    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
      600v is at it again!
      http://600v.deviantart.com/art/RM-311-A-1-619284192
      http://600v.deviantart.com/art/RM-311-A-2-619284555
      http://600v.deviantart.com/art/RM-311-A-3-619284651
      http://600v.deviantart.com/art/RM-311-A-4-619284710
      http://600v.deviantart.com/art/RM-311-A-5-619284804
        db11
        His work is absolutely jaw-dropping.
        Love his design aesthetic.
          The car designer Hero! 😎
          Seems he changes to KeyShot against Vray for SketchUp!
          • cottyC Offline
            cotty
            You should be in the pub more often (if it's possible πŸ˜‰ )...
            my SketchUp gallery
            • BoxB Offline
              If only they would extend the opening hours......
                They close the pubs there down under?
                • BoxB Offline
                  Believe or not Thomthom, they do. They've gotten very draconian around here since I was away.
                  Much rather be over there.
                    Pubs close?
                    • BoxB Offline
                      A little pub time fun.
                      Wouldn't want to bet on it's balance tho.
                      http://i155.photobucket.com/albums/s296/storeben/Dice.gif
                      Proxy in SU8 format.
                      • BoxB Offline
                        Yes Rich, Pubs do close, but the Irish can't comprehend such a thing and simply believe the little people carried them home when the time was right. That those same little people tend to bang their heads on bedroom door frames, cleaned out their wallets and have been known to do unspeakable things in their mouths is a small price to pay for the craic.
                        P.S. I added the proxy above if anyone wants it.
                        • cottyC Offline
                          cotty
                          Will you 3D print the result?
                          my SketchUp gallery
                          • BoxB Offline
                            I can do if people would be interested in seeing the result.
                            • cottyC Offline
                              cotty
                              I am. πŸ‘
                              my SketchUp gallery
                                Me three!
                                • Z Offline
                                  ZahariStoyanov
                                  Count me in πŸ˜„
                                    I bet that the sum of two opposite sides wiil be seven! πŸ’š
                                    • BoxB Offline
                                      Ok, set it to print, but it will take a few hours and I only have Black at the moment.
                                      Here it is starting, positioned along one edge for support reasons.
                                      I'll try and catch a photo when it is about half way so you can understand the support structure, but I have to go out so may miss it.
                                      • utilerU Offline
                                        utiler
                                        They certainly have, Box. In Queensland they've started serving last drinks at 2am!!!!
                                        Just Curious...
                                          Old news in Trondheim... πŸ˜’
                                          • BoxB Offline
                                            Well here you go, quick prepub post.
                                            Here it is about half way, you can see how the support structure is inter-meshed with it. This particular printer, an Up Mini, doesn't allow you to turn off support fully, although you can reduce it. The supports are very delicate and quite easy to remove. But it's best to position your piece to get the least possible, or in this case the most suitable.
                                            If I had set it square on it would have created a lot more support to fill the cube, it would have been better set on iy's point, but the tiny footprint would most likely have caused a print failure, as the connection to the 'raft' is remarkably tenuous.
                                            And here is the finished print, just waiting to be broken out of it's supports. You can see the individual layers of filament, these can be smoothed off with a bit of a light sand.
                                            Mind you this shape will be impossible to smooth perfectly as it's near impossible to get inside. Before you ask, it is a 50mm cube. and it took ~2.5 hours to print.
                                            I'll try and clean it up and post a finished pic soon.
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 82
                                            • 83
                                            • 37 / 83
