    3D Truss Models
    1.5k Posts 31 Posters 977.2k Views 30 Watching
    • medeekM Offline
      medeek
      As previously noted the web dialog from the plugin can actually be used external to SketchUp to explore gambrel attic geometry:
      http://design.medeek.com/resources/images/truss_su125_800.jpg
      Imperial Units:
      (design.medeek.com)
      Metric Units:
      (design.medeek.com)
      I might develop this into a web based app which would allow one to generate 2D AutoCAD geometry (.dwg) of the truss profile.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        With non-structural lookouts would you frame them something like this? This question is mostly directed at the contractors and carpenters out in the field who actually have to build these roofs. Typically as an engineer I never worry about these details especially when they are non-structural.
        http://design.medeek.com/resources/images/truss_su132_800.jpg
        In my opinion they aren't really doing a whole lot, much better to drop the gable truss and then cantilever them from the first in board truss (ie. structural outlookers).
        design.medeek.com
        • medeekM Offline
          medeek
          Hip Truss Algorithm:
          http://design.medeek.com/resources/truss/GEOMETRY/HIP1_800.jpg
          design.medeek.com
          • JQLJ Offline
            JQL
            I wish I would know what you're talking about, so I could help you. All this english roof terms are just... well foreign to me. πŸ˜„
            www.casca.pt
            Visit us on facebook!
            • medeekM Offline
              medeek
              Version 1.6.3 - 06.19.2016
              • Added Gable Dormers to the Minor Roof Sub-Menu (dormer walls only).
              For now only the walls of the dormer are created:
              http://design.medeek.com/resources/images/truss_su134_800.jpg
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              I am still ironing out the details on how to best model the roof geometry. I will probably offer either a rafter or truss option. Other details such as multiple windows will also come later.
              For now please test the metric and imperial wall creation. I will probably need to post a tutorial video on how to use this feature since it involves selecting the main roof plane (top of a rafter or truss) and then two points that define the width/exterior corners of the dormer.
              design.medeek.com
              • facerF Offline
                facer
                Medeek,
                A 3D Kubity model may help viewers explore your 3D Models πŸ˜„
                (refer to private PM note)
                https://www.kubity.com/p/tWg5zg
                [kubity:2u0sejcq]tWg5zg[/kubity:2u0sejcq]
                • medeekM Offline
                  medeek
                  Outlookers oriented horizontally with gable end truss top chord dropped:
                  http://design.medeek.com/resources/images/truss_su133_800.jpg
                  View model here:
                  3D Warehouse
                  https://www.kubity.com/p/g2XGL2
                  [kubity:nam3sa03]g2XGL2[/kubity:nam3sa03]
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    I like the ability to embed the kubity file directly, that makes it easy to view and convenient. The only downside is kubity does not display the edges so it is a bit hard to analyze the model fully. Is there a way to turn on edges in kubity?
                    The 3D Warehouse has the button that allows one to view the model in the 3D WebGL viewer, so to rotate and view the model in the browser is possible.
                    design.medeek.com
                    • facerF Offline
                      facer
                      Medeek,
                      I put your question to the Kubity forum on:
                      http://sketchucation.com/forums/viewtopic.php?f=400%26amp;t=65244%26amp;p=598242#p598242
                      Discussion can be viewed here:
                      http://sketchucation.com/forums/viewtopic.php?f=400%26amp;t=65244%26amp;p=598268#p598268
                      No definitive answer yet.
                      • medeekM Offline
                        medeek
                        Version 1.6.2 - 06.14.2016
                        • Added Symmetric Cathedral truss type, configurations: (AUTO).
                        • Metric input enabled for symmetric cathedral truss type.
                        • Added gable end trusses for symmetric cathedral truss type.
                        • Structural outlookers (vert. & horz.) enabled under advanced roof options for Symmetric Cathedral truss type.
                        Various sizes and configurations of a symmetric cathedral truss:
                        http://design.medeek.com/resources/images/truss_su130_800.jpg
                        View model here:
                        3D Warehouse
                        https://www.kubity.com/p/8s2EX8
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Testing the dormer (wall) feature out with a gambrel attic truss:
                          http://design.medeek.com/resources/images/truss_su135_800.jpg
                          These dormers have a typical gable profile but it might be useful to have a gambrel dormer option as well to match with a gambrel style roof. Note that I have not shown all of the ladder framing in the model. On a roof like this it could get quite extensive.
                          To generate the dormer roof I just used my rafter roof feature and then trimmed the elements back manually.
