    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    597 Posts 120 Posters 2.2m Views 120 Watching
    • fredo6F Offline
      New Release: Animator - v1.0q - 20 May 16
      Main changes:
      • fixed a major bug for non-English keyboard (say French!), whereby movements would not load due to the problem of decimal separator in Sketchup for length. I noticed it in a model by Pilou (thanks).
      • TheaRender: implemented a timeout so that Animator stops the rendering and goes to the next frame if the rendering of a frame is > 3 times the rendering of the previous frame. So you shoudl now be able to launch a rendering with Thea and go take a coffee or lunch.
      See main post for RBZ files
      • JQLJ Offline
        JQL
        Thanks Fredo, I'm starting it now!
        www.casca.pt
        Visit us on facebook!
        • fredo6F Offline
          New Release: Animator - v1.0r - 23 May 16
          Main changes:
          • Fixed tentatively a number of problems on Mac OSX signaled by Oxer, such as the size of the Video Generation dialog box and the video file generation by FFmpeg
          • Typing SpaceBar or a shortcut provoking a change of interactive tool now switch to Temporary Exit. A confirmation message is displayed. An option in Default Parameters allows to skip confirmation.
          • other bug fixing, in particular to avoid empty sequences
          • JQLJ Offline
            JQL
            Thanks for providing this solution so fast!
            I will resume my endeavours with animator asap!
            www.casca.pt
            • ntxdaveN Offline
              ntxdave
              Started to build a new animation with v1.0r. Was in the process of adding a translation sequence for the car and decided I had made an error so I hit X icon to escape without saving the sequence and now I have the screen below. I do not seem to be able to stop Animator or restart it. I did finally get the button to Back to Animator but the screen stayed the same.
              I was finally able to continue by triple clicking in the viewport which killed Animator and I was able to restart it.
              This has happened 3 times now.........
              Press F1...thank me later
              • fredo6F Offline
                Dave,
                Just republished Animator 1.0r with the fix. Sorry for that.
                LibFredo6 7.0r is unchanged.
                I need also to think of an Escape, in case of bugs, because with the new Temporary exit feature, I got into a circular issue.
                • ntxdaveN Offline
                  ntxdave
                  @fredo6 said:
                  Dave,
                  Thanks.......I will update immediately 😎
                  Tried the same thing - exiting the creation of a motion and it seemed back to normal (yes-it worked properly) πŸ‘ πŸ‘
                  • duanekempD Offline
                    duanekemp
                    New update downloaded today.
                    Thank you so much.
                    Duane Kemp
                    Kemp Productions
                    Puidoux, Switzerland
                    Gallery:
                    https://duanekemp.artstation.com/
                    • fredo6F Offline
                      New Release: Animator - v1.0t - 02 Jun 16
                      • New Features
                      • Visual Effects: Layer visibility, rendering style, shadow. This allows to set these parameters independently of views
                      • Support of SketchFX Ex (thanks to Alberto and Fluid)
                      • Preview in timeline (you need to set it up in Default Parameters)
                      • Maintenance - Fixes and adjustments
                      • Bug in Make film from selection
                      • Non-ascii characters in model path and name made FFmpeg to fail - fixed
                      • Position of the timeline (horizontal or vertical) is now retained across Sketchup sessions
                      • Bug in Previw of video and sample image on Mac
                      • Cosmetic changes in GUI
                      I'll try to make some videos to demo the features more in details.
                      In the meantime, here is a small GIF showing that you can play with styles, layer visibility and shadows independently of views (watch the palette, shadows and background style).
                      • soloS Offline
                        I am having issues with this release, see video.
                        • ntxdaveN Offline
                          ntxdave
                          Hey Pete - that stuff looks familiar πŸ˜›
                          • soloS Offline
                            lol, yeah, I was trying something out that I thought could help you but I am having issues making my idea work.
                            • ntxdaveN Offline
                              ntxdave
                              Care to share?
                              • soloS Offline
                                Trying to figure out how to do the water spray
                                • ntxdaveN Offline
                                  ntxdave
                                  I have it working (not as an animated texture) but have it showing up and then hiding. I also did one where I used the Video Texture plugin that animates the spray but it did not work well with Animator. The animation of the texture did not show at all.
                                  Take a look at this thread: http://sketchucation.com/forums/viewtopic.php?f=401%26amp;t=65021%26amp;p=597074#p597074
                                  • fredo6F Offline
                                    New Release: Animator - v1.0u - 04 Jun 16
                                    Maintenance and small evolutions
                                    • Rendering Style bug is fixed. Should now work
                                    • A Layer visibility element will now restore previous layer visibility when it is finished if it has a non-zero duration (as requested by ntxdave)
                                    • Consistent numbering in naming by default (as suggested by Rich O Brien)
                                    • You can now open components and groups when in temporary exit to Sketchup
                                    • Cosmetic changes in Video generation dialog box
                                    • ntxdaveN Offline
                                      ntxdave
                                      Ran some quick tests........
                                      Style Change
                                      Style now changes........
                                      Layer Visibilitu
                                      Layer turned on but did not turn off at the end of the duration
                                      Paint Brush
                                      Was able to temporally exit and change the use the paint brush to edit an object.
                                      My observation was that sequences were sequentially numbered...
                                      Did not try to create a video yet.........
                                      • fredo6F Offline
                                        You need to hve a defined state for the layer visibility before your Layer visibility element.
                                        In general, it's a good idea to place a view with shadow, style and layer visibility at the beginning of the film so that the animation always starts in a determined state.
                                        • ntxdaveN Offline
                                          ntxdave
                                          Tried just putting a normal view at the beginning and it did not change anything. Then I added a layer view at the beginning with 0 seconds and all works well (see below).
                                          Layer Control - click to play
                                          Fredo, I am fine with this. I fully understand having to place this view at the beginning. It helps insure that we have captured the "default" setting for all layers. I like using the duration to control when the layer returns to its original state. It give me a better visual of when the layer state will be changed in one control rather than having to identify 2 controls which could wind up in different time lines. Thanks very much for implementing it this way.
                                          I only have one last item to be able to do my full car wash (as I currently see it 😐 ). I need to be able to scale a couple of pieces. Now I have to go off and generate several different materials for different types of sprays/foams.
                                          • ntxdaveN Offline
                                            ntxdave
                                            OK - If I have multiple layers to show/hide, I cannot get it to work correctly (at least the way I would like) using the duration greater than 0.
                                            Here is an example. I have 2 spray units. I have them at different times and different durations. They both turn on correctly but they do not turn off until after the 2nd layer is to be hidden.
                                            Multiple layer control - click to view
                                            I will try later using the original method of setting 0 duration for each layer to show and hide and see what happens. While this works, I was hoping the previous method would work as well. Maybe I am pushing the envelope a little too far. I will have multiple situations like this is a full wash. As previously stated, if a single control for each layer can be accomplished, IMO it would be much easier to manage.
                                            Is this way out of perspective ❓
                                            OK - I see what is going on is that each time any action is taken, it is for ALL layers. Thus I would need to break my example down and have 5 layer visibility captures:
                                            1. At beginning to capture the initial state of all layers
                                            2. Beginning of the first spray to turn that layer on and the other spray layer off
                                            3. Beginning of the second spray to turn that layer on and make sure the other layer is still on
                                            4. End of the first spray to turn that layer off and make sure the other spray is still on (since in the case there is actually some overlap
                                            5. End of the second spray to turn that layer off
                                            Is it out of the question to ask if it is possible to control each layer independently?
                                            • 29
                                            • 30
                                            • 1 / 30
