
          This is great. I was aware of Grasshopper, but never used it. I learned more about it from the latest Archicad 20 versions which has hotlink to Grasshopper output. These are very important thing happening:
          http://bim42.com/2012/07/geometry-gym/
          If you could integrate IFC in your plugin, you could make Sketchup the best "slim" BIM software just like that.
          Like this:
          https://youtu.be/4n8U-PGmhCk
          And the code is open source:
          http://geometrygym.blogspot.rs/2016/02/openbim-just-became-more-open.html
          www.saurus.rs
          • F
            fluid
            We just released a new version of Viz, you can get it here.
            In this version:
            • Added smooth shading and texture mapping output into SketchUp
            • Added a few new nodes, including Extrude
            • Preliminary Mac support, on SketchUp 2015/2016
            • Updated sample scenes
            Here is a tutorial video about extrusions:
            [flash:2jxsg7a4]https://www.youtube.com/v/_lLORq8ZZo8[/flash:2jxsg7a4]
              Parametric indeed! ๐Ÿ˜Ž
              Why not 3D for thickness? (sure we have yet Joint PushPull by Fredo6)
              • JQLJ
                JQL
                In this version:
                OMG This is getting Huge
                www.casca.pt
                Visit us on facebook!
                • genki.ttG
                  genki.tt
                  Great Update ! I could try on my mac, THX.
                  • F
                    fluid
                    We are writing a getting started manual here.
                    It's still a work in progress and we would like to have your feedback about missing topics or things that need extra clarification.
                      If you are interested by a French version of the guide,
                      if it's not yet existing,
                      i can do it for the fun! ๐Ÿค“
                      Same for the UI - if you have some texts, lists ...for not have to swim in the code! ๐Ÿ˜„
                      French Translation of the guide done! ๐Ÿ˜„
                      • F
                        fluid
                        Thanks Pilou, great job!
                        • F
                          fluid
                          We now have 3d boolean operations in Viz! You can grab the new version here.
                          Version 0.5.0 highlights:
                          • 3d Boolean Operations
                          • Extrude node now works on surfaces as well, to create solids
                          • Added a few more nodes, like CapEdge, ExtractEdge, etc
                          • Updated the getting started guide
                          [flash:umzgk0ah]https://www.youtube.com/v/YJ2gFgG3Mk8[/flash:umzgk0ah]
                          • PixeroP
                            Pixero
                            Looking great. ๐Ÿ‘
                            Now if we can have non destructive quad chamfer/bevel please. ๐Ÿ˜‰
                              Cool! ๐Ÿ˜Ž
                              Does it the same is possible with 2 existing solids (not created with nodes) ?
                              Ps
                              So I must update my French manual! ๐Ÿ˜„
                              • F
                                fluid
                                @Pixero: added to the todo list
                                @pilou: Yes, you can use a "GeometrySource" node to get geometry from SketchUp and then perform boolean operations. Keep in mind the solids need to be closed.
                                  French Version Updated! ๐Ÿ˜„
                                    Does the Boolean Viz works with SU MAKE ?
                                    Seems not! Even Union! (Maybe it's different than Envelopp ?
                                    Suggestion : a Box Selection moving for place it for see that is behind! ๐Ÿ˜„
                                    • F
                                      fluid
                                      Did you turn off the preview on node "GeometrySource-1" and "GeometrySource-2"? Otherwise they'll probably cover the result of the boolean operation. Also, you should connect the "Out Geometry" pins to the inputs of the boolean operation, not the "Active" pins.
                                        OK! Better that works in SU MAKE except I must hide existing groups! ๐Ÿ˜‰
                                        Just something not very clear!
                                        How attribut easily an existing group to a specific Geometry Source Node?
                                        Here I create a group then create a Node Source Then click Set Geometry Source
                                        then I create a second group then a Second Node Source Then Click Set Geometry Source
                                        It's not possible to select a Node Source existing on the Screen then Click Set Geometry Source? or...
                                        There is a list a groups of Source objects but how to apply a specific Nodes?
                                        Verify if your start Viz default axes are in the same orientation than default Axes SU Screen!
                                        Seems there are not! ๐Ÿ˜„
                                        (Click for Zoom)
                                        • F
                                          fluid
                                          Currently the to assign SketchUp geometry to a GeometrySource node in Viz you have to select the appropriate GeometrySource in the list, but probably selecting the node directly in Viz would be more practical.
                                          I'm adding it to the to do list, together with the axis orientation issue.
                                          Instead of hiding the groups in SketchUp, you can also move the GeometrySink group to a different location, so you'll be able to see both the operands of the boolean operation as well as the results.
                                          • genki.ttG
                                            genki.tt
                                            I just installed v.0.5.0 on mac, but it doesn't start when I click Vz icon or select 'Start Viz' from menu ... what's wrong??
                                            SketchUp PRO 2016
                                            MacBookPro 15' OSX 10.11.6
                                            • 4 / 5
