    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • facerF
      facer
      Medeek,
      A 3D Kubity model may help viewers explore your 3D Models πŸ˜„
      (refer to private PM note)
      https://www.kubity.com/p/tWg5zg
      [kubity:2u0sejcq]tWg5zg[/kubity:2u0sejcq]
      • medeekM
        medeek
        Outlookers oriented horizontally with gable end truss top chord dropped:
        http://design.medeek.com/resources/images/truss_su133_800.jpg
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        https://www.kubity.com/p/g2XGL2
        [kubity:nam3sa03]g2XGL2[/kubity:nam3sa03]
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          I like the ability to embed the kubity file directly, that makes it easy to view and convenient. The only downside is kubity does not display the edges so it is a bit hard to analyze the model fully. Is there a way to turn on edges in kubity?
          The 3D Warehouse has the button that allows one to view the model in the 3D WebGL viewer, so to rotate and view the model in the browser is possible.
          design.medeek.com
          • facerF
            facer
            Medeek,
            I put your question to the Kubity forum on:
            http://sketchucation.com/forums/viewtopic.php?f=400%26amp;t=65244%26amp;p=598242#p598242
            Discussion can be viewed here:
            http://sketchucation.com/forums/viewtopic.php?f=400%26amp;t=65244%26amp;p=598268#p598268
            No definitive answer yet.
            • medeekM
              medeek
              Version 1.6.2 - 06.14.2016
              • Added Symmetric Cathedral truss type, configurations: (AUTO).
              • Metric input enabled for symmetric cathedral truss type.
              • Added gable end trusses for symmetric cathedral truss type.
              • Structural outlookers (vert. & horz.) enabled under advanced roof options for Symmetric Cathedral truss type.
              Various sizes and configurations of a symmetric cathedral truss:
              http://design.medeek.com/resources/images/truss_su130_800.jpg
              View model here:
              3D Warehouse
              https://www.kubity.com/p/8s2EX8
              design.medeek.com
              • medeekM
                medeek
                Testing the dormer (wall) feature out with a gambrel attic truss:
                http://design.medeek.com/resources/images/truss_su135_800.jpg
                These dormers have a typical gable profile but it might be useful to have a gambrel dormer option as well to match with a gambrel style roof. Note that I have not shown all of the ladder framing in the model. On a roof like this it could get quite extensive.
                To generate the dormer roof I just used my rafter roof feature and then trimmed the elements back manually.
                View model here:
                3D Warehouse
                https://www.kubity.com/p/uCN2F6
                design.medeek.com
                • medeekM
                  medeek
                  Same barn with a few more details. For gambrel attic advanced options I should also include the option for a crow's beak as shown in this model and the option to set the extension.
                  http://design.medeek.com/resources/images/truss_su136_800.jpg
                  View model here:
                  3D Warehouse
                  https://www.kubity.com/p/hNVovS
                  design.medeek.com
                    MtnArch
                    This would be a GREAT addition! Is there any logic to how far back along the main fascia that the crow's beak is supposed to merge in? Could this be an option along with the depth for the extension?
                    Highest Regards,
                    Alan T. Hendry, RA
                    Architect
                    • facerF
                      facer
                      Internal view:
                      Views will be available for Kubity in few weeks πŸ˜„
                      Crows Beak picture attached for clarity of term used.
                      • medeekM
                        medeek
                        I hadn't thought this through enough. The logic for the crow's beak requires two inputs as you correctly stated:
                        1.) The extension length from the rakeboard measured from the exterior edge of the rake to the furthest point of the crow's beak.
                        2.) The merge distance along the main fascia where the crow's beak merges back into the rakeboard.
                        The logic to create this actually won't be that difficult I just need to get to it.
                        design.medeek.com
                        • facerF
                          facer
                          Dormer Framing - Ceiling option
                          The attached image from:
                          Canadian Wood-Frame House Construction p. 148
                          http://www.cmhc-schl.gc.ca/odpub/pdf/61010.pdf
                          shows ceiling for a flat section option. (ideal for services as electrical and other)
                          • medeekM
                            medeek
                            The problem with dormers is there is a number of ways to frame them up. The way I like to frame attic dormers when using trusses is have the front wall rest on the attic subfloor and then the side walls rest on the truss top chord. I've also seen it where all dormers walls rest on the subfloor of the attic.
                            With a rafter roof that is open the entire dormer is often framed on the roof per facer's drawing (I call it a floating dormer).
                            design.medeek.com
                            • medeekM
                              medeek
                              Under advanced options for gable roofs (truss and rafter) I am thinking about adding a "roof return" option. Any thoughts on "greek returns":
                              http://design.medeek.com/plansets/garages/GARAGE4828-A6D-3B/PHOTOS/GREEK_RETURN_FRAMING.jpg
                              http://design.medeek.com/plansets/garages/GARAGE4828-A6D-3B/PHOTOS/SHEATHING_RIGHT.jpg
                              The images above shows a roof return with a gable termination, alternatively this could end with a hip termination as in below:
                              http://architectage.com/aaattaches/aaattaches7/040619454852583.jpg
                              Or with a full greek which stretches across the entire span:
                              http://www.tractorbynet.com/forums/files/projects/261132d1334631697-what-do-you-call-roof-full-return-jpg
                              Does anyone have any specific framing details on how best to frame these roof elements?
