    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      Quick fix. The metric GUI now shows both metric and imperial in the preview pane for gambrel attic trusses. I've lumped it into Version 1.6.0 and uploaded the corrected release.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        Does the new RBZ overwrite the previous version
        or we must erase the "previous" by hand before loading?
        • medeekM
          medeek
          I usually manually remove the medeek extension and folder from my plugins folder since I don't trust that SketchUp will do a clean install. This guarantees that all files and folders were replaced.
          design.medeek.com
          • medeekM
            medeek
            Version 1.6.0 - 06.08.2016
            • Corrected a bug with raised heel fink trusses and structural outlookers.
            • Metric GUI for gambrel attic truss type now shows metric and imperial units in preview pane.
            • Added energy/raised heels for king post truss (3 variants: wedge, slider and vertical w/ strut).
            This update may seem minor but underneath the hood it is a big change. I've rewritten a significant portion of the common truss module so that I can now offer raised heel trusses for all the other common truss types. Be on the lookout for this update in the near future.
            Raised heel trusses (wedge, slider, vert) complicate things when combined with structural outlookers. I've had to add some significant logic to deal with all the permutations.
            design.medeek.com
            • medeekM
              medeek
              Various configurations of a 16' King Post Truss:
              http://design.medeek.com/resources/images/truss_su128_800.jpg
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              With a raised heel note the use of either a wedge, slider or vertical web with strut.
              design.medeek.com
              • medeekM
                medeek
                I was really hoping to make it to Basecamp this year but it does not look like it will happen. Hopefully some of you can vouch for me and put in a good word if you are attending this year. I'm going to try for next year and by then this plugin will be more substantial and a little more polished.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.6.1 - 06.11.2016
                  • Added Coffer truss type, configurations: (AUTO).
                  • Metric input enabled for coffer truss type.
                  • Added gable end trusses for coffer truss type.
                  • Structural outlookers (vert. & horz.) enabled under advanced roof options for Coffer truss type.
                  • Building parameter menu (2nd) and advanced options menu for trusses now default to last picked options of the session for that sub-menu item.
                  Various configurations of a 40' coffer truss shown below:
                  http://design.medeek.com/resources/images/truss_su129_800.jpg
                  The web triangulation algorithm automatically determines which configuration is appropriate based on the span between panel points. This simplifies the geometry input menu but does take some control from the user.
                  View model here:
                  3D Warehouse
                  design.medeek.com
                  • medeekM
                    medeek
                    Modified an existing truss roof to make it a half hip truss set:
                    http://design.medeek.com/resources/images/truss_su131_800.jpg
                    View model here:
                    3D Warehouse
                    This will be my first venture into more complex truss systems. I figured I would cut my teeth on the half hip (Jerkin Head, Tudor Hip) truss set first before attacking the more complex full hip variants of which there are many.
                    After sketching this model up and examining the geometry I now have a number of questions:
                    1. Are my roof planes correct? Note that I have drawn the apex of the hip roofs at the edge of the last full truss and not at its centerline. Not entirely sure what is common practice in this regard.
                    2. I've shown some non-structural outlookers along the rake. What would the outlookers along the half hip portion look like?
                    3. If I use structural outlookers how would those be framed in over the hip section?
                    4. Does the apex of the half hip typically coincide with the next truss or could it land somewhere between trusses? ie. the half hip length is some multiple of the truss spacing.
                    5. Is the hip section usually the same pitch as the rest of the roof? There is really no reason why it has to be.
                    6. As the length of the half hip increases the depth of the gable end truss decreases as does the first inboard truss. What is the practical limit for the minimum depth of the first inboard truss?
                    7. Does anyone have some shop drawings of this type of truss set that I can study?
                    design.medeek.com
                    • medeekM
                      medeek
                      As previously noted the web dialog from the plugin can actually be used external to SketchUp to explore gambrel attic geometry:
                      http://design.medeek.com/resources/images/truss_su125_800.jpg
                      Imperial Units:
                      404 - File or directory not found.
                      (design.medeek.com)
                      Metric Units:
                      (design.medeek.com)
                      I might develop this into a web based app which would allow one to generate 2D AutoCAD geometry (.dwg) of the truss profile.
                      design.medeek.com
                      • medeekM
                        medeek
                        With non-structural lookouts would you frame them something like this? This question is mostly directed at the contractors and carpenters out in the field who actually have to build these roofs. Typically as an engineer I never worry about these details especially when they are non-structural.