                          View model here:
                          3D Warehouse
                          https://www.kubity.com/p/uCN2F6
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Same barn with a few more details. For gambrel attic advanced options I should also include the option for a crow's beak as shown in this model and the option to set the extension.
                            http://design.medeek.com/resources/images/truss_su136_800.jpg
                            View model here:
                            3D Warehouse
                            https://www.kubity.com/p/hNVovS
                            design.medeek.com
                              MtnArch
                              This would be a GREAT addition! Is there any logic to how far back along the main fascia that the crow's beak is supposed to merge in? Could this be an option along with the depth for the extension?
                              Highest Regards,
                              Alan T. Hendry, RA
                              Architect
                              • facerF Offline
                                facer
                                Internal view:
                                Views will be available for Kubity in few weeks πŸ˜„
                                Crows Beak picture attached for clarity of term used.
                                • medeekM Offline
                                  medeek
                                  I hadn't thought this through enough. The logic for the crow's beak requires two inputs as you correctly stated:
                                  1.) The extension length from the rakeboard measured from the exterior edge of the rake to the furthest point of the crow's beak.
                                  2.) The merge distance along the main fascia where the crow's beak merges back into the rakeboard.
                                  The logic to create this actually won't be that difficult I just need to get to it.
                                  design.medeek.com
                                  • facerF Offline
                                    facer
                                    Dormer Framing - Ceiling option
                                    The attached image from:
                                    Canadian Wood-Frame House Construction p. 148
                                    http://www.cmhc-schl.gc.ca/odpub/pdf/61010.pdf
                                    shows ceiling for a flat section option. (ideal for services as electrical and other)
                                    • medeekM Offline
                                      medeek
                                      The problem with dormers is there is a number of ways to frame them up. The way I like to frame attic dormers when using trusses is have the front wall rest on the attic subfloor and then the side walls rest on the truss top chord. I've also seen it where all dormers walls rest on the subfloor of the attic.
                                      With a rafter roof that is open the entire dormer is often framed on the roof per facer's drawing (I call it a floating dormer).
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Under advanced options for gable roofs (truss and rafter) I am thinking about adding a "roof return" option. Any thoughts on "greek returns":
                                        http://design.medeek.com/plansets/garages/GARAGE4828-A6D-3B/PHOTOS/GREEK_RETURN_FRAMING.jpg
                                        http://design.medeek.com/plansets/garages/GARAGE4828-A6D-3B/PHOTOS/SHEATHING_RIGHT.jpg
                                        The images above shows a roof return with a gable termination, alternatively this could end with a hip termination as in below:
                                        http://architectage.com/aaattaches/aaattaches7/040619454852583.jpg
                                        Or with a full greek which stretches across the entire span:
                                        http://www.tractorbynet.com/forums/files/projects/261132d1334631697-what-do-you-call-roof-full-return-jpg
                                        Does anyone have any specific framing details on how best to frame these roof elements?
                                        As far as the logic to add them into the plugin it won't be a big deal, just an additional module that plugs into the advanced roof module.
                                        To simplify things I would used the same pitch on the returns as on the main roof. The three variables would be:
                                        1.) Return Type: Gable, Hip, Full
                                        2.) Length of the Return
                                        3.) Extension beyond Rake
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          A quick study of a hip return:
                                          http://design.medeek.com/resources/images/truss_su137_800.jpg
                                          Notice the inboard hip rafter does not terminate at the gable wall when the return length is too short. This poses some interesting framing given this situation, note the return on the right side of the roof is this case, not entirely sure how one would support/terminate the hip rafter in this situation.
                                          When the return length allows the hip rafter to terminate at the gable wall then the framing is fairly straightforward.
                                          The hip rafter will terminate at the gable wall when the return length is greater than or equal to twice the total return extension (Rakeboard Width + Gable Overhang + Return Extension).
                                          The other question that I have is how to apply the sheathing to these small odd shaped roof segments. How far up under the overhang should the sheathing extend?
                                          View model here:
                                          3D Warehouse
                                          https://www.kubity.com/p/ytJPd4
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            This is an excellent link:
                                            404 Not Found
                                            (spot.pcc.edu)
                                            They run the outside hip rafter back to the gable wall and don't run the barge rafter (rake board) to the fascia like I've shown, maybe I've got this wrong...
                                            This method would allow for sheathing of the return without having to notch around the barge rafter. I call this the floating barge rafter method:
                                            http://design.medeek.com/resources/images/truss_su138_800.jpg
                                            Compare with extending the barge rafter all the way to the fascia board:
                                            http://design.medeek.com/resources/images/truss_su139_800.jpg
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 75
                                            • 76
                                            • 13 / 76