                              As far as the logic to add them into the plugin it won't be a big deal, just an additional module that plugs into the advanced roof module.
                              To simplify things I would used the same pitch on the returns as on the main roof. The three variables would be:
                              1.) Return Type: Gable, Hip, Full
                              2.) Length of the Return
                              3.) Extension beyond Rake
                              design.medeek.com
                              • medeekM
                                medeek
                                A quick study of a hip return:
                                http://design.medeek.com/resources/images/truss_su137_800.jpg
                                Notice the inboard hip rafter does not terminate at the gable wall when the return length is too short. This poses some interesting framing given this situation, note the return on the right side of the roof is this case, not entirely sure how one would support/terminate the hip rafter in this situation.
                                When the return length allows the hip rafter to terminate at the gable wall then the framing is fairly straightforward.
                                The hip rafter will terminate at the gable wall when the return length is greater than or equal to twice the total return extension (Rakeboard Width + Gable Overhang + Return Extension).
                                The other question that I have is how to apply the sheathing to these small odd shaped roof segments. How far up under the overhang should the sheathing extend?
                                View model here:
                                3D Warehouse
                                https://www.kubity.com/p/ytJPd4
                                design.medeek.com
                                • medeekM
                                  medeek
                                  This is an excellent link:
                                  http://spot.pcc.edu/~rsteele/BCT122_123/return_eave.pdf
                                  They run the outside hip rafter back to the gable wall and don't run the barge rafter (rake board) to the fascia like I've shown, maybe I've got this wrong...
                                  This method would allow for sheathing of the return without having to notch around the barge rafter. I call this the floating barge rafter method:
                                  http://design.medeek.com/resources/images/truss_su138_800.jpg
                                  Compare with extending the barge rafter all the way to the fascia board:
                                  http://design.medeek.com/resources/images/truss_su139_800.jpg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.6.4 - 06.27.2016
                                    • Added roof return option within the advanced options menu for common, scissor and vaulted trusses, configurations: (HIP).
                                    http://design.medeek.com/resources/images/truss_su140_800.jpg
                                    View model here:
                                    3D Warehouse
                                    https://www.kubity.com/p/DnsBmT
                                    This option is available for most typical triangular shaped trusses.
                                    I will be adding the gable and full return at a later date, currently only the hip return is available. Another limitation is that the return roof pitches currently default to the main roof pitch. I need to add some additional code that will allow the pitch of the return portions to be set independent of the main roof pitch.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      12:12 main roof with a 8:12 hip roof return. The interesting part is the hip rafter
                                      where the return meets the main roof plane. The dropped hip rafter is off center so that it supports the sheathing from both planes. The calculations might prove challenging.
                                      http://design.medeek.com/resources/images/truss_su141_800.jpg
                                      Typically the return pitch is less than or equal to the main roof pitch. In fact I don't think I've ever seen a return with a pitch greater than the main roof.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Roof return pitch can now be set independent of main roof pitch:
                                        http://design.medeek.com/resources/images/truss_su142_800.jpg
                                        The calculations for a hip rafter that handles two pitches was insane as expected. I've also made some other minor adjustments and bug fixes related to the sheathing and rake board when the roof return extension equals the gable overhang.
                                        I've set it up so that the return pitch can also be greater than the main roof pitch but its doubtful if this will find any usage.
                                        There may be better ways of framing the hip rafter where the return meets the main roof, any thoughts on this are welcome. The initial release of 1.6.4 had a bug with attic trusses and the returns so I suggest downloading the latest version.
                                        I'm also looking for photos of the framing for a full greek return to further study this.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Looking at the lumber and I-Joist floor module this morning and thinking it might be nice to make an option that allows one to specify something other than a rectangle for the floor outline. For example an L-shaped floor outline:
                                          http://design.medeek.com/resources/images/truss_su143_800.jpg
                                          View model here:
                                          3D Warehouse
                                          https://www.qrvr.io/p/HlnqPF
                                          Or even more exotic shapes with non-orthogonal corners. I'll be giving this some thought over the weekend.
                                          design.medeek.com
                                          • jujuJ
                                            juju
                                            Hi Nathaniel,
                                            Will you be able to include an option to generate purlins / battens? Here our standard construction method places this in the position where the roof sheathing goes, directly on top of the trusses. The top and bottom batten / purlin position could possibly be customisable (distance from apex and from edge / fascia). Obviously will require input field for width / height, maximum spacing field as well but this should possibly require a toggle for constant spacing from lowest portion of TC to apex position.
                                            I would really appreciate this, unless the function is there and I'm missing it, please advise... Thanks in advance!
                                            PS:
                                            I know the focus of the plugin is for the roof trusses / structure, but could you have an option to include the roofing material? This only needs to be a simple structure, similar to the sheathing option but placement on top of purlins / battens with input field for thickness. πŸ˜„
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 76
                                            • 77
                                            • 22 / 77
