    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 677.6k Views 39 Watching
    • Y Offline
      ying2014
      @Anton_S,thank you very much!It is helpful.
        perroloco2000
        thanks for answer Anton
        AMS Library 3.2.1. is working, no error
        But I still have my past problem with AMS Window Settings: everytime i hide menu bar crash SU.
        The others functions of the plugin are working but impossible hide menu bar without crash.
        please help to optimize my screen
          Anton_S
          @Perroloco2000 give me a list of plugins your using, a list of shortcuts (Preferences->Shortcuts->Export...), sketchup version, sketchup localization (en, fr, or whatever) and windows version so that I could attempt to reproduce the crash and pin it down on my own machine.
            perroloco2000
            SketchUp Make 2016 16.1.1449 64-bits (spanish). Windows 10 Home 1511 (10586.164)
            I have a fresh install of windows 10 (last version) and SketchUp (last version). I still haven´t other plugins, and didn´t modify default shortcuts.
            I installed AMS Library 3.2.1. (all works)
            I installed AMS Window Settings 4.2.0. all functions works but when I hide menu bar the crash come. Thanks
              Anton_S
              Ok I am able to reproduce it with Spanish localization. I even get frozen strings errors, which I have no idea what's causing them and how to prevent them. I will look into into it and do my best to fix it.
                Anton_S
                Hi perecollo2000. Try the new version. I think it should be fixed now.
                  perroloco2000
                  hi Anton .... YOU SOLVED IT!!!
                  100% working, thank you very much for your work, and quick reply
                  your plugins really help my work on the laptop screen
                  great autor, thanks
                    pnickles
                    Forgive me but I'm a newb who can barely work his way through/around Extensions.
                    I'm unable to get the MSphysics to load/run. It is registered under Plugins but I receive the following message when I open Sketchup2016. I've tried copying/pasting the "main.rb" file into every imaginable Plugin folder but it still fails to see/find the file.?
                    (I installed the AMS Library v3.2.2 AFTER I installed the MSphysics extension but the order of installation shouldn't matter, correct?)
                    I'm running Win8 via Parallels, SU2016.
                    Error message
                    Folder showing MAIN.RB file in MSPhysics folder
                      Anton_S
                      Pnickles, you got it into the correct plugins folder, but placed the content improperly.
                      I suggest deleteding whatever you placed in the plugins folder manually (including MSPhysics which is placed improperly based on your screenshot) and starting over with the following instructions. Download ams_Lib_3.2.2.zip, extract it, and place ams_Lib folder and ams_Lib.rb file into the plugins folder. Same applies to MSPhysics_0.5.0.zip. It should look something like this:
                        pnickles
                        Different error messages now. See attached. Perhaps it's because I'm running Win8 via Parallels?
                        • Bryan KB Offline
                          Are there how to use instructions somewhere?
                            Anton_S
                            Bryan, in case you're wondering if it's a plugin, well it's not. AMS library is more of a dependency for a few of my other plugins.
                            • W Offline
                              wikii
                              How to get the version number?
                              AMS.ver ?
                                Anton_S
                                Use AMS::Lib::VERSION It returns a string like "3.3.0".
                                • Bryan KB Offline
                                  Thanks Anton, but what I'm looking for is how to use it. It's installed without a problem but I need some kind of instructions or tutorial on how to use the controls.
                                  Thanks.
                                    Anton_S
                                    The first post contains a link to the library's documentation. I not particularly sure if that's what you desire though.
                                    • Bryan KB Offline
                                      Anton, thanks. I found some great video tutorials. https://www.youtube.com/user/samketner/videos?sort=dd%26amp;view=0%26amp;shelf_id=0
                                      My new problem is that the UI menu is not displaying correctly nor or the contents.. There are no tabs and the menu window is not resizable so I cannot access the contents at the bottom of the screen.
                                      Here is a screen shot.
                                      Any ideas?
                                        ladyquestio
                                        I keep getting this error. What is happening?
                                        http://tanyaloser.tripod.com/loaderror10.JPG
                                          Anton_S
                                          Hmm. I'm not getting any errors in my SU8. Are you using the latest versions of both plugins? If not, try completely removing both and installing once again.
                                          Edit: Actually I'm getting a similar error when I attempt to start MSPhysics simulation in SU8. I haven't been able to determine the cause, so try sticking to SU2013+.
                                          Edit: I will ensure the compatibility with SU version prior to 2013 at some point.
                                            ladyquestio
                                            Anton:
                                            I removed all the files as per instruction. Defragged the HD. then reloaded SU8 . I have a video of what happens.
                                            Watch and see. then Tell me what I did wrong.
                                            https://youtu.be/nUL87J2N79A
                                            • 4 / 6