                        http://design.medeek.com/resources/images/truss_su132_800.jpg
                        In my opinion they aren't really doing a whole lot, much better to drop the gable truss and then cantilever them from the first in board truss (ie. structural outlookers).
                        design.medeek.com
                        • medeekM
                          medeek
                          Hip Truss Algorithm:
                          http://design.medeek.com/resources/truss/GEOMETRY/HIP1_800.jpg
                          design.medeek.com
                          • JQLJ
                            JQL
                            I wish I would know what you're talking about, so I could help you. All this english roof terms are just... well foreign to me. πŸ˜„
                            www.casca.pt
                            Visit us on facebook!
                            • medeekM
                              medeek
                              Version 1.6.3 - 06.19.2016
                              • Added Gable Dormers to the Minor Roof Sub-Menu (dormer walls only).
                              For now only the walls of the dormer are created:
                              http://design.medeek.com/resources/images/truss_su134_800.jpg
                              View model here:
                              3D Warehouse
                              I am still ironing out the details on how to best model the roof geometry. I will probably offer either a rafter or truss option. Other details such as multiple windows will also come later.
                              For now please test the metric and imperial wall creation. I will probably need to post a tutorial video on how to use this feature since it involves selecting the main roof plane (top of a rafter or truss) and then two points that define the width/exterior corners of the dormer.
                              design.medeek.com
                              • facerF
                                facer
                                Medeek,
                                A 3D Kubity model may help viewers explore your 3D Models πŸ˜„
                                (refer to private PM note)
                                https://www.kubity.com/p/tWg5zg
                                [kubity:2u0sejcq]tWg5zg[/kubity:2u0sejcq]
                                • medeekM
                                  medeek
                                  Outlookers oriented horizontally with gable end truss top chord dropped:
                                  http://design.medeek.com/resources/images/truss_su133_800.jpg
                                  View model here:
                                  3D Warehouse
                                  https://www.kubity.com/p/g2XGL2
                                  [kubity:nam3sa03]g2XGL2[/kubity:nam3sa03]
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    I like the ability to embed the kubity file directly, that makes it easy to view and convenient. The only downside is kubity does not display the edges so it is a bit hard to analyze the model fully. Is there a way to turn on edges in kubity?
                                    The 3D Warehouse has the button that allows one to view the model in the 3D WebGL viewer, so to rotate and view the model in the browser is possible.
                                    design.medeek.com
                                    • facerF
                                      facer
                                      Medeek,
                                      I put your question to the Kubity forum on:
                                      http://sketchucation.com/forums/viewtopic.php?f=400%26amp;t=65244%26amp;p=598242#p598242
                                      Discussion can be viewed here:
                                      http://sketchucation.com/forums/viewtopic.php?f=400%26amp;t=65244%26amp;p=598268#p598268
                                      No definitive answer yet.
                                      • medeekM
                                        medeek
                                        Version 1.6.2 - 06.14.2016
                                        • Added Symmetric Cathedral truss type, configurations: (AUTO).
                                        • Metric input enabled for symmetric cathedral truss type.
                                        • Added gable end trusses for symmetric cathedral truss type.
                                        • Structural outlookers (vert. & horz.) enabled under advanced roof options for Symmetric Cathedral truss type.
                                        Various sizes and configurations of a symmetric cathedral truss:
                                        http://design.medeek.com/resources/images/truss_su130_800.jpg
                                        View model here:
                                        3D Warehouse
                                        https://www.kubity.com/p/8s2EX8
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Testing the dormer (wall) feature out with a gambrel attic truss:
                                          http://design.medeek.com/resources/images/truss_su135_800.jpg
                                          These dormers have a typical gable profile but it might be useful to have a gambrel dormer option as well to match with a gambrel style roof. Note that I have not shown all of the ladder framing in the model. On a roof like this it could get quite extensive.
                                          To generate the dormer roof I just used my rafter roof feature and then trimmed the elements back manually.
                                          View model here:
                                          3D Warehouse
                                          https://www.kubity.com/p/uCN2F6
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Same barn with a few more details. For gambrel attic advanced options I should also include the option for a crow's beak as shown in this model and the option to set the extension.
                                            http://design.medeek.com/resources/images/truss_su136_800.jpg
                                            View model here:
                                            3D Warehouse
                                            https://www.kubity.com/p/hNVovS
                                            design.medeek.com
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 76
                                            • 77
                                            • 22 / 77
