    Animator State per scene
    renderpluginsextensions
    20 Posts 4 Posters 10.4k Views 4 Watching
    • ntxdaveN
      ntxdave
      @fredo6 said:
      @JQL: there is no CSS, as I style the dialog boxes in Ruby. But could be an option
      @ntxdave: Yes, I will certainly present differently anyway. Currently, this is more for me to debug.
      One small remark:
      • In Edit mode, you see all films, clip and sequence.
      • If you click on one row, you select it, it becomes yellow
      • You can switch to the Runtime mode by toggling the small wrench (the panel gets blue) and you only see the sliders selected.
      Good things to know.......
      Boy, this thread got me thinking. It would be great if the visitor worked inside the SketchUp Viewer or if there was a way to get this view in a web page. At a convention, I had a number of links for videos of different car washes. Man would it be neat if there was a way to click on a link for a car wash and it would launch the visitor and its capabilities. Would almost eliminate the need for generating videos πŸ˜„
      Press F1...thank me later
      • fredo6F
        Actually, I was thinking of creating dynamic components (switches and various shapes), so that when you interact you start a piece of animation.
        • ntxdaveN
          ntxdave
          Where I would eventually like to go is to not have to have the SketchUp software installed. Just a way to view the files with some animation.
          • JQLJ
            JQL
            Grea idea! I wonder how far off from an animation plugin animator would go if you follow that path, but I like the possibilities.
            www.casca.pt
            Visit us on facebook!
            • ntxdaveN
              ntxdave
              @jql said:
              Yep - good question.
              Again, I think the capabilities for the visitor is something I have wanted for a long time. I would like to be able to share the file and let them see the model and its animations without having to have the SketchUp software. Again, thinking about being able to give a customer the file with animations but they do not have SU.
              Either way, I like what I am seeing but other things are more important to me in the short run (like scaling). I need that for a couple of pieces of the car wash equipment but then I am being short sighted. I am willing to go with the majority and Fredo's original schedule.
              • JQLJ
                JQL
                If you don't have sketchup how do you get visitor in a file? Sketchup viewer, for what I know, doesn't have ruby support so you can't have visitor activated in it. Or am I missing something?
                www.casca.pt
                • ntxdaveN
                  ntxdave
                  Right now, they only show the customer drawings. I am trying to entice them with animations. So, other than me and the president of the company no one ever sees the actual SU files. I think the president has a copy of SU but no one else does. The only time they really see the files is at a convention and even then they only use PDF and movie files. What I am seeing with the visitor has, in my opinion, the opportunity to show off the SU file in a really constructive way. At least that is my goal. I am searching for a way to get them beyond the paper environment.
                  Last night I was thinking, wouldn't it be neat if you could use the visitor feature to show off your model on a tablet with all of the animation features. But then, I have been accused of being crazy before. Back in the late 70's some people I worked with at a technology company thought I should be fired because I suggested building a portable computer (can you say laptop).
                  Anyway, the visitor feature of Animator has me fired up. I see lots of potential for showing models developed in SU. Architecture like you discussed, products demos like Solo showed and many more things where you have the ability to "bring that drawing/product to life". What I am seeing is via Animator, you can produce a lot of the same type of things as Lumion, LumenRT and others. Maybe I am going too far.
                  • ntxdaveN
                    ntxdave
                    Fredo, I am not sure how/if this should be addressed. In some of my testing/learning, I created an animation that uses views to capture different scenes to show/hide objects.
                    In the video below, I used the view to capture a "spray" when the car reaches a certain piece of equipment. In the normal videos, this works great. However, when I view it using the Visitor, I do not get the same thing because it ignores my "views" and shows things based on the scene that I have active. Notice that there are 2 scenes in this model. One is named "No Spray" and the other is named "Spray". I added a view just before the piece of equipment that sprays to switch the scene from "No Spray" to "Spray" so you would see the spray when the car goes through that piece of equipment. In a full car wash, this type of situation will take place several times and it works just fine. But in Visitor it does not work because it shows the entire animation based on the view of the selected scene. Hope this makes sense.
                    Maybe I asking to "eat my cake and have it too". Is there any way to view the animation the same way in both Animator and the Visitor? Again, this is not the highest priority in the world. I see this as a long range question that is far less important than many of the other things you are working on.
                    • fredo6F
                      Dave,
                      Yes I know. Visitor is just in draft mode.
                      Actually, I will allow the usage of views (same filtering as in the Editor).
                      I will also decouple the Camera, Style and Layer Visibility in the next version. View Camera will still have the possibility to carry style and layer visibility, but that will not be the default.
                      This will allow to control layers independently of view (in your case, the visibility of the water curtain is linked to the animation of the car, regardless of the view).
                        Your horizontal blue object don't rotate, does this normal?
                        • ntxdaveN
                          ntxdave
                          @fredo6 said:
                          Dave,
                          Sounds good to me.. πŸ‘ πŸ‘ πŸ‘
