    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 668.6k Views 39 Watching
    • H Offline
      herojack
      载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb 时出错
      Error: #<RuntimeError: can't modify frozen String>
      D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
      D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
        perroloco2000
        hi again Anton
        i have new portatil (with fresh windows 10 install)
        i´m not able to install AMS library (not 3.2.0. not 3.1.3.). trying with the .rbz by preferencs or extracting .zip in plugins folder same result: crash SU2016 or get the same error as herojack posted
        any help will be welcome in the way to use your nice plugins
        thanks
        Error al cargar archivo C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb
        C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
        C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require'
        C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
        C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
        • Y Offline
          ying2014
          hello Anton_S:
          I have a question,if I want to set a dialog,and the WedDialogs are on top one more time,but
          sketchup is activated, in other words,like (dlg.show_modal + AMS::Sketchup.activate),what should I do?
            Anton_S
            @Atek to install the plugin, place ams_lib folder and the ams_lib.rb into the plugins folder.
            The plugins folder is located in the following locations:
            • For SU8 and below the plugins folder is located in
              C:\Program Files (x86)\Google\Google SketchUp [n]\
            • For SU2013 the plugins folder is located in
              C:\Program Files (x86)\SketchUp\SketchUp 2013\
            • For SU2014+ the plugins folder is located in
              C:\Users[User Name]\AppData\Roaming\SketchUp\SketchUp 20XY\SketchUp
              I will post these instructions into the main post.
            @Perojack, @Perroloco2000 I will look into the error. Thanks for reporting.
            @Ying2014 If I understood you correctly you want to activate the dialog. For that there is an existing function, WebDialog.#bring_to_front. Can you elaborate a bit more if I didn't understand your question?
            • Y Offline
              ying2014
              @Anton_s,I want WebDialog to have been in the front until end of a program ,because I want to make the WebDialog as a mask,I can do something to model which I wan't people to see the process. WebDialog.#bring_to_front can't always in the front。
                Anton_S
                Here is the code Ying:
                title = "My Dialog"
                dlg = UI;;WebDialog.new(title)
                dlg.show
                hwnd = AMS;;Sketchup.find_window_by_caption(title)
                AMS;;Window.set_pos(hwnd, -1, 0,0,0,0, 0x0023) # The -1 here does the trick
                Though upgrade to 3.2.1 first as there was a small bug in that function.
                @Perojack, @Perroloco2000 I think the error is fixed now. Try the new version.
                • Y Offline
                  ying2014
                  @Anton_S,thank you very much!It is helpful.
                    perroloco2000
                    thanks for answer Anton
                    AMS Library 3.2.1. is working, no error
                    But I still have my past problem with AMS Window Settings: everytime i hide menu bar crash SU.
                    The others functions of the plugin are working but impossible hide menu bar without crash.
                    please help to optimize my screen
                      Anton_S
                      @Perroloco2000 give me a list of plugins your using, a list of shortcuts (Preferences->Shortcuts->Export...), sketchup version, sketchup localization (en, fr, or whatever) and windows version so that I could attempt to reproduce the crash and pin it down on my own machine.
                        perroloco2000
                        SketchUp Make 2016 16.1.1449 64-bits (spanish). Windows 10 Home 1511 (10586.164)
                        I have a fresh install of windows 10 (last version) and SketchUp (last version). I still haven´t other plugins, and didn´t modify default shortcuts.
                        I installed AMS Library 3.2.1. (all works)
                        I installed AMS Window Settings 4.2.0. all functions works but when I hide menu bar the crash come. Thanks
                          Anton_S
                          Ok I am able to reproduce it with Spanish localization. I even get frozen strings errors, which I have no idea what's causing them and how to prevent them. I will look into into it and do my best to fix it.
                            Anton_S
                            Hi perecollo2000. Try the new version. I think it should be fixed now.
                              perroloco2000
                              hi Anton .... YOU SOLVED IT!!!
                              100% working, thank you very much for your work, and quick reply
                              your plugins really help my work on the laptop screen
                              great autor, thanks
                                pnickles
                                Forgive me but I'm a newb who can barely work his way through/around Extensions.
                                I'm unable to get the MSphysics to load/run. It is registered under Plugins but I receive the following message when I open Sketchup2016. I've tried copying/pasting the "main.rb" file into every imaginable Plugin folder but it still fails to see/find the file.?
                                (I installed the AMS Library v3.2.2 AFTER I installed the MSphysics extension but the order of installation shouldn't matter, correct?)
                                I'm running Win8 via Parallels, SU2016.
                                Error message
                                Folder showing MAIN.RB file in MSPhysics folder
                                  Anton_S
                                  Pnickles, you got it into the correct plugins folder, but placed the content improperly.
                                  I suggest deleteding whatever you placed in the plugins folder manually (including MSPhysics which is placed improperly based on your screenshot) and starting over with the following instructions. Download ams_Lib_3.2.2.zip, extract it, and place ams_Lib folder and ams_Lib.rb file into the plugins folder. Same applies to MSPhysics_0.5.0.zip. It should look something like this:
                                    pnickles
                                    Different error messages now. See attached. Perhaps it's because I'm running Win8 via Parallels?
                                    • Bryan KB Offline
                                      Are there how to use instructions somewhere?
                                        Anton_S
                                        Bryan, in case you're wondering if it's a plugin, well it's not. AMS library is more of a dependency for a few of my other plugins.
                                        • W Offline
                                          wikii
                                          How to get the version number?
                                          AMS.ver ?
                                            Anton_S
                                            Use AMS::Lib::VERSION It returns a string like "3.3.0".
                                            • 3 / 6
